Please see the post below for current information and installation instructions.
DSC Alarm Plugin - Installation and Information
There is no provision to "Arm Stay"; only "Arm Away". And no detail as to the nature of any "Error" status. These are limitations of the TL-150.
Incidentally, the TL-150 also reports (individually for each zone) the number of minutes (up to 1 hour, I think) that have elapsed since the zone's status changed. I find that to be very handy. This is not shown in the screen shot since that information is only displayed as a tooltip if you hover the cursor over a zone in the grid (can't capture that in a screenshot). But, since the information is in the HTML, it's easily parsed and can therefore be made available to Indigo via the plugin.
First, I think we'll need to clearly define exactly what we want the plugin to do. Personally, I'm of the Keep It Simple philosophy. I would propose a plugin that simply updates a collection of user-named Indigo variables that represent the current System Status, the status of each zone, and optionally, the elapsed time since the most recent status chagne for each zone. The user could then decide what to do with those variables.
Looks good! So, you can arm/disarm the system from your phone without entering an access code? I debated myself endlessly about that, and finally decided to require the code. It shouldn't be hard to make that part optional, though; let the user decide.
peppop wrote:I am curious, are you using the same thing to create your interface? If not, please explain. A plug in would be great for the IT-100 & the TL-150.
peppop wrote:Sum info that the TL-150 provides.
peppop wrote:Like to try your script, will you post it, with directions on how to?
DSC Alarm Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 84, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/DSC Alarm.indigoPlugin/Contents/Server Plugin/DSC.py", line 488, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/DSC Alarm.indigoPlugin/Contents/Server Plugin/DSC.py", line 207, in readPacket
<type 'exceptions.UnicodeDecodeError'>: 'ascii' codec can't decode byte 0xdf in position 7: ordinal not in range(128)
DSC Alarm Error plugin runConcurrentThread function returned or failed; will attempt
peppop wrote:It looks good thank you.
I'm getting thees errors
