RFPlayer error
Fri Jan 03, 2020 12:29 pm
Colly offline
RFPlayer error
Hi Joe,
Getting this error for a while now and haven't followed up on it, everything seems to be working fine - I just use it for 6 motorised blinds in my living room.
   RFPlayer Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 95, in runConcurrentThread
TypeError: not all arguments converted during string formatting
   RFPlayer Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Let me know if I can do anything to provide more info.
Fri Jan 03, 2020 12:41 pm
Re: RFPlayer error
What version are you running? Also, can you turn on debug logging and send me the log around the error.
I'm confused because line 95 in the current version doesn't do any string formatting.
Fri Jan 03, 2020 12:46 pm
Colly offline
Re: RFPlayer error
Running V7.0.3
Turned on debug logging and will reply with output once received.
Fri Jan 03, 2020 12:58 pm
Re: RFPlayer error
Colly wrote:
Running V7.0.3
My bad, the plugin store was not up to date. Current version is 7.2.0. Try that one.
Fri Jan 03, 2020 12:59 pm
Colly offline
Re: RFPlayer error
On it :D
Just for info, the error generally comes up once or twice every hour..
Fri Jan 03, 2020 1:01 pm
Re: RFPlayer error
Colly wrote:
On it :D
It was actually caused by a bad logging statement, which is only displayed when the receiver sees an RF frame that it doesn't recognize. You should still get a message about the unrecognized frame, but it won't cause an exception.
Fri Jan 03, 2020 1:03 pm
Colly offline
Re: RFPlayer error
Just updated, see below just in case there's anything of interest to you.
   Stopping plugin RFPlayer (pid 25160)
   RFPlayer Debug                  RFPlayer: Stopping Interface device
   RFPlayer Debug                  RFPlayer stop called
   RFPlayer                        Shutting down RFPlayer
   Stopped plugin RFPlayer
   Upgrading plugin RFPlayer to newer version 7.2.0 (previous version moved to trash)
   Loading plugin "RFPlayer 7.2.0"
   Starting plugin "RFPlayer 7.2.0" (pid 43029)
   Started plugin "RFPlayer 7.2.0"
   RFPlayer                        Starting RFPlayer
   RFPlayer Debug                  RFPlayer: Starting Device
   RFPlayer Debug                  RFPlayer: Updated device version: 0 -> 2
   RFPlayer Debug                  RFPlayer start called, port = /dev/cu.usbserial-A1251VTU, baud = 115200
   RFPlayer                        Opened serial port /dev/cu.usbserial-A1251VTU at 115200 baud
   Error                           device "RFPlayer" state key playerStatus not defined (ignoring update request)
   RFPlayer Debug                  RFPlayer: deviceStartComm complete, sensorDevices[] =
   RFPlayer                        Welcome to Ziblue Dongle RFPLAYER (RFP1000, Firmware V1.12 Mac 0xFD0C80E9)!
   RFPlayer Debug                  RFPlayer: systemStatus frame received
   Error                           device "RFPlayer" state key firmwareVers not defined (ignoring update request)
   RFPlayer Debug                  RFPlayer: radioStatus frame received
   Error                           device "RFPlayer" state key lowBandFreq not defined (ignoring update request)
   Error                           device "RFPlayer" state key highBandFreq not defined (ignoring update request)
   RFPlayer Debug                  RFPlayer logLevel = 10
Fri Jan 03, 2020 1:05 pm
Re: RFPlayer error
You might want to edit that RFPlayer device to stop those errors. Just edit the device configuration and save it again.
Fri Jan 03, 2020 1:08 pm
Colly offline
Re: RFPlayer error
Yes that sorted it.
Thanks for the prompt response.
Fri Jan 03, 2020 1:19 pm
Colly offline
Re: RFPlayer error
Further update in log, see below:
   RFPlayer Error                  RFPlayer: Unknown protocol:
    "frame": {
        "header": {
            "cluster": "0",
            "dataFlag": "0",
            "floorNoise": "-99",
            "frameType": "0",
            "frequency": "433920",
            "infoType": "0",
            "protocol": "0",
            "protocolMeaning": "-",
            "rfLevel": "-94",
            "rfQuality": "2"
        "infos": {
            "id": "0",
            "idMeaning": "A1",
            "subType": "0",
            "subTypeMeaning": "OFF"
Fri Jan 03, 2020 1:21 pm
Re: RFPlayer error
Yeah, I should probably not have that as an error log entry. I'll fix it eventually.
Fri Jan 03, 2020 1:24 pm
Colly offline
Re: RFPlayer error
No problem!
