Somfy/RTS control
Wed Aug 01, 2018 4:15 pm
Re: Somfy/RTS control
OK, looking over the data, you definitely have some bogus known devices data, and I don't think the instructions in my last post will clean them up.
So, edit the preferences file for the plugin, which is at <Indigo install>/Preferences/Plugins/com.flyingdiver.indigoplugin.rfplayer.indiPref
First, delete all the Indigo devices for the shades, then disable the plugin. Use a plain text editor to edit the file.
Delete everything between these two lines:
   <knownDevices type="dict">
   </knownDevices>
Save the file, then restart the plugin. You'll need to use your remote again so that the RFPlayer sees the commands and adds them to the known devices list. Then recreate the Indigo devices.
Sorry for all this. I'm going to work on code to try to clean this up automatically, but that's going to take a bit of work.
Sun Aug 05, 2018 9:10 am
koburg offline
Hi
I Have done also the Manuel clearing of the com.flyingdiver.indigoplugin.rfplayer.indiPref
and the device list are then working
but Still same issue's from earlier.
Sun Aug 05, 2018 9:27 am
I'm not going to try to guess what issues from before actually means.
Now that we have the devices cleaned up, please post a known devices dump. And then post a log section showing the commands you're executing and the results.
Thu Aug 09, 2018 2:28 pm
koburg offline
it means still no luck getting things working
here is the dump:
   RFPlayer                        Known device list:
knownDevices : (dict)
     DOMIA-A1 : (dict)
          description : A1 (string)
          devices : (list)
          frameData : (dict)
               header : (dict)
                    cluster : 0 (string)
                    dataFlag : 0 (string)
                    floorNoise : -89 (string)
                    frameType : 0 (string)
                    frequency : 433920 (string)
                    infoType : 0 (string)
                    protocol : 6 (string)
                    protocolMeaning : DOMIA (string)
                    rfLevel : -78 (string)
                    rfQuality : 2 (string)
               infos : (dict)
                    idMeaning : A1 (string)
                    subType : 0 (string)
                    subTypeMeaning : OFF (string)
          playerId : 1767248280 (integer)
          status : Available (string)
     RTS-3257408 : (dict)
          description : Shutter (string)
          devices : (list)
               Item : 256247804 (integer)
          frameData : (dict)
               header : (dict)
                    floorNoise : -91 (string)
                    infoType : 3 (string)
                    protocol : 9 (string)
                    protocolMeaning : RTS (string)
                    rfLevel : -63 (string)
                    rfQuality : 7 (string)
               infos : (dict)
                    qualifier : 7 (string)
                    qualifierMeaning : (dict)
                         flags : (list)
                              Item : Up/On (string)
                    subTypeMeaning : Shutter (string)
          status : Active (string)
Thu Aug 09, 2018 2:34 pm
koburg offline
Device test
WebServer                       request to turn off device "new device 2" from 127.0.0.1
   RFPlayer Error                  Error in plugin execution ExecuteAction:
  File "plugin.py", line 314, in actionControlSensor
KeyError: (u'RTS-3257408',)
Thu Aug 09, 2018 2:39 pm
Hmm. I need a device dump. Run this Python script in the scripting shell or in an Action Group:
indigo.server.log(unicode(indigo.devices[256247804]))
Please confirm that the number in the script is the Indigo DeviceId of your "new device 2".
Fri Aug 10, 2018 4:03 am
koburg offline
   Script                          address : RTS-3257408
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
deviceTypeId : discoveredDevice
displayStateId : sensorValue
displayStateImageSel : SensorOff
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 0
     com.flyingdiver.indigoplugin.rfplayer : (dict)
          AllowOnStateChange : false (bool)
          IsDiscoverable : true (bool)
          SupportsOnState : true (bool)
          SupportsSensorValue : true (bool)
          address : RTS-3257408 (string)
          devVersCount : 2 (integer)
lastChanged : 2000-01-01 00:00:00
lastSuccessfulComm : 2000-01-01 00:00:00
model : Discovered Device
name : new device 2
onState : False
ownerProps : com.flyingdiver.indigoplugin.rfplayer : (dict)
pluginId : com.flyingdiver.indigoplugin.rfplayer
protocol : Plugin
remoteDisplay : True
sensorValue : 0.0
states : States : (dict)
     faultCode :  (string)
     sensorValue : 0 (integer)
subModel :
supportsAllOff : False
supportsOnState : True
supportsSensorValue : True
supportsStatusRequest : False
version : None
Fri Aug 10, 2018 8:56 am
Fri Aug 10, 2018 12:15 pm
koburg offline
WebServer                       request to turn off device "RTS-3257408" from 127.0.0.1
   WebServer                       request to turn off device "RTS-3322944" from 127.0.0.1
now there is no error but nothing happen with the blinds
Fri Aug 10, 2018 12:33 pm
Don't use a control page to test. Use the Indigo client.
And turn on debug level logging for testing.
Sat Aug 11, 2018 1:22 am
koburg offline
here you are 8)
RFPlayer Debug                  actionControlSensor: sensor = <protocols.rts.RTS object at 0x10a8d59d0>, player = <RFPlayer.RFPlayer object at 0x10a8d5890>, action = configured : True
delayAmount : 900
description : turn on device
deviceId : 240007113
replaceExisting : True
sensorAction : TurnOn
textToSpeak :
   RFPlayer Debug                  RTS turnOn command 'on rts 3257408 qualifier 0' to RF USB
   RFPlayer Debug                  json decode failure:
ZIA--
error request number=0
Syntax error: on rts 3257408 qualifier 0
Sat Aug 11, 2018 7:20 am
Try this one: https://github.com/FlyingDiver/Indigo-R ... /tag/7.1.4
At this point, I think the plugin is processing the commands properly. Now it's just a matter of getting the syntax of the command strings sent to the RFPlayer correct.
Wed Aug 15, 2018 7:56 am
koburg offline
You got Success ! :D
now they kan go up and down thru the on off button alle shutters that are discovered do this now!
now I hope you can make the MY/Stop function work which is a memory spot you can set for the blinds.
and also "dimmer" function which means go xx % for the blinds.
I know the rfplayer support the functions I tested it from the RFconfig and the log in the RFconfig also knows "MY/Stop"
the MY button is also used as stop command.
   RFPlayer Debug                  actionControlSensor: sensor = <protocols.rts.RTS object at 0x113dad7d0>, player = <RFPlayer.RFPlayer object at 0x113dad850>, action = configured : True
delayAmount : 900
deviceId : 1636726277
textToSpeak :
   RFPlayer Debug                  RTS turnOn command 'on rts ID 3191872 qualifier 0' to RF USB
delayAmount : 900
description : turn off device
sensorAction : TurnOff
textToSpeak :
   RFPlayer Debug                  RTS turnOff command 'off rts ID 3191872 qualifier 0' to RF USB
delayAmount : 900
textToSpeak :
Wed Aug 15, 2018 10:05 am
Can you post the log from RFconfig? Hopefully it shows the syntax of the commands sent to the RFPlayer.
Wed Aug 15, 2018 12:19 pm
Have you tried the "Send My" command? The syntax is the same as the on/off commands, and I think I had another user already test it.
It's the in the "RFPlayer Actions" group.
