New plugin - RFPlayer by ZiBlue
Tue Dec 26, 2017 5:49 pm
Colly offline
Re: New plugin - RFPlayer by ZiBlue
Any use?
   RFPlayer Threaddebug            RFPlayer: Frame Received:
    "frame": {
        "header": {
            "cluster": "0",
            "dataFlag": "0",
            "floorNoise": "-105",
            "frameType": "0",
            "frequency": "433920",
            "infoType": "0",
            "protocol": "0",
            "protocolMeaning": "-",
            "rfLevel": "-99",
            "rfQuality": "2"
        "infos": {
            "id": "0",
            "idMeaning": "A1",
            "subType": "0",
            "subTypeMeaning": "OFF"
   RFPlayer Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 92, in runConcurrentThread
KeyError: u'0'
   RFPlayer Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tue Dec 26, 2017 5:53 pm
Yeah, that helps a lot. The problem is that the "protocol" value of "0" isn't valid according to my docs from ZiBlue. Do you have any idea what device is generating that message?
I should have done a better job of trapping invalid protocol values. I'll see if I can get a quick fix out to at least ignore that error.
Tue Dec 26, 2017 5:59 pm
Colly offline
I've only added some window blinds to Indigo so far.
Not really.
No panic on the update everything seems to be working OK despite the errors.
Sat Jan 20, 2018 3:15 pm
petematheson offline
Hi Guys,
Newbie question :) I just bought my first Somfy blind. I have the RFPlayer plugged in and the plugin installed, I've added the RFPlayer Dongle into Indigo.
How do I add the actual blind so I can control up / down etc.. ?
Cheers!
