Somfy/RTS control
Sat Jan 20, 2018 3:22 pm
FlyingDiver online
Re: New plugin - RFPlayer by ZiBlue
When you use the remote that came with the blinds, does the RFPLayer detect that? Turn on Verbose debugging and use the remote and see if anything is detected.
If not, then you'll have to use the Java app to capture the commands and assign them to Parrot commands.
Wed Jan 24, 2018 4:21 pm
petematheson offline
Yep it does pick up the button presses. How do I interpret these to get commands set up in the Indigo plugin?
    RFPlayer Threaddebug            RFPlayer Dongle: Frame Received:
    "frame": {
        "header": {
            "cluster": "0",
            "dataFlag": "0",
            "floorNoise": "-99",
            "frameType": "0",
            "frequency": "433920",
            "infoType": "3",
            "protocol": "9",
            "protocolMeaning": "RTS",
            "rfLevel": "-87",
            "rfQuality": "3"
        "infos": {
            "id": "16081238",
            "qualifier": "7",
            "qualifierMeaning": {
                "flags": [
                    "Up/On"
            "subType": "0",
            "subTypeMeaning": "Shutter"
   RFPlayer Threaddebug            RFPlayer Dongle: Sensor frame received: RTS-16081238
    "frame": {
        "header": {
            "cluster": "0",
            "dataFlag": "0",
            "frameType": "0",
            "infoType": "3",
            "protocol": "9",
            "rfLevel": "-86",
            "rfQuality": "3"
        "infos": {
            "id": "16081238",
            "qualifier": "1",
                "flags": [
                    "Down/Off"
            "subType": "0",
    "frame": {
        "header": {
            "cluster": "0",
            "dataFlag": "0",
            "frameType": "0",
            "infoType": "3",
            "protocol": "9",
            "rfLevel": "-87",
            "rfQuality": "3"
        "infos": {
            "id": "16081238",
            "qualifier": "7",
                "flags": [
                    "Up/On"
            "subType": "0",
Wed Jan 24, 2018 4:23 pm
FlyingDiver online
That was a down/off command? Can you capture an up command as well? And any other commands your remote can do? I'll add them to the next release of the plugin.
joe
Wed Jan 24, 2018 5:21 pm
joe
Edited the post shortly after posting.
It has a down and an up command in there now for the Somfy RTS.
I’ll see if I can capture the MY button (favourite position).
It’s a 3 button remote so that’s essentially all there is to it
Thu Mar 15, 2018 8:03 am
koburg offline
new Somfy device auto discovered
I got this from my log
i have rts Somfy blinds
RTS-3388480 : (dict)
description : Shutter (string)
devices : (list)
Item : 513280744 (integer)
frameData : (dict)
header : (dict)
cluster : 0 (string)
dataFlag : 0 (string)
floorNoise : -87 (string)
frameType : 0 (string)
frequency : 433420 (string)
infoType : 3 (string)
protocol : 9 (string)
protocolMeaning : RTS (string)
rfLevel : -35 (string)
rfQuality : 10 (string)
infos : (dict)
qualifier : 7 (string)
qualifierMeaning : (dict)
flags : (list)
Item : Up/On (string)
subType : 0 (string)
subTypeMeaning : Shutter (string)
playerId : 1580545739 (integer)
status : Active (string)
Sat Jul 28, 2018 10:25 am
koburg offline
Re: Pre-release version 7.1.0
Hi
Just want to ask if you plan to update so it can be used with roller shutters ?
- Allan
Sat Jul 28, 2018 11:37 am
norcoscia offline
What type of rollers do you have - if somfy there is a plug in or you can control with a script if you have their bridge.
_______
Norm
Sat Jul 28, 2018 11:43 am
FlyingDiver online
koburg wrote:
Hi
- Allan
I expect it can now, at least using Parrot capture and transmit. For more native control I need to see what a control transmission looks like. If the unit detects the control message and logs it then I can make a native device for it.
Sat Jul 28, 2018 4:20 pm
koburg offline
It is Somfy what plugin. I have rfplayer plugin.
Sat Jul 28, 2018 4:23 pm
koburg offline
FlyingDiver wrote:
koburg wrote:
Hi
- Allan
The Parrot function is not working with somfy i have used maybe 20 hours try to make it work no luck. And the support from rfplayer Them self is very very bad they have never repliet on any of My questions. I Will be happy to supply all data needed for make it work.
Sat Jul 28, 2018 4:28 pm
FlyingDiver online
Somehow I totally missed that post from March with the Somfy device info. Can you capture that again and this time post it here with CODE tags. The other post is missing most of the JSON punctuation, which makes it harder to decipher. Or zip up the log and post it to a new GitHub issue: https://github.com/FlyingDiver/Indigo-RFPlayer/issues
Sat Jul 28, 2018 4:47 pm
norcoscia offline
The PlugIn is called Somfy Manager (it is in beta but works great). It was written by user howartp. It will require the Somfy Mylink bridge to work. The bridge handles the translation from IP to Somfy RF. If you want any more info just let me know... happy to help.
_______
Norm
Sat Jul 28, 2018 6:00 pm
FlyingDiver online
Somfy/RTS control
Consolidating the threads about Somfy/RTS control using RFPlayer.
Sat Jul 28, 2018 6:04 pm
FlyingDiver online
Re: Somfy/RTS control
Sorry everyone - looks like I dropped the ball on this one. I'll start investigating this tomorrow.
Sat Jul 28, 2018 7:48 pm
pbaperez offline
I ended up using the Somfy WT series with an insteon micro on/fff control module.
You do sacrifice the ability to pasuse the sun screen.
It's either all the way up or down to your set limit. The sun hits the same spot so it works great for me.
Sent from my Pixel 2 XL using Tapatalk
