Using the Sensor Logger with SES 303
Wed Oct 14, 2020 3:32 am
IndigoSam offline
Hi Peter,
I'm trying out the Sensor Logger plugin to retrieve temperature values from an Horstmann/Secure SES 303, which allows up to 4 additional temperature probes to be attached.
As per this thread https://forums.indigodomo.com/viewtopic.php?f=58&t=15529&start=0 I installed the plugin to try and read them.
However, I get a few errors.
   Z-Wave Sensor Logger Error      Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 318, in zwaveCommandReceived
NameError: global name 'dechumid' is not defined
That's every 30 minutes, and
   Error                           XML Parse Error: not well-formed (invalid token)
   Error                           On character 435 of line number 1.
every 5.
Any ideas?
Sam.
Wed Oct 14, 2020 6:17 am
Re: Using the Sensor Logger with SES 303
Hi Sam,
Just checking I realise that I am running an old version of the plugin (V1.0.18). I have uploaded it to the "interweb" and will PM you the link.
As it is working for me, it should hopefully work for you. :)
Wed Oct 14, 2020 3:07 pm
IndigoSam offline
Hi Jon,
That all now seems to be working, with the older version. Thanks again.
Sam.
Thu Oct 15, 2020 12:31 am
Thanks Jon
