Indigo controllable power strip
Tue Oct 10, 2017 10:06 am
Re: Indigo controllable power strip
Can you put a ZWave Watcher on the device and tell me what outgoing request is for the main device and the endpoints - the command lengths (on my Greenwave) don’t match the Zwave docs so I don’t know exactly what’s being sent.
Tue Oct 10, 2017 10:19 am
Is this what you wanted? I did the plugin request all, then the native UI update for the base strip and one outlet.
Oct 10, 2017, 12:17:29 PM
   Action Group                    Power Strip Testing
   Z-Wave Power Logger Debug       Node: 15
   Z-Wave Power Logger             Requesting power level 1 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 01 32 01 0A 25]
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0F 00 13 0F 08 60 0D 01 01 32 01 0A 25 25 0F BF (True)
   Z-Wave Power Logger             Requesting power level 2 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 02 32 01 0A 25]
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0F 00 13 0F 08 60 0D 01 02 32 01 0A 25 25 10 A3 (True)
   Z-Wave Power Logger             Requesting power level 3 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 03 32 01 0A 25]
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0F 00 13 0F 08 60 0D 01 03 32 01 0A 25 25 11 A3 (True)
   Z-Wave Power Logger             Requesting power level 4 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 04 32 01 0A 25]
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0F 00 13 0F 08 60 0D 01 04 32 01 0A 25 25 12 A7 (True)
   Z-Wave Power Logger             Requesting power level 5 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 05 32 01 0A 25]
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0F 00 13 0F 08 60 0D 01 05 32 01 0A 25 25 13 A7 (True)
   Z-Wave Power Logger             Requesting power level 6 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 06 32 01 0A 25]
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0F 00 13 0F 08 60 0D 01 06 32 01 0A 25 25 14 A3 (True)
Oct 10, 2017, 12:18:03 PM
   Z-Wave                          sent "AV Power Strip" energy status request
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0A 00 13 0F 03 32 01 00 25 15 E9 (True)
   Z-Wave                          received "AV Power Strip" energy total to 0.529 kWh
   Z-Wave Watcher Debug            Raw command received (Node 15): 01 14 00 04 00 0F 0E 32 02 21 64 00 00 02 11 38 9D 00 00 01 96 BA
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0A 00 13 0F 03 32 01 10 25 16 FA (True)
   Z-Wave                          received "AV Power Strip" power load to 30.964 W
   Z-Wave Watcher Debug            Raw command received (Node 15): 01 0E 00 04 00 0F 08 32 02 21 74 00 00 78 F4 1B
   Z-Wave Power Logger Debug       -----
   Z-Wave Power Logger Debug       Energy report received:
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 78 F4 1B
   Z-Wave Power Logger Debug       Endpoint:  Total
   Z-Wave Power Logger Debug       State:     totalpowerrep
   Z-Wave Power Logger Debug       Total Power Reported: 30964 (30.964) watts
Oct 10, 2017, 12:18:26 PM
   Z-Wave                          sent "Tablo Switched Outlet" energy status request
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0E 00 13 0F 07 60 0D 01 04 32 01 00 25 17 83 (True)
   Z-Wave                          received "Tablo Switched Outlet" energy total to 0.148 kWh
   Z-Wave Watcher Debug            Raw command received (Node 15): 01 14 00 04 00 0F 0E 32 02 21 64 00 00 00 94 38 7B 00 00 00 71 FF
   Z-Wave Watcher Debug            Raw command received (Node 15): 01 18 00 04 00 0F 12 60 0D 04 01 32 02 21 64 00 00 00 94 38 7B 00 00 00 71 45
   Z-Wave Watcher Debug            Raw command sent (Node 15): 01 0E 00 13 0F 07 60 0D 01 04 32 01 10 25 18 9C (True)
   Z-Wave                          received "Tablo Switched Outlet" power load to 8.512 W
   Z-Wave Watcher Debug            Raw command received (Node 15): 01 0E 00 04 00 0F 08 32 02 21 74 00 00 21 40 FF
   Z-Wave Watcher Debug            Raw command received (Node 15): 01 12 00 04 00 0F 0C 60 0D 04 01 32 02 21 74 00 00 21 40 86
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 21 40 FF
   Z-Wave Power Logger Debug       Total Power Reported: 8512 (8.512) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 0F 0C 60 0D 04 01 32 02 21 74 00 00 21 40 86
   Z-Wave Power Logger Debug       Endpoint:  4
   Z-Wave Power Logger Debug       Socket:    4
   Z-Wave Power Logger Debug       State:     socket4power
   Z-Wave Power Logger Debug       Power: 8512 (8.512) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 17.978 watts
Tue Oct 10, 2017 10:29 am
Ah whoops, I've forgotten to de-hex one of the hex values.
I'll sort in a moment.
Tue Oct 10, 2017 4:40 pm
Sorry, I broke my PC this evening so had to sort that out - couldn't get at my windows server, which contains my plugins for a start!
Now fixed, and also fixed problem accessing mac's folders from my PC which was hindering plugin development.
I'm contacting Matt off forum because I think there's a bug (or more probably, a not-yet-implemented situation) in how Indigo is handling sending commands to endpoints, so it will be a day or so before I can post further.
Peter
Tue Oct 10, 2017 5:03 pm
v1.0.9 published.
http://www.oakworthmethodists.org/_Indi ... Plugin.zip
Both Actions should now work for requesting levels (total and individual).
Peter
Tue Oct 10, 2017 5:08 pm
Looks correct to me now.
Tue Oct 10, 2017 5:11 pm
Hooray!
Ross, when your new one comes, can you test whether the totalrep gets updated when individual socket reports arrive, or only if you request it?
What are both your thoughts - should I just keep one total state and calculate it, or never calculate it and only use reported values?
Tue Oct 10, 2017 5:24 pm
srkinard offline
New one should arrive tomorrow so I'll test it if work doesn't get in the way...
The strip natively provides the total consumption so I wouldn't stress too much having the plugin calculate it. Just having access to each socket's current and cumulative numbers is perfect for me, since I want to chart two different ways.
On my servers they barely change so I just monitor how much they contribute to the punch in the kidneys that my power bill brings.
On the new strip, it will be connected to some devices that power on and off when I'm home, and others that are standby/on states so I'm going to chart usage graphs showing how much they contribute to energy consumption by day, week, month and year.
If we get the current draw in watts and the total-since-last-reset in kWh for each socket...perfect.
Will update tomorrow when I get a chance to add it in and use it.
Ross
Wed Oct 11, 2017 6:06 pm
srkinard offline
Peter-
When I try to install the 1.0.9 plugin it gives an error:
There is a problem with this plugin. If this error persists, contact the plugin developer.
log has:
 Error                           plugin "" is missing file: Contents/Info.plist
Just added the new strip and about to start testing it.
Ross
Wed Oct 11, 2017 6:08 pm
Re-download it. I just did and the contents are fine.
Wed Oct 11, 2017 6:15 pm
srkinard offline
Just did and get the same error...
Wed Oct 11, 2017 6:17 pm
Did you unpack it manually and look in the package? What's there? I get:
Shamu:Downloads jkeenan$ ls -laR ZwavePowerLevel.indigoPlugin
total 0
drwxr-xr-x@ 3 jkeenan  staff   96 Oct  8 18:25 .
drwx------+ 9 jkeenan  staff  288 Oct 11 20:17 ..
drwxr-xr-x@ 4 jkeenan  staff  128 Oct  8 18:25 Contents
ZwavePowerLevel.indigoPlugin/Contents:
total 8
drwxr-xr-x@ 4 jkeenan  staff  128 Oct  8 18:25 .
drwxr-xr-x@ 3 jkeenan  staff   96 Oct  8 18:25 ..
-rwxr-xr-x@ 1 jkeenan  staff  730 Oct 10 20:56 Info.plist
drwxr-xr-x@ 6 jkeenan  staff  192 Oct  9 00:15 Server Plugin
ZwavePowerLevel.indigoPlugin/Contents/Server Plugin:
total 48
drwxr-xr-x@ 6 jkeenan  staff    192 Oct  9 00:15 .
drwxr-xr-x@ 4 jkeenan  staff    128 Oct  8 18:25 ..
-rwxr-xr-x@ 1 jkeenan  staff    511 Oct  9 22:28 Actions.xml
-rwxr-xr-x@ 1 jkeenan  staff   2702 Oct  9 20:21 Devices.xml
-rwxr-xr-x@ 1 jkeenan  staff    148 Jul 21  2016 PluginConfig.xml
-rwxr-xr-x@ 1 jkeenan  staff  11056 Oct 10 23:59 plugin.py
Wed Oct 11, 2017 6:20 pm
srkinard offline
Looks ok, but definitely won't upgrade...will reboot the Indigo server in a few
indigo:Desktop indigo$ ls -lahR ZwavePowerLevel.indigoPlugin
total 0
drwxr-xr-x@  3 indigo  staff    96B Oct  8 18:25 .
drwx------+ 13 indigo  staff   416B Oct 11 19:17 ..
drwxr-xr-x   4 indigo  staff   128B Oct 11 19:17 Contents
total 8
drwxr-xr-x  4 indigo  staff   128B Oct 11 19:17 .
drwxr-xr-x@ 3 indigo  staff    96B Oct  8 18:25 ..
-rwxr-xr-x  1 indigo  staff   730B Oct 10 20:56 Info.plist
drwxr-xr-x  6 indigo  staff   192B Oct 11 19:17 Server Plugin
total 48
drwxr-xr-x  6 indigo  staff   192B Oct 11 19:17 .
drwxr-xr-x  4 indigo  staff   128B Oct 11 19:17 ..
-rwxr-xr-x  1 indigo  staff   511B Oct  9 22:28 Actions.xml
-rwxr-xr-x  1 indigo  staff   2.6K Oct  9 20:21 Devices.xml
-rwxr-xr-x  1 indigo  staff   148B Jul 21  2016 PluginConfig.xml
-rwxr-xr-x  1 indigo  staff    11K Oct 10 23:59 plugin.py
Weird....
Wed Oct 11, 2017 6:47 pm
srkinard offline
So...new strip in place...plugged a 40w incandescent bulb in it and it reports about 41w used...
Physical sockets 1-4 line up with Socket1-4
Cannot get physical sockets 5-6 to report anything...
All the following are with the light plugged into Socket5
Log when I tell Indigo to update all 5 points (All Outlets & 1-4)
   Z-Wave                          sent "New Power Strip" energy status request
   Z-Wave                          received "New Power Strip" power load to 41.473 W
   Z-Wave                          sent "078 - Outlet 1" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 4E 08 32 02 21 74 00 00 A2 01 75
   Z-Wave Power Logger Debug       Total Power Reported: 41473 (41.473) watts
   Z-Wave                          sent "078 - Outlet 2" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 4E 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Power Logger Debug       Total Power Reported: 0 (0.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 4E 0C 60 0D 01 01 32 02 21 74 00 00 00 00 A3
   Z-Wave Power Logger Debug       Endpoint:  1
   Z-Wave Power Logger Debug       Socket:    1
   Z-Wave Power Logger Debug       State:     socket1power
   Z-Wave Power Logger Debug       Power: 0 (0.0) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 0.0 watts
   Z-Wave                          sent "078 - Outlet 3" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 4E 0C 60 0D 02 01 32 02 21 74 00 00 00 00 A0
   Z-Wave Power Logger Debug       Endpoint:  2
   Z-Wave Power Logger Debug       Socket:    2
   Z-Wave Power Logger Debug       State:     socket2power
   Z-Wave                          sent "078 - Outlet 4" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 4E 0C 60 0D 03 01 32 02 21 74 00 00 00 00 A1
   Z-Wave Power Logger Debug       Endpoint:  3
   Z-Wave Power Logger Debug       Socket:    3
   Z-Wave Power Logger Debug       State:     socket3power
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 4E 0C 60 0D 04 01 32 02 21 74 00 00 00 00 A6
   Schedule                        Energy Refresh
   Action Group                    Update Energy Use
Log when I execute the Power Logger action to refresh all:
   Action Group                    Update new strip all
   Z-Wave Power Logger Debug       Node: 78
   Z-Wave Power Logger             Requesting all power levels for node 78
   Z-Wave                          sent "New Power Strip" raw command [32 01 0A 19]
All zeros after this since 5 isn't reporting in so the calculated total is 0.
Log when I execute the Power Logger refresh individual sockets
   Action Group                    Update new strip individual
   Z-Wave Power Logger             Requesting power level 1 for node 78
   Z-Wave                          sent "New Power Strip" raw command [60 0D 01 01 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 2 for node 78
   Z-Wave                          sent "New Power Strip" raw command [60 0D 01 02 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 3 for node 78
   Z-Wave                          sent "New Power Strip" raw command [60 0D 01 03 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 4 for node 78
   Z-Wave                          sent "New Power Strip" raw command [60 0D 01 04 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 5 for node 78
   Z-Wave                          sent "New Power Strip" raw command [60 0D 01 05 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 6 for node 78
   Z-Wave                          sent "New Power Strip" raw command [60 0D 01 06 32 01 0A 25]
Any ideas?
Wed Oct 11, 2017 11:05 pm
You’re not on latest version of plugin there.
Latest version requests 8 sockets and doesn’t send [60 0D...] to the devices.
