Indigo controllable power strip
Sun Oct 08, 2017 9:46 am
(Note for anyone reading in future - this thread is split off from a thread in the main forums before I wrote this plugin)
If I can see what it's doing with those 4 I should be able to pull all 6; I've just never done multiple endpoints before so I need a bit of guidance from the log.
Should be a simple job as far as I can think.
Peter
Sun Oct 08, 2017 10:03 am
srkinard offline
Re: Indigo controllable power strip
Peter-
Here's a log from a n Energy Status Refresh on 5 points on the strip...the Main Strip power, and Outlets 1-4
   Action Group                    Refresh Power Strip Energy
   Z-Wave                          sent "Computer Room Strip - All Outlets" energy status request
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0A 00 13 49 03 32 01 00 25 CE 74 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 13 97 06 00 2B 00 13 97 06 F6
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0A 00 13 49 03 32 01 10 25 CF 65 (True)
   Z-Wave                          received "Computer Room Strip - All Outlets" power load to 846.945 W
   Z-Wave                          sent "Computer Room Strip - Outlet 1 - ESXi 02" energy status request
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 0C EC 61 50
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 01 32 01 00 25 D0 07 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 01 63 9C 00 2C 00 01 63 9C FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 01 01 32 02 21 64 00 01 63 9C 00 2C 00 01 63 9C 8C
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 01 32 01 10 25 D1 16 (True)
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" power load to 60.588 W
   Z-Wave                          sent "Computer Room Strip - Outlet 2 - ESXi 03" energy status request
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 00 EC AC FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 12 00 04 00 49 0C 60 0D 01 01 32 02 21 74 00 00 EC AC E4
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 02 32 01 00 25 D2 06 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 00 00 00 00 2C 00 00 00 00 FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 02 01 32 02 21 64 00 00 00 00 00 2C 00 00 00 00 8F
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 02 32 01 10 25 D3 17 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 12 00 04 00 49 0C 60 0D 02 01 32 02 21 74 00 00 00 00 A7
   Z-Wave                          sent "Computer Room Strip - Outlet 3 - Mac Pro" energy status request
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 03 32 01 00 25 D4 01 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 04 A8 48 00 2D 00 04 A8 48 FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 03 01 32 02 21 64 00 04 A8 48 00 2D 00 04 A8 48 8F
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 03 32 01 10 25 D5 10 (True)
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" power load to 196.658 W
   Z-Wave                          sent "Computer Room Strip - Outlet 4 - 24 bay RAID" energy status request
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 03 00 32 FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 12 00 04 00 49 0C 60 0D 03 01 32 02 21 74 00 03 00 32 97
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 04 32 01 00 25 D6 04 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 04 6E DC 00 2E 00 04 6E DC FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 04 01 32 02 21 64 00 04 6E DC 00 2E 00 04 6E DC 8B
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0E 00 13 49 07 60 0D 01 04 32 01 10 25 D7 15 (True)
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" power load to 189.972 W
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 02 E6 14 FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 12 00 04 00 49 0C 60 0D 04 01 32 02 21 74 00 02 E6 14 51
Ross
Sun Oct 08, 2017 11:48 am
Ok, great, I've decoded all that lot and believe I understand it.
Can you list what's plugged into the 6 sockets, 1-6?
Am I right in thinking ESX2 is plugged into socket 1, and ESX3 is plugged into socket 2, both of which are unswitchable from Indigo?
Peter
Sun Oct 08, 2017 12:16 pm
srkinard offline
On the strip, outlets #1 & 2 are the unswitchable ones, but they do report energy use. Outlets 3-6 are the switchable ones.
Physical Outlet 1 has a Cisco Catalyst 2960G plugged into it. It is not listed in Indigo since it is not controllable
Physical Outlet 2 is EMPTY
Physical Outlet 3 is ESXi 02 and is in Indigo as Outlet 1
Physical Outlet 4 is ESXi 03 and is in Indigo as Outlet 2
Physical Outlet 5 is Mac Pro and is in Indigo as Outlet 3
Physical Outlet 6 is 24-bay RAID and is in Indigo as Outlet 4
Where it is off is energy reporting...in Indigo you see:
Outlet 1 - ESXi 02 reporting 60.588 W which is actually the power consumed by Physical Outlet #1 - Cisco 2960G
Outlet 2- ESXi 03 reporting 0 W which is actually the EMPTY Physical Outlet #2
Outlet 3 - Mac Pro reporting 196.658 W which is actually the power consumed by Physical Outlet #3 - ESXi 02
Outlet 4 - Mac Pro reporting 189.972 W which is actually the power consumed by Physical Outlet #4 - ESXi 03
Physical outlets 5-6 energy is the missing info...it's a matter of Energy reporting 7 items...1 total and Physical Outlets 1-6, but indigo only has 5 devices...master switch and physical outlets 3-6 that ID as 1-4.
Here it is in a chart type form:
Phsyical   Indigo      Energy
Master     All Outlets Total Energy
Outlet 1   <none>      Outlet 1
Outlet 2   <none>      Outlet 2
Outlet 3   Outlet 1    Outlet 3
Outlet 4   Outlet 2    Outlet 4
Outlet 5   Outlet 3    Outlet 5 <not in Indigo>
Outlet 6   Outlet 4    Outlet 6 <not in Indigo>
Does that help?
Ross
Sun Oct 08, 2017 1:42 pm
Ah right.
Yeah, I think I confused myself but I do know what's happening.
Can you try sending a raw zwave command (Interfaces > ZWave > Send raw command):
0x60 0x0D 0x01 0x05 0x32 0x01 0x00 0x25 (they're all zero's)
then after a few seconds
0x60 0x0D 0x01 0x05 0x32 0x01 0x10 0x25
I think that should be requesting the power consumption in kWh and W of endpoint 5 (which is socket 1).
You should get back:
01 18 00 04 00 49 0C 60 0D 01 05 32 02 21 64 ## ## ## ## ## ## ## ## ## ## ## (this is the kWh used since last reset, time since you last asked, and previous kWh value)
01 12 00 04 00 49 0C 60 0D 01 05 32 02 21 74 ## ## ## ## ## (this is the current power in w)
Peter
Sun Oct 08, 2017 1:44 pm
srkinard offline
Here's the log output:
   Z-Wave                          sent "Computer Room Strip - All Outlets" raw command [60 0D 01 05 32 01 00 25]
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0F 00 13 49 08 60 0D 01 05 32 01 00 25 25 EA 12 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 05 6C 12 00 A1 00 05 6C 0B FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 05 01 32 02 21 64 00 05 6C 12 00 A1 00 05 6C 0B 1C
Oct 8, 2017 at 2:44:08 PM
   Z-Wave                          sent "Computer Room Strip - All Outlets" raw command [60 0D 01 05 32 01 10 25]
   Z-Wave Watcher Debug            Raw command sent (Node 73): 01 0F 00 13 49 08 60 0D 01 05 32 01 10 25 25 EB 03 (True)
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 03 59 D1 FF
   Z-Wave Watcher Debug            Raw command received (Node 73): 01 12 00 04 00 49 0C 60 0D 05 01 32 02 21 74 00 03 59 D1 2B
Sun Oct 08, 2017 1:50 pm
Excellent.
That's 219.601w from socket 1 (endpoint 5)
I'll knock it up into a Power Logging plugin for you.
Peter
Sun Oct 08, 2017 1:59 pm
srkinard offline
Cool...a plugin that could pull the 6 outlets consumption and the totals for the strip would rock...I mainly got it for power monitoring since none of those devices are ever switched off.
Ross
Sun Oct 08, 2017 2:56 pm
Peter rocks. 8)
Sun Oct 08, 2017 5:12 pm
Right, give this plugin a try.
It provides for up to 8 sockets per power strip, but will only populate the ones that it receives info for.
Create a ZWave Power Logger device and point it at one of your Aeon power strip devices (doesn't matter which socket device, it's only finding out the node ID from it).
Then watch the states populate as it receives energy notifications.
There's two Actions which request Total and Individual usage - not sure if Total works or not, but it doesn't matter if it doesn't because whenever individual ones are received it just recalculates the total anyway!
I've been testing this against my Greenwave power strip which isn't the most reliable as it refuses to send updates if it hasn't changed since last time it sent you one. (That's "by design")
Peter
Sun Oct 08, 2017 5:23 pm
srkinard offline
Ok...so I installed and created the device...here's what the log shows:
   Z-Wave                          received "Computer Room Strip - All Outlets" energy total to 1290.002 kWh
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 13 AF 12 00 7F 00 13 AE E7 56
   Z-Wave Power Logger Debug       -----
   Z-Wave Power Logger Debug       Energy report received:
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 13 AF 12 00 7F 00 13 AE E7 56
   Z-Wave Power Logger Debug       Node:      73
   Z-Wave Power Logger Debug       Total:     33
   Z-Wave Power Logger Debug       Format:    64
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 0E 00 04 00 49 08 32 02 21 74 00 05 8B 75 FF
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 05 8B 75 FF
   Z-Wave Power Logger Debug       Format:    74
   Z-Wave Power Logger Debug       Total Power: 363381 (36338.0) watts
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 12 00 04 00 49 0C 60 0D 05 00 32 02 21 74 00 05 8B 75 5A
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 05 00 32 02 21 74 00 05 8B 75 5A
   Z-Wave Power Logger Debug       Endpoint:  5
   Z-Wave Power Logger Debug       Socket:    1
   Z-Wave Power Logger Debug       Power: 363381 (36338.0) watts
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" energy total to 91.477 kWh
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 01 65 55 00 7F 00 01 65 52 FF
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 01 65 55 00 7F 00 01 65 52 FF
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 01 00 32 02 21 64 00 01 65 55 00 7F 00 01 65 52 D9
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 01 00 32 02 21 64 00 01 65 55 00 7F 00 01 65 52 D9
   Z-Wave Power Logger Debug       Endpoint:  1
   Z-Wave Power Logger Debug       Socket:    3
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 00 00 00 00 7E 00 00 00 00 FF
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 00 00 00 00 7E 00 00 00 00 FF
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 02 00 32 02 21 64 00 00 00 00 00 7E 00 00 00 00 DC
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 02 00 32 02 21 64 00 00 00 00 00 7E 00 00 00 00 DC
   Z-Wave Power Logger Debug       Endpoint:  2
   Z-Wave Power Logger Debug       Socket:    4
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" energy total to 306.687 kWh
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 04 AD FF 00 7E 00 04 AD F5 FF
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 04 AD FF 00 7E 00 04 AD F5 FF
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 03 00 32 02 21 64 00 04 AD FF 00 7E 00 04 AD F5 D7
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 03 00 32 02 21 64 00 04 AD FF 00 7E 00 04 AD F5 D7
   Z-Wave Power Logger Debug       Endpoint:  3
   Z-Wave Power Logger Debug       Socket:    5
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" energy total to 291.913 kWh
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 04 74 49 00 7D 00 04 74 40 FF
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 04 74 49 00 7D 00 04 74 40 FF
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 04 00 32 02 21 64 00 04 74 49 00 7D 00 04 74 40 D0
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 04 00 32 02 21 64 00 04 74 49 00 7D 00 04 74 40 D0
   Z-Wave Power Logger Debug       Endpoint:  4
   Z-Wave Power Logger Debug       Socket:    6
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 05 6F 42 00 F0 00 05 6F 32 FF
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 05 6F 42 00 F0 00 05 6F 32 FF
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 05 00 32 02 21 64 00 05 6F 42 00 F0 00 05 6F 32 25
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 05 00 32 02 21 64 00 05 6F 42 00 F0 00 05 6F 32 25
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 14 00 04 00 49 0E 32 02 21 64 00 03 B8 33 00 F0 00 03 B8 29 FF
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 03 B8 33 00 F0 00 03 B8 29 FF
   Z-Wave Power Logger Debug       Raw command received (Node 73): 01 18 00 04 00 49 12 60 0D 06 00 32 02 21 64 00 03 B8 33 00 F0 00 03 B8 29 4C
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 06 00 32 02 21 64 00 03 B8 33 00 F0 00 03 B8 29 4C
   Z-Wave Power Logger Debug       Endpoint:  6
   Z-Wave Power Logger Debug       Socket:    2
Adding a screenshot of the power readings it has...shows #4 as zero but it should be pulling 190w-200w since it's a dual-CPU Precision like outlet #3
Screen Shot 2017-10-08 at 6.20.46 PM.png (134.13 KiB) Viewed 3827 times
Sun Oct 08, 2017 5:37 pm
That log doesn't tie up with that screenshot...
You can ignore all the "Format: 64" sections as that's the kWh energy reports.
I suspect in the time it took you to copy/paste the log and prepare the screenshot, you received some more "Format: 74" sections which are the wattage energy reports.
If you still haven't received socket 4 data I need to see what the format 74's show.
I've just uploaded 1.0.1 which strips some of the logging out (and also allows you to turn on/off debugging in plugin config!)
Eventually I will decode the format bytes in the plugin - I can decode on paper but I've not coded the decoding of it yet - then filter out the logs to only wattage or kWh depending what users choose - I'll add more config to the device when I get to that.
Peter
Sun Oct 08, 2017 6:18 pm
srkinard offline
So I'm a little confused...I took a screenshot right after the refresh interval I have on the power strip and matched up the values from your plugin...
Still only 4 of 6 sockets show non-zero numbers when it should be 5.
Total doesn't have a match in the log...and socket3 reads the low number that should match socket1
socket2 should be zero, socket3 should be around 200w as should socket4 based on the hardware powered by it.
see attachment
Thanks Ross
Screen Shot 2017-10-08 at 7.05.19 PM.png (436.04 KiB) Viewed 3915 times
Sun Oct 08, 2017 6:24 pm
That Log is Indigo’s native logging which we know doesn’t match up; turn debug on in my plugin (since 1.0.1) to get back to what you saw from my plugin earlier.
Sun Oct 08, 2017 6:28 pm
srkinard offline
I did turn debugging on after updating to the 1.0.1 plugin but I see no messages in the log from it...forgot to restart the plugin:
Here's the log and I snapped a screenshot right after so the values should match up now:
   Reloading plugin "Z-Wave Power Logger 1.0.1"
   Stopping plugin "Z-Wave Power Logger 1.0.1" (pid 79692)
   Stopped plugin "Z-Wave Power Logger 1.0.1"
   Starting plugin "Z-Wave Power Logger 1.0.1" (pid 81984)
   Started plugin "Z-Wave Power Logger 1.0.1"
   Z-Wave Power Logger Debug       startup called
   Z-Wave                          received "Computer Room Strip - All Outlets" energy total to 1291.029 kWh
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 13 B3 15 00 44 00 13 B3 04 88
   Z-Wave                          received "Computer Room Strip - All Outlets" power load to 839.109 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 0C CD C5 D5
   Z-Wave Power Logger Debug       Total Power: 839109 (83910.0) watts
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" energy total to 91.547 kWh
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 01 65 9B 00 4B 00 01 65 9A FF
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 01 01 32 02 21 64 00 01 65 9B 00 4B 00 01 65 9A EA
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" power load to 60.635 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 00 EC DB FF
   Z-Wave Power Logger Debug       Total Power: 60635 (6063.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 01 01 32 02 21 74 00 00 EC DB 93
   Z-Wave Power Logger Debug       Power: 60635 (6063.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 00 00 00 00 4E 00 00 00 00 FF
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 02 01 32 02 21 64 00 00 00 00 00 4E 00 00 00 00 ED
   Z-Wave                          received "Front Porch - Sensor - Temperature" sensor update to 82.7 °F
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Power Logger Debug       Total Power: 0 (0.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 02 01 32 02 21 74 00 00 00 00 A7
   Z-Wave Power Logger Debug       Power: 0 (0.0) watts
   Z-Wave                          received "Front Porch - Sensor - Humidity" sensor update to 65%
   Z-Wave                          received "Front Porch - Sensor - Luminance" sensor update to 4 lux
   Z-Wave                          received "Front Porch - Sensor - Ultraviolet" sensor update to 0
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" energy total to 306.919 kWh
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 04 AE E7 00 51 00 04 AE E3 FF
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 03 01 32 02 21 64 00 04 AE E7 00 51 00 04 AE E3 F7
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" power load to 196.094 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 02 FD FE FF
   Z-Wave Power Logger Debug       Total Power: 196094 (19609.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 03 01 32 02 21 74 00 02 FD FE A7
   Z-Wave Power Logger Debug       Power: 196094 (19609.0) watts
   Z-Wave                          received "Master Bedroom Tamper" status update is off
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" energy total to 292.133 kWh
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 04 75 25 00 54 00 04 75 21 FF
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 49 12 60 0D 04 01 32 02 21 64 00 04 75 25 00 54 00 04 75 21 F5
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" power load to 187.333 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 02 DB C5 FF
   Z-Wave Power Logger Debug       Total Power: 187333 (18733.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 04 01 32 02 21 74 00 02 DB C5 BD
   Z-Wave Power Logger Debug       Power: 187333 (18733.0) watts
Screen Shot 2017-10-08 at 7.27.12 PM.png (151.88 KiB) Viewed 3912 times
