Indigo controllable power strip
Sun Oct 08, 2017 6:48 pm
Re: Indigo controllable power strip
Here's some more data from another install. I have nothing in plugs 1 and 2 (unswitched). Switched 1 (plug 3) is my Cable Modem, switched 2 (plug 4) is my Router, and switched 4 (plug 6) is my Tablo:
Oct 8, 2017 at 8:42:35 PM 10/8
   Z-Wave                          sent "AV Power Strip" energy usage reset
   Z-Wave                          sent "Cable Modem Switched Outlet" energy usage reset
   Z-Wave                          sent "Router Switched Outlet" energy usage reset
   Z-Wave                          sent "Tablo Switched Outlet" energy usage reset
Oct 8, 2017 at 8:43:16 PM 10/8
   Z-Wave                          sent "Tablo Switched Outlet" energy status request
   Z-Wave Power Logger Debug       -----
   Z-Wave Power Logger Debug       Energy report received:
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 0F 0E 32 02 21 64 00 00 00 00 00 00 00 00 00 00 FF
   Z-Wave Power Logger Debug       Node:      15
   Z-Wave Power Logger Debug       Total:     33
   Z-Wave Power Logger Debug       Format:    64
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 0F 12 60 0D 04 01 32 02 21 64 00 00 00 00 00 00 00 00 00 00 E3
   Z-Wave Power Logger Debug       Endpoint:  4
   Z-Wave Power Logger Debug       Socket:    6
   Z-Wave                          received "Tablo Switched Outlet" power load to 8.504 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 21 38 FF
   Z-Wave Power Logger Debug       Format:    74
   Z-Wave Power Logger Debug       Total Power: 8504 (850.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 0F 0C 60 0D 04 01 32 02 21 74 00 00 21 38 FE
   Z-Wave Power Logger Debug       Power: 8504 (850.0) watts
   Z-Wave                          sent "Router Switched Outlet" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 0F 12 60 0D 02 01 32 02 21 64 00 00 00 00 00 00 00 00 00 00 E5
   Z-Wave Power Logger Debug       Endpoint:  2
   Z-Wave Power Logger Debug       Socket:    4
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Power Logger Debug       Total Power: 0 (0.0) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 0F 0C 60 0D 02 01 32 02 21 74 00 00 00 00 E1
   Z-Wave Power Logger Debug       Power: 0 (0.0) watts
   Z-Wave                          sent "Cable Modem Switched Outlet" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 18 00 04 00 0F 12 60 0D 01 01 32 02 21 64 00 00 00 00 00 00 00 00 00 00 E6
   Z-Wave Power Logger Debug       Endpoint:  1
   Z-Wave Power Logger Debug       Socket:    3
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 0F 0C 60 0D 01 01 32 02 21 74 00 00 00 00 E2
   Z-Wave                          sent "AV Power Strip" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 14 00 04 00 0F 0E 32 02 21 64 00 00 00 00 00 00 00 00 00 00 9B
   Z-Wave                          received "AV Power Strip" power load to 30.411 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 76 CB 2A
   Z-Wave Power Logger Debug       Total Power: 30411 (3041.0) watts
Power Logger States.png (42.47 KiB) Viewed 3576 times
Mon Oct 09, 2017 12:13 am
Sorry about debug Ross; I missed copying some code from another plugin - you shouldn’t have to reload plugin! I’ll sort that.
Thanks both for log/pics. I don’t understand why they don’t tie up so I’ll have to fine tune what I do log.
The powersocket states should only ever update if there’s a Format:34 or Format:74 and vice-versa (at the moment) so either state should be 0 or there should be a log snippet for Socket: 5.
(Format is a bit mask with several valid combinations that I’ll code to support other models later)
Mon Oct 09, 2017 1:36 pm
Just uploaded 1.0.2
Mon Oct 09, 2017 1:44 pm
   Starting plugin "Z-Wave Power Logger 1.0.2" (pid 31291)
   Z-Wave Power Logger Error       Error in plugin execution InitializeMain:
SyntaxError: ('invalid syntax', ('plugin.py', 113, 27, '\t\t\t\tif (bytes[10] == "74"): #3DP, Watts, 4bytes\n'))
   Stopping plugin "Z-Wave Power Logger 1.0.2" (pid 31291)
   Stopped plugin "Z-Wave Power Logger 1.0.2"
Please put a link for each version when you announce it so we don't have to go back through the thread looking for the original link. ;)
Mon Oct 09, 2017 1:56 pm
That means me going and finding it each time :lol:
1.0.4
http://www.oakworthmethodists.org/_Indi ... Plugin.zip
Mon Oct 09, 2017 2:19 pm
Still not matching outlets to data right.
Oct 9, 2017, 4:16:00 PM
   Z-Wave                          received "AV Power Strip" energy total to 0.593 kWh
   Z-Wave                          received "AV Power Strip" power load to 30.200 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 75 F8 1A
   Z-Wave Power Logger Debug       Endpoint:  Total
   Z-Wave Power Logger Debug       State:     totalpowerrep
   Z-Wave Power Logger Debug       Total Power Reported: 30200 (30.2) watts
   Z-Wave Power Logger Debug       Total Power Reported: 0 (0.0) watts
   Z-Wave Power Logger Debug       State:     socket3power
   Z-Wave Power Logger Debug       Total Power Calculated: 18.21 watts
   Z-Wave Power Logger Debug       State:     socket4power
   Z-Wave                          sent "015 - Outlet 3" energy status request
   Z-Wave                          received "015 - Outlet 3" energy total to 0.187 kWh
   Z-Wave                          received "015 - Outlet 3" power load to 9.702 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 25 E6 FF
   Z-Wave Power Logger Debug       Total Power Reported: 9702 (9.702) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 0F 0C 60 0D 03 01 32 02 21 74 00 00 25 E6 23
   Z-Wave Power Logger Debug       Endpoint:  3
   Z-Wave Power Logger Debug       Socket:    5
   Z-Wave Power Logger Debug       State:     socket5power
   Z-Wave Power Logger Debug       Power: 9702 (9.702) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 18.176 watts
Screen Shot 2017-10-09 at 4.19.08 PM 10-9.png (46.48 KiB) Viewed 3459 times
Mon Oct 09, 2017 3:19 pm
Are you sure?
That's Indigo ZWave reporting 9.702w on outlet 3, then my plugin reporting 9.702w on endpoint 3, socket 5.
As I understand it:
Socket 1 = Endpoint 5 = Unswitched
Socket 2 = Endpoint 6 = Unswitched
Socket 3 = Endpoint 1 = Outlet 1 (Switched)
Socket 4 = Endpoint 2 = Outlet 2 (Switched)
Socket 5 = Endpoint 3 = Outlet 3 (Switched)
Socket 6 = Endpoint 4 = Outlet 4 (Switched)
Which looks ok at a data/plugin/command level - the only thing wrong is you said there's nothing in socket 5 but the device is physically sending a power reading from it?
Peter
Mon Oct 09, 2017 3:35 pm
I think it's actually:
Socket 1 = Endpoint 1 = Unswitched
Socket 2 = Endpoint 2 = Unswitched
Socket 3 = Endpoint 3 = Switched 1
Socket 4 = Endpoint 4 = Switched 2
Socket 5 = Endpoint 5 = Switched 3
Socket 6 = Endpoint 6 = Switched 4
So the power readings on Endpoints 1 and 2 are correct. I'm not seeing anything on Endpoint 6.
Mon Oct 09, 2017 3:45 pm
srkinard offline
On mine I just checked with the new plugin and physical outlet #2 is empty but socket4 is the one with no reading.
Physical socket #1 has the small load on it and that matches socket3
I'm wondering if the sockets map weird...
socket3 = Unswitched #1 = Physical #1
socket4 = Unswitched #2 = Physical #2
Sadly with servers powering too much of the house I can't easily play with them.
I just ordered another strip to experiment with using my Kill-a-watt meter and a known load...it will arrive Wed.
Try to help narrow down exactly which sockets line up with what...
Here's the log:
   Action Group                    Refresh Power Strip Energy
   Z-Wave                          sent "Computer Room Strip - All Outlets" energy status request
   Z-Wave                          received "Computer Room Strip - All Outlets" energy total to 1308.930 kWh
   Z-Wave                          received "Computer Room Strip - All Outlets" power load to 854.635 W
   Z-Wave                          sent "Computer Room Strip - Outlet 1 - ESXi 02" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 0D 0A 6B BD
   Z-Wave Power Logger Debug       Total Power Reported: 854635 (854.635) watts
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" energy total to 92.826 kWh
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" power load to 60.733 W
   Z-Wave                          sent "Computer Room Strip - Outlet 2 - ESXi 03" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 00 ED 3D FF
   Z-Wave Power Logger Debug       Total Power Reported: 60733 (60.733) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 01 01 32 02 21 74 00 00 ED 3D 74
   Z-Wave Power Logger Debug       Power: 60733 (60.733) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 17120.782 watts
   Z-Wave                          sent "Computer Room Strip - Outlet 3 - Mac Pro" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 02 01 32 02 21 74 00 00 00 00 A7
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" energy total to 311.168 kWh
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" power load to 201.686 W
   Z-Wave                          sent "Computer Room Strip - Outlet 4 - 24 bay RAID" energy status request
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 03 13 D6 FF
   Z-Wave Power Logger Debug       Total Power Reported: 201686 (201.686) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 03 01 32 02 21 74 00 03 13 D6 60
   Z-Wave Power Logger Debug       Power: 201686 (201.686) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 17112.588 watts
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" energy total to 296.164 kWh
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" power load to 188.786 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 02 E1 72 FF
   Z-Wave Power Logger Debug       Total Power Reported: 188786 (188.786) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 49 0C 60 0D 04 01 32 02 21 74 00 02 E1 72 30
   Z-Wave Power Logger Debug       State:     socket6power
   Z-Wave Power Logger Debug       Power: 188786 (188.786) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 17111.271 watts
Attaching the screen of the socket readings
Screen Shot 2017-10-09 at 4.33.07 PM.png (144.46 KiB) Viewed 3450 times
Mon Oct 09, 2017 4:26 pm
Sorry, you're correct - I've just re-read Matt's post in the 2014 thread on this subject.
For on/off commands, endpoints 1-4 are the switched sockets 3-6.
For energy reporting, endpoints 1-4 are the unswitched sockets 1-2 and the first two switched sockets 3-4.
That's where all the confusion lies. I've been applying the on/off mapping where endpoints 1-4 are sockets 3-6 and thus endpoints 5-6 would (if they existed) be sockets 1-2.
I've just put 1.0.7 up at the same link... :lol:
Note there's a new Action to reset the power levels to zero which will probably be sensible before continuing.
Peter
Mon Oct 09, 2017 5:04 pm
Now I'm seeing power readings on 3 and 4, but nothing on 6. Does Endpoint 5 or 6 not work? Indigo doesn't see them so the plugin can't either?
Mon Oct 09, 2017 5:06 pm
Are you sending my Action to request them?
Indigo will never ask them cos it doesn’t know about them.
Mon Oct 09, 2017 5:18 pm
srkinard offline
The numbers I get seem to line up with what's plugged in now...
I'll test once I get the new power strip on, before I put it into use...
Tue Oct 10, 2017 12:17 am
Great.
Can you both play with the totalpower/totalpowerrep values?
TotalPowerRep gets updated whenever it receives a 'total' power report from the device whereas TotalPower is calculated from the totals of 1-8.
I don't think TotalPowerRep is accurate because whenever an endpoint report arrives, I think it also sends a false "total" report of the same endpoint value.
I've asked Jay for a subforum in my plugins area.
Peter
Tue Oct 10, 2017 6:31 am
State values that are getting filled in haven't changed. And I'm not sure that using your request commands actually does anything:
   Action Group                    Power Strip Testing
   Z-Wave Power Logger             Requesting power level 1 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 01 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 2 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 02 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 3 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 03 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 4 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 04 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 5 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 05 32 01 0A 25]
   Z-Wave Power Logger             Requesting power level 6 for node 15
   Z-Wave                          sent "AV Power Strip" raw command [60 0D 01 06 32 01 0A 25]
The commands are getting sent, but nothing is coming back as far as I can tell. When I use the "Update" button in the Indigo device UI, I do get something back:
   Z-Wave                          received "Tablo Switched Outlet" power load to 8.468 W
   Z-Wave Power Logger Debug       Raw command: 01 0E 00 04 00 0F 08 32 02 21 74 00 00 21 14 FF
   Z-Wave Power Logger Debug       Total Power Reported: 8468 (8.468) watts
   Z-Wave Power Logger Debug       Raw command: 01 12 00 04 00 0F 0C 60 0D 04 01 32 02 21 74 00 00 21 14 D2
   Z-Wave Power Logger Debug       Power: 8468 (8.468) watts
   Z-Wave Power Logger Debug       Total Power Calculated: 17.934 watts
In that example, I was asking for an update for switched outlet 4, but what I got back was endpoint 4 which is the second switched outlet (physical outlet 4).
There doesn't seem to be anything I can do that will get an update from switched outlet 4 (physical outlet 6, presumably endpoint 6 for energy reports).
Screen Shot 2017-10-10 at 8.25.29 AM 10-10.png (40.32 KiB) Viewed 3372 times
