Indigo controllable power strip
Tue Oct 17, 2017 2:46 pm
srkinard offline
Re: Indigo controllable power strip
Installed it and tested...no errors on the energy reset, but now the current power settings all show zero and the energy totals are still there.
Here's a log snippet from the "refresh" of one strip (and still Incorrect Packet size errors...no plugin errors tho.)
   Action Group                    Refresh Power Strip Energy
   Z-Wave                          sent "Computer Room Strip - All Outlets" energy status request
   Z-Wave                          received "Computer Room Strip - All Outlets" energy total to 1471.711 kWh
   Z-Wave Sensor Logger Debug      -----
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 16 74 DF 00 64 00 16 74 D0 B6
   Z-Wave Sensor Logger Debug      Bitmask: 64, DP: 3, Scale: 0, ByteLength: 4
   Z-Wave Sensor Logger Debug      Energy Reported: 1471.711 kWh
   Z-Wave                          received "Computer Room Strip - All Outlets" power load to 856.807 W
   Z-Wave                          sent "Computer Room Strip - Outlet 1 - ESXi 02" energy status request
   Z-Wave Sensor Logger Debug      Incorrect packet size - ignoring
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" energy total to 104.445 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 01 97 FD 00 64 00 01 97 FC FF
   Z-Wave Sensor Logger Debug      Endpoint[Node]:  1
   Z-Wave Sensor Logger Debug      Energy Reported: 104.445 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 49 12 60 0D 01 01 32 02 21 64 00 01 97 FD 00 64 00 01 97 FC C5
   Z-Wave Sensor Logger Debug      Endpoint[Raw]:  1
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 104.445 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 1471.697 kWh
   Z-Wave Sensor Logger Debug      Total Power Calculated: 0.0 w
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" power load to 61.034 W
   Z-Wave                          sent "Computer Room Strip - Outlet 2 - ESXi 03" energy status request
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 00 00 00 00 65 00 00 00 00 FF
   Z-Wave Sensor Logger Debug      Endpoint[Node]:  2
   Z-Wave Sensor Logger Debug      Energy Reported: 0.0 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 49 12 60 0D 02 01 32 02 21 64 00 00 00 00 00 65 00 00 00 00 C6
   Z-Wave Sensor Logger Debug      Endpoint[Raw]:  2
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 0.0 kWh
   Z-Wave                          sent "Computer Room Strip - Outlet 3 - Mac Pro" energy status request
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" energy total to 349.828 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 05 56 84 00 65 00 05 56 80 FF
   Z-Wave Sensor Logger Debug      Endpoint[Node]:  3
   Z-Wave Sensor Logger Debug      Energy Reported: 349.828 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 49 12 60 0D 03 01 32 02 21 64 00 05 56 84 00 65 00 05 56 80 C3
   Z-Wave Sensor Logger Debug      Endpoint[Raw]:  3
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 349.828 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 1471.701 kWh
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" power load to 201.826 W
   Z-Wave                          sent "Computer Room Strip - Outlet 4 - 24 bay RAID" energy status request
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" energy total to 332.595 kWh
   Z-Wave                          received "Front Porch - Sensor - Motion Sensor" status update is on
   Trigger                         Front Porch - Motion Trigger
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 49 0E 32 02 21 64 00 05 13 33 00 66 00 05 13 30 FF
   Z-Wave Sensor Logger Debug      Endpoint[Node]:  4
   Z-Wave Sensor Logger Debug      Energy Reported: 332.595 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 49 12 60 0D 04 01 32 02 21 64 00 05 13 33 00 66 00 05 13 30 C0
   Z-Wave Sensor Logger Debug      Endpoint[Raw]:  4
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 332.595 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 1471.704 kWh
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" power load to 193.670 W
Tue Oct 17, 2017 2:50 pm
You're never happy are you! :)
Added reset energy in .20 (same Action)
It's correct to say invalid packet size, because that's what's coming from your zwave network - invalid packets (hence why plugin was erroring because data wasn't where it should be)
Peter
Tue Oct 17, 2017 2:54 pm
srkinard offline
Well...in my defense...I *am* on a diet and haven't had any of my favorite foods (or sugar...or soft drinks) in almost 4 weeks. I've dropped 14lbs though.
I blame Aeon Labs for their device not presenting a more sensible setup to Indigo and complicating Matt, Jay and your lives because of it. :mrgreen:
Ross
Tue Oct 17, 2017 3:22 pm
Just uploaded .21 which adds timestamps to the states - I'd already done this for temperature devices so I've ported them to power devices.
14lbs is good; I lost 7 when I got my exercise bike/cross trainer - then put 3 back on! - but my knee was hurting so I wasn't exercising as much as previously. It's ok again now so need to get back on it once I shift this cold.
Peter
Tue Oct 17, 2017 3:24 pm
Nah, Jay doesn't do owt - he's been on holiday for a fortnight and I haven't noticed anyone missing him...
Sat Oct 21, 2017 7:35 pm
srkinard offline
Been busy so haven't had a chance to tinker with this much, but even with current .21 version I don't get the power reading anymore.
Since the update where it starts with Incorrect packet size - Ignoring not a single outlet returns power levels...only energy levels. This did work previously regardless of the occasional error in the log regarding the packet counts.
Here's the log from just now:
   Action Group                    Update new strip
   Z-Wave                          sent "078 - New Power Strip" energy status request
   Z-Wave                          received "078 - New Power Strip" energy total to 0.403 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 4E 0E 32 02 21 64 00 00 01 93 01 A5 00 00 01 80 6D
   Z-Wave Sensor Logger Debug      Energy Reported: 0.403 kWh
   Z-Wave                          received "078 - New Power Strip" power load to 153.057 W
   Z-Wave                          sent "078 - Outlet 1" energy status request
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 4E 0E 32 02 21 64 00 00 00 02 01 A4 00 00 00 02 FF
   Z-Wave Sensor Logger Debug      Energy Reported: 0.002 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 4E 12 60 0D 01 01 32 02 21 64 00 00 00 02 01 A4 00 00 00 02 02
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 0.002 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 0.357 kWh
   Z-Wave                          sent "078 - Outlet 2" energy status request
   Z-Wave                          received "078 - Outlet 2" energy total to 0.051 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 4E 0E 32 02 21 64 00 00 00 33 01 A5 00 00 00 30 FF
   Z-Wave Sensor Logger Debug      Energy Reported: 0.051 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 4E 12 60 0D 02 01 32 02 21 64 00 00 00 33 01 A5 00 00 00 30 03
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 0.051 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 0.36 kWh
   Z-Wave                          received "078 - Outlet 2" power load to 21.147 W
   Z-Wave                          sent "078 - Outlet 3" energy status request
   Z-Wave                          received "078 - Outlet 3" energy total to 0.059 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 4E 0E 32 02 21 64 00 00 00 3B 01 A4 00 00 00 38 FF
   Z-Wave Sensor Logger Debug      Energy Reported: 0.059 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 4E 12 60 0D 03 01 32 02 21 64 00 00 00 3B 01 A4 00 00 00 38 03
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 0.059 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 0.363 kWh
   Z-Wave                          received "078 - Outlet 3" power load to 16.333 W
   Z-Wave                          sent "078 - Outlet 4" energy status request
   Z-Wave                          received "078 - Outlet 4" energy total to 0.264 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 4E 0E 32 02 21 64 00 00 01 08 01 A4 00 00 00 FB FF
   Z-Wave Sensor Logger Debug      Energy Reported: 0.264 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 18 00 04 00 4E 12 60 0D 04 01 32 02 21 64 00 00 01 08 01 A4 00 00 00 FB F5
   Z-Wave Sensor Logger Debug      Endpoint Energy Reported: 0.264 kWh
   Z-Wave Sensor Logger Debug      Total Energy Calculated: 0.376 kWh
   Z-Wave                          received "078 - Outlet 4" power load to 111.958 W
Not sure what to do....all my z-wave devices operate normally so I don't think it's my system.
And the energy reset still says it completes but doesn't reset the energy values in the strips.
Is there a UK version of the strip? I'd send you an Amazon gift card to get one for developing on if so...
Ross
Sun Oct 22, 2017 1:35 am
Sorry, been busy catching up on jobs I didn’t do last weekend when I coded this plugin!
There’s no uk version of the Power strip; nearest thing from Aeotec is the http://www.vesternet.com/z-wave-aeon-la ... -6-gen5-uk single socket but finding that (with UK plugs) in Amazon is proving difficult.
The reset command is only intended to reset the local values; primarily for when debugging new devices that end up logging wrong sensors to wrong endpoints. I believe Indigo’s UI resets the actual strip correctly?
I’ll look at energy readings - I’ve probably miscounted.
Mon Oct 23, 2017 3:17 pm
I've just uploaded .22 which temporarily reverts the error checking for energy reports.
So you should receive most energy reports again now, but may get some of the invalid length errors returning in the log for now.
Peter
Tue Oct 24, 2017 7:32 pm
srkinard offline
Do you dread seeing my name yet? lol...sorry...
Updated the plugin and one outlet reports power, but none of the others seem to...the log shows numbers but they don't actually show int he plugin:
   Z-Wave Sensor Logger            Requesting total power levels for node 73
   Z-Wave                          sent "Computer Room Strip - All Outlets" raw command [32 01 10]
   Z-Wave Sensor Logger            Requesting power level 1 for node 73
   Z-Wave                          received "Computer Room Strip - All Outlets" power load to 862.329 W
   Z-Wave Sensor Logger            Requesting power level 2 for node 73
   Z-Wave                          received "Computer Room Strip - Outlet 1 - ESXi 02" power load to 62.311 W
   Z-Wave Sensor Logger            Requesting power level 3 for node 73
   Z-Wave Sensor Logger            Requesting power level 4 for node 73
   Z-Wave                          received "Computer Room Strip - Outlet 3 - Mac Pro" power load to 219.295 W
   Z-Wave Sensor Logger            Requesting power level 5 for node 73
   Z-Wave Sensor Logger            Requesting power level 6 for node 73
   Z-Wave                          received "Computer Room Strip - Outlet 4 - 24 bay RAID" power load to 195.553 W
   Z-Wave Sensor Logger            Requesting power level 7 for node 73
   Z-Wave Sensor Logger            Requesting power level 8 for node 73
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 4E 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Sensor Logger Debug      Bitmask: 74, DP: 3, Scale: 2, ByteLength: 4
   Z-Wave Sensor Logger Debug      Power Reported: 0.0 w
   Z-Wave Sensor Logger Debug      Raw command: 01 14 00 04 00 4D 0E 32 02 21 64 00 00 47 98 00 E6 00 00 47 92 35
   Z-Wave Sensor Logger Debug      Energy Reported: 18.328 kWh
   Z-Wave Sensor Logger Debug      Raw command: 01 10 00 04 00 4D 0A 32 02 21 74 00 01 2F A9 00 00 4E
   Z-Wave Sensor Logger Debug      Power Reported: 77.737 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 4E 08 32 02 21 74 00 00 46 33 A3
   Z-Wave Sensor Logger Debug      Power Reported: 17.971 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 4E 08 32 02 21 74 00 00 46 33 FF
   Z-Wave Sensor Logger Debug      Endpoint[Node]:  5
   Z-Wave Sensor Logger Debug      Endpoint[Node]:  6
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 0D 28 79 8D
   Z-Wave Sensor Logger Debug      Power Reported: 862.329 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 00 F3 67 FF
   Z-Wave Sensor Logger Debug      Power Reported: 62.311 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 00 00 00 FF
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 03 58 9F FF
   Z-Wave Sensor Logger Debug      Power Reported: 219.295 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 02 FB E1 FF
   Z-Wave Sensor Logger Debug      Power Reported: 195.553 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 03 70 06 FF
   Z-Wave Sensor Logger Debug      Power Reported: 225.286 w
   Z-Wave Sensor Logger Debug      Raw command: 01 0E 00 04 00 49 08 32 02 21 74 00 02 8F 3E FF
   Z-Wave Sensor Logger Debug      Power Reported: 167.742 w
Attaching a screen of the plugin values taken right after the log snippet
Screen Shot 2017-10-24 at 8.30.49 PM.png (62.71 KiB) Viewed 2847 times
Thu Oct 26, 2017 1:20 pm
Sorry, 1.0.23 uploaded.
Same as before - it's a temporary fix to re-enable the energy logs but may also give errors occasionally.
Peter
