Python Script to Add 2 Numbers/Variables
Sat Dec 02, 2023 8:25 pm
ckeyes888 offline
Ugh, thought this would be an easy conversion from AS but as usual I’m not getting it.
Need to add one variable to another. In this case I need to add the SnowToday variable to the SnowSeason variable.
The existing script is:
       set snowDay to the value of variable "SnowToday" as real
       set snowSeason to the value of variable "SnowSeason" as real
       set snowSeason to snowSeason + snowDay
       set the value of variable "SnowSeason" to snowSeason
end tell
Appreciate any help.
Carl
Sat Dec 02, 2023 8:33 pm
Re: Python Script to Add 2 Numbers/Variables
Why don't you show what you've tried, so we can help you learn.
Sat Dec 02, 2023 8:54 pm
ryanbuckner offline
try this:
# replace the variable numbers below with the IDs of snowSeason and SnowToday. You can go to the variable in Indigo and right click to get the ID
snowSeason = float(indigo.variables[954090031].value) + float(indigo.variables[954090032].value)
# replace the variable number below with the ID of snowSeason
indigo.variable.updateValue(954090031, value=str(snowSeason))
Sat Dec 02, 2023 9:02 pm
ckeyes888 offline
Here’s what I tried:
 snowDay = indigo.variables[504418172].value
snowSeason = indigo.variables[1813022255].value
snowTotal = snowDay + snowSeason
indigo.variable.updateValue(1813022255,snowTotal)
Carl
Sat Dec 02, 2023 9:04 pm
Carl
That API returns a string (all Indigo variables are strings). There's an alternate call to get an int or float, or you can cast what you got to a float when you do the addition. You will also need to convert that result to a string when you do the updatevalue() call.
Sat Dec 02, 2023 9:13 pm
ckeyes888 offline
Tried this but get a “Python argument types in” error.
 snowTotal = float(indigo.variables[1813022255].value) + float(indigo.variables[504418172].value)
indigo.variable.updateValue(1813022255, value=snowTotal)
Carl
Sat Dec 02, 2023 9:15 pm
ryanbuckner offline
Don't forget to convert the snowTotal back to a string
Sat Dec 02, 2023 9:16 pm
Indigo variables are strings. You're trying to set it to a float.
Sat Dec 02, 2023 9:19 pm
ckeyes888 offline
Got it except it’s adding a decimal place. Adding 3 + 1 is returning 4.0.
How to remove?
Carl
Sat Dec 02, 2023 9:20 pm
Well, you're converting to floats, which always have a decimal point. If your inputs are always whole numbers, you should be using integers.
Sat Dec 02, 2023 9:27 pm
ckeyes888 offline
It tried substituting “int” for “floats” but that doesn’t work.
No idea how to do that.
Carl
Sat Dec 02, 2023 9:38 pm
Sat Dec 02, 2023 9:45 pm
ryanbuckner offline
Carl
Why don't you share your current code and any errors you're receiving. Also, what are the values of the variables right now?
Sun Dec 03, 2023 6:36 pm
ckeyes888 offline
Sorry, tried substituting int for float again and it works fine.
Thanks a bunch!
Carl
Tue Dec 05, 2023 9:27 pm
ryanbuckner offline
Thanks a bunch!
Carl
Great. Post your working code for the next person that has the same problem and finds this thread
