Changing Indigo Variables with AppleScript
Wed Jul 19, 2023 8:52 pm
Dave Durham offline
OK...yes, I know, I know...I should switch to Python...but for now I have hundreds of AppleScripts that need to work with Indigo and maybe eventually I'll properly change them. So...
I have a way to have my AppleScript scripts read and write to Indigo Variables via my Reflector. But I can't believe this is the fastest/best way to do this. It works, but it takes a second or two (as opposed to instant the way it used to when the server was scriptable). So, my question is, is there a faster/better way to read and write Indigo Variables via AppleScript? Here is the way I do it now:
To Write an Indigo Variable via AppleScript:
on sendToIndigo(theValue, variableID)
   set theValue to cleanUpString2(theValue) --This just gets rid of \ and ' characters
   set sideShell to "curl -X POST -H \"Authorization: Bearer  MyAuthorizationCodeGoestHere\" -d '{\"message\": \"indigo.variable.updateValue\", \"objectId\": " & variableID & ", \"parameters\": {\"value\": \"" & theValue & "\"}}' https://ReflectorNameHere.indigodomo.net/v2/api/command"
   do shell script sideShell
end sendToIndigo
To Read an Indigo Variable via AppleScript:
--Currently limitied to 2000 Characters in the return
on getFromIndigo(variableID)
   set sideShell to "curl -H \"Authorization: Bearer MyAuthorizationCodeGoesHere\" https://ReflectorNameHere.indigodomo.net/v2/api/indigo.variables/" & variableID
   try
      set VariableInformation to do shell script sideShell
      set characterPosition to 1
      set valuePosition to 1
      set variableValue to ""
      repeat 300 times
         if character characterPosition of VariableInformation = "v" then
            set wordCheck to (characters characterPosition thru (characterPosition + 4) of VariableInformation) as string
            if wordCheck = "value" then
               set valuePosition to characterPosition + 9
               if ((character valuePosition of VariableInformation) as string) = "\"" then
                  --The value is BLANK
               else
                  --The vlaue is NOT BLANK
                  repeat 2000 times
                     set variableValue to (variableValue & character valuePosition of VariableInformation) as string
                     set valuePosition to valuePosition + 1
                     if character valuePosition of VariableInformation = "\"" then exit repeat
                  end repeat
               end if
            end if
         end if
         if valuePosition is not 1 then exit repeat
         set characterPosition to characterPosition + 1
      end repeat
      return variableValue
   on error
      --There was a problem getting the Variable from Indigo
   end try
end getFromIndigo
Any help / insight would be appreciated.
Thank you kindly,
Dave Durham
Thu Jul 20, 2023 7:23 am
Re: Changing Indigo Variables with AppleScript
Two points:
  • You don't have to use the reflector - since you're running the script on the same Mac, you can just use http://localhost:8176/
  • The Indigo Control AppleScript should be faster than using the reflector - not sure if it'll be faster than using localhost though since it has to launch an IPH instance for each script
Thu Jul 20, 2023 7:33 am
One more: after editing your post to put code tags around your AppleScript (which you should always do), I admit I don't understand exactly what the function that gets an Indigo is doing, but it's potentially doing a TON of looping. AppleScript isn't very fast, so I'm a little surprised it ever worked quickly. I suspect you'd get a big performance boost by converting that to Python. We could help if you could explain what it's trying to do.
Fri Jul 21, 2023 11:17 am
Dave Durham offline
Jay, Thank you for the reply. and as usual, you're right on both counts. I'll circle back to implement when I return from my trip.
Thank you kindly,
-d
Fri Jul 21, 2023 12:11 pm
He's looping through the JSON response looking for the "value" key (and value).
