Moon Phase Script?
Tue Apr 04, 2023 8:28 pm
ckeyes888 offline
Moon Phase Script?
Since the Fantastic Weather plugins are no more I lost my moon phase device state info.
Before using the plugin I used an Applescript to determine the moon phase,
which of course is also defunct.
Hoping there might be a Python version of this script to return a numeric description of the current moon phase?
   set theYear to year of (current date)
   set theMonth to month of (current date) as integer
   set theDay to day of (current date)
   if (theMonth = 1) then
      set theDay to theDay - 1
   else if (theMonth = 2) then
      set theDay to theDay + 30
   else
      set theDay to theDay + 28 + (theMonth - 2) * 3059 / 100
   end if
   set g to (theYear - 1900) mod 19 + 1
   set e to (11 * g + 18) mod 30
   if (((e = 25) and (g > 11)) or (e = 24)) then
      set e to e + 1
   end if
   set fullness to ((((e + theDay) * 6 + 11) mod 177) / 22) as integer
   if (fullness = 8) then set fullness to 0
   set value of variable "MoonPhase" to fullness
end tell
Carl
Wed Apr 05, 2023 5:47 am
Re: Moon Phase Script?
Wed Apr 05, 2023 2:38 pm
ckeyes888 offline
Looks great but how do I apply that to populating a variable?
Carl
Wed Apr 05, 2023 2:39 pm
Instead of the print statement, save the value to an Indigo variable. How to do that is in the Wiki.
Wed Apr 05, 2023 2:50 pm
ckeyes888 offline
Am I close? Cant get it to compile.
Thanks, Carl
#!/usr/bin/env python
moonphase.py - Calculate Lunar Phase
Author: Sean B. Palmer, inamidst.com
Cf. http://en.wikipedia.org/wiki/Lunar_phase#Lunar_phase_calculation
import math, decimal, datetime
dec = decimal.Decimal
def position(now=None):
   if now is None:
      now = datetime.datetime.now()
   diff = now - datetime.datetime(2001, 1, 1)
   days = dec(diff.days) + (dec(diff.seconds) / dec(86400))
   lunations = dec("0.20439731") + (days * dec("0.03386319269"))
   return lunations % dec(1)
def phase(pos):
   index = (pos * dec(8)) + dec("0.5")
   index = math.floor(index)
   return {
      0: "New Moon",
      1: "Waxing Crescent",
      2: "First Quarter",
      3: "Waxing Gibbous",
      4: "Full Moon",
      5: "Waning Gibbous",
      6: "Last Quarter",
      7: "Waning Crescent"
   }[int(index) & 7]
def main():
   pos = position()
   phasename = phase(pos)
   roundedpos = round(float(pos), 3)
   indigo.variable.updateValue(indigo.variables[103086076], value= roundedpos)
   ##print "%s (%s)" % (phasename, roundedpos)
if __name__=="__main__":
   main()
Wed Apr 05, 2023 2:59 pm
What's with all the blank lines?
This works for me. You have to cast the value to a string before you store it in the Indigo variable. I also removed the "main" function because that doesn't work in an embedded script.
def position(now = None):
   if now is None:
def phase(pos):
   return {
      0: "New Moon",
      2: "First Quarter",
      4: "Full Moon",
      6: "Last Quarter",
   }[int(index) & 7]
pos = position()
indigo.variable.updateValue(indigo.variables[504685077], value = str(roundedpos))
#print(roundedpos)
Wed Apr 05, 2023 3:15 pm
ckeyes888 offline
Working great. Trying modify it to return a whole number without a decimal.
Got it working.
Carl
Wed Apr 05, 2023 3:33 pm
roundedpos = int(round(float(pos), 3))
