Convert to Python
Wed Aug 03, 2022 7:32 pm
ckeyes888 offline
Convert to Python
Hey,
Having trouble converting this one to python.
Appreciate any help!
   set the value of variable "TimerSpklrDurationMin" to (value of variable "TimerSpklrDuration") & " " & "min" & " " & "remain"
end tell
Carl
Thu Aug 04, 2022 3:01 am
Re: Convert to Python
Have you looked at the Adapter/Device Conversion plugins for this?
There’s a new py3 version that @DaveL17 has written but I don’t think it’s hit the plugin store yet.
It will constantly maintain itself with exactly the wording you’re trying to set in that variable, that I guess you then display on a control page.
No need for a script to tell Indigo to refresh the variable.
Thu Aug 04, 2022 4:44 am
There is an "unofficial" fork of the Adapters plugin updated for Python 3 in my GitHub repos. It's a beta release, but seems to be running smoothly. I consider it unofficial because the plugin will be added to the Indigo open source plugin list (as it's been abandoned by its original developer.)
For your original question, here's the Python version of your code (it's better to use ID numbers instead of names):
# with IDs
var_value = indigo.variables[1928699259].value  # ID of `TimerSpklrDuration`
indigo.variable.updateValue(314742858, var_value + " min remain")  # ID of `TimerSpklrDurationMin`
# with names
var_value = indigo.variables["TimerSpklrDuration"].value
indigo.variable.updateValue("TimerSpklrDurationMin", var_value + " min remain")
Thu Aug 04, 2022 11:29 am
ckeyes888 offline
Thanks a bunch!
Will be updating soon but still so many Applescripts to convert. :-(
Carl
Thu Aug 04, 2022 11:59 am
ckeyes888 offline
Maybe one more?
   set the value of variable "sprinklerLastRun" to (value of variable "DayShort") & " " & (value of variable "MonthShort") & "," & (value of variable "DateExt")
end tell
I've gotten this far:
var_value = indigo.variables[1109021660].value  # ID of `sprinklerLastRun `
var_value = indigo.variables[1842520251].value  # ID of `DayShort `
var_value = indigo.variables[1269656511].value  # ID of `MonthShort `
var_value = indigo.variables[1102866719].value  # ID of `DayExt `
indigo.variable.updateValue(1109021660, var_value +
Carl
Thu Aug 04, 2022 12:49 pm
last_run = indigo.variables[1109021660].value  # ID of `sprinklerLastRun `
day_short = indigo.variables[1842520251].value  # ID of `DayShort `
month_short = indigo.variables[1269656511].value  # ID of `MonthShort `
day_ext  = indigo.variables[1102866719].value  # ID of `DayExt `
indigo.variable.updateValue(1109021660, f"{day_short} {month_short}, {day_ext}")
Though, you use DateExt in your AppleScript but DayExt in your python script's description of the variable - I assumed the comment in the python script is right but if not you can change it from day_ext to date_ext in both places.
Thu Aug 04, 2022 2:48 pm
ckeyes888 offline
Thanks Jay.
Getting syntax error. See attached image.
Carl
Thu Aug 04, 2022 2:57 pm
Upon a quick review, the code looks right. What version of Indigo are you using?
Thu Aug 04, 2022 4:08 pm
ckeyes888 offline
Don’t laugh…7.2.0
Carl
Thu Aug 04, 2022 4:18 pm
No judgment here, but that explains the syntax error. This code should fix it. Replace the last line with this:
indigo.variable.updateValue(1109021660, u"{0} {1}, {2}".format(day_short, month_short, date_ext))
Thu Aug 04, 2022 4:27 pm
ckeyes888 offline
Different error.
Carl
Thu Aug 04, 2022 5:45 pm
indigo.variable.updateValue(…….)
Somehow the start of the line has been mistransposed.
Thu Aug 04, 2022 6:10 pm
DAMMIT.
Changed my post above.
Thu Aug 04, 2022 6:28 pm
ckeyes888 offline
Perfect. Many thanks!
Carl
Sat Aug 06, 2022 9:21 am
ckeyes888 offline
Doh, I found one more I can't get converted.
   if value of variable "TimerSprinklerStart" as integer is greater than 2000 then
      if value of variable "DayLong" is "Sunday" then
         set value of variable "sprinklerNextRun" to "Tuesday"
      else if value of variable "DayLong" is "Monday" then
         set value of variable "sprinklerNextRun" to "Wednesday"
It's a much longer script but if can finish it if I get this section.
Carl
