Convert to Python
Sat Aug 06, 2022 12:48 pm
Re: Convert to Python
Untested, but close:
# Get the variable values
timer_sprinkler_start = indigo.variables[TimerSprinklerStart_IDHERE].getValue(int)
day_long = indigo.variables[DayLong_IDHERE].value
# Perform the logic
if timer_sprinkler_start > 2000:
    if day_long == "Sunday":
        indigo.variable.updateValue(sprinklerNextRun_IDHERE, "Tuesday")
    elif day_long == "Monday"
        indigo.variable.updateValue(sprinklerNextRun_IDHERE, "Wednesday")
Sat Aug 06, 2022 3:34 pm
Something like this:
if int(indigo.variable.value("TimerSprinklerStart")) > 2000:
    if indigo.variable.value("DayLong") == "Sunday":
        indigo.variable.updateValue("sprinklerNextRun", "Tuesday")
    elif indigo.variable.value("DayLong") == "Monday":
        indigo.variable.updateValue("sprinklerNextRun", "Wednesday")
Sun Aug 07, 2022 12:16 pm
ckeyes888 offline
Thanks so much.
Very close now to updating Indigo for the first time in years.
Carl
Sun Aug 07, 2022 12:53 pm
Don't forget to convert the variable names to variable ID numbers (no quotes) to "future-proof" your scripts. :D
Wed Aug 10, 2022 6:32 pm
ckeyes888 offline
Will do, thanks.
Carl
Fri Aug 12, 2022 7:50 pm
ckeyes888 offline
Ugh, keep finding more.
Help converting?
   set rainDay to the value of variable "wsDaily_Rain" as real
   set rainSeason to the value of variable "RainSeason" as real
   set rainSeason to rainSeason + rainDay
   set the value of variable "RainSeason" to rainSeason
   set X to value of variable "RainSeason"
   set X to 100 * X as integer
   set X to X / 100
   set value of variable "RainSeason" to X as string
end tell
Carl
Sat Aug 13, 2022 6:04 am
I don't know AppleScript, but it looks like the stuff at the bottom (the last 4 lines) is unnecessary). Someone should check me on this, but I think this will do it:
rainDay = float(indigo.variables['wsDaily_Rain'].value)
rainSeason = float(indigo.variables['RainSeason'].value)
rainSeason += rainDay
indigo.variable.updateValue('RainSeason', str(int(rainSeason)))
Sat Aug 13, 2022 6:16 am
I’m thought that initially, but it’s actually a clever way of rounding to 2 D.P.
I’ve done the same myself before now.
Sat Aug 13, 2022 1:08 pm
ckeyes888 offline
The script just rounds off the RainSeason variable to a whole number…doesn’t add the rainDay to it.
Carl
Sat Aug 13, 2022 2:55 pm
I'm confused. Isn't that what this line does?
Sat Aug 13, 2022 3:06 pm
It may be that once AppleScript has X as an integer, it retains it as integer, so dividing by 100 would do as Carl says - ie the last four rows round off the value of RainSeason to a whole number.
Either way, the earlier setting of the variable is superfluous as it's overwritten by either a 2DP or whole number.
Carl
It DOES add rainDay to it.
The first section adds rainDay to rainSeason then stores it back into RainSeason.
The second section re-grabs RainSeason (which has now been incremented) then rounds it off to either 2DP or integer.
Yes.
Sat Aug 13, 2022 3:24 pm
ckeyes888 offline
Sorry guys. I’m confused.
When running python script above on a rainDay variable of 0.09 and a rainSeason variable of 7.09 the return on the rainSeason is just 7, not 7.18.
Carl
Sat Aug 13, 2022 4:02 pm
Change the last line to:
indigo.variable.updateValue('RainSeason', f"{rainSeason:.2f}")
Sat Aug 13, 2022 4:17 pm
ckeyes888 offline
Get this error.
Carl
