Convert to Python?
Sun Jun 06, 2021 2:19 pm
ckeyes888 offline
Convert to Python?
Is this script convertible to python?
set militaryTime to value of variable "sprk_Start_Time"
set standardTime to militaryTimeToStandardTime(militaryTime)
on militaryTimeToStandardTime(militaryTime)
   set militaryTime to militaryTime as text
   if length of militaryTime is equal to 4 then
      set theHour to text 1 thru 2 of militaryTime
      set theMinutes to text 3 thru 4 of militaryTime
   else if length of militaryTime is equal to 3 then
      set theHour to "" & text 1 of militaryTime
      set theMinutes to text 2 thru 3 of militaryTime
   else if length of militaryTime is equal to 2 then
      set theHour to "00"
      set theMinutes to text 1 thru 2 of militaryTime
   else if length of militaryTime is equal to 1 then
      set theHour to "00"
      set theMinutes to "0" & text 1 of militaryTime
   end if
   set theHourNumber to theHour as number
   if (theHourNumber is equal to 0) and (theMinutes is equal to 0) then
      set standardTime to "12:00 AM"
   else if theHourNumber is greater than 12 then
      set theHourNumber to theHourNumber - 12
      set standardTime to (theHourNumber as text) & ":" & theMinutes & " pm"
   else if theHourNumber = 12 then
      set standardTime to theHour & ":" & theMinutes & " pm"
   else if (theHourNumber is equal to 0) and (theMinutes is not equal to 0) then
      set standardTime to "12" & ":" & theMinutes & " am"
   else
      set standardTime to theHour & ":" & theMinutes & " am"
   end if
end militaryTimeToStandardTime
set value of variable "sprk_Start_Time_AmPm" to standardTime
Very much appreciate any help with it.
Carl
Sun Jun 06, 2021 2:43 pm
whmoorejr offline
Re: Convert to Python?
For getting military or standard time as a clock in indigo, I use the Clock Display plugin: https://www.indigodomo.com/pluginstore/164/
Once you create a clock device, you can pull the time in any format (Each format is a separate device state) in a python script or use on a control page in any format. On pages only I use, I use the 24 hour clock. For "Wife" pages, I use 12 hr am/pm.
Will that help tackle whatever you are trying to do?
Bill
My Plugin: My People
Sun Jun 06, 2021 2:48 pm
Almost certainly, but I would never even attempt it. You would be much better off not trying to mangle the strings, but converting the input string to a datetime object, then converting that back to a string with the format you want. To do that, forget that script even exists and just start from the two time strings you're working with (input and output).
Sun Jun 06, 2021 4:45 pm
ckeyes888 offline
The Clock Display plugin looks promising except I need the 24 hr time without the colon. e.g. 16:42 needs to be 1642.
Maybe use a script to remove the colon?
Carl
Sun Jun 06, 2021 5:01 pm
ckeyes888 offline
This script is also a part of my sprinkler system.
Any help converting it appreciated.
   set newDelay to the value of variable "TimerSprinklerStart" as real
   set newDelay to newDelay + 2200
   set the value of variable "TimerSprinklerStart" to newDelay
   set the value of variable "sprinklerTF" to "false"
end tell
Carl
Sun Jun 06, 2021 7:54 pm
whmoorejr offline
Carl
You can do that in the plugin....
Screen Shot 2021-06-06 at 8.50.12 PM.png (230.91 KiB) Viewed 2197 times
Bill
Sun Jun 06, 2021 8:29 pm
whmoorejr offline
end tell
Carl
newDelay = indigo.variables[123456789].value
newDelay = int(newDelay) + 2200
indigo.variable.updateValue(123456789, value=str(newDelay))
indigo.variable.updateValue(987654321, value="false")
With python, you use the ID number of the variable instead of the name. Line 1 grabs the value of the variable by number. Line 2 changes the value from the default (string) to an integer, adds the delay amount to the starting number. Line 3 overwrites the variable with the "newDelay" as a string. Substitute 123456789 with the ID number of "TimerSprinklerStart" and 987654321 to the ID number for "sprinklerTF" and you should be good.
Bill
Sun Jun 06, 2021 8:48 pm
ckeyes888 offline
All working great!
Thanks so much for the help!
Carl
