Converting Security script to Python
Wed Oct 28, 2020 4:51 am
macpro offline
I've been using an ancient version of the Security script for many years. And it looks like it is the last speedbump on my way to Indigo 7.4.
Basically I need to convert this to Python:
using terms from application "IndigoServer"
   on receive security event of eventType with code devID
      bla bla bla
   end receive security event
end using terms from
How can I do this?
Wed Oct 28, 2020 7:09 am
Re: Converting Security script to Python
What's a security event?
Or, a better question is, what does this actually do? If you disable this script, what happens (or doesn't happen)?
Wed Oct 28, 2020 7:24 am
macpro offline
See https://wiki.indigodomo.com/doku.php?id=x10_security_events for some details.
Basically it allows a running AppleScript to respond to events from X10 Security devices, like door/window sensors.
Wed Oct 28, 2020 7:27 am
Ok, so what's the answer to the second part of the question? What devices do you have that generate these events?
Wed Oct 28, 2020 7:56 am
macpro offline
X10 Security devices. Look door/window sensors, motion detectors etc..
They are not visible in Indigo as devices.
And when I disable that script, Indigo will no longer know if doors/windows are open or closed.
Wed Oct 28, 2020 8:54 am
WagnerOne offline
I'm going to be in this same boat when I try to upgrade. I am still using that old Security Script too. I looked into switching to Switchboard a few times, but never got around to it.
I have upwards of 20 EagleEye/ActiveEye MS13A/MS16A X10 motion sensors in my system. I've been replacing them slowly with z-wave sensors, but the types I have and want more of (I'm looking at you Dome) all seem to be in short/no supply the past many months.
All my X10 motion/door/etc. sensors talk to Indigo via a dedicated W800RF32 interface.
I used to have some DS10A dry contact sensors talking to the W800 too, but I've retired all those at this point. I basically cut the leads off the dry contacts I was using and wired in a Z-Wave Ecolink door/window sensors.
Other cheap X10 sensors like the MS10A worked with that script too.
This setup has been bulletproof and working flawlessly for decades at this point. The X10 sensors are super small/discrete, battery operated via 2xAAA batteries and are indoor/outdoor. Most importantly they are very inexpensive. Why would I want to pay for a "multi" sensor that I never use anything more than the motion capabilities of for $40 each when I can get 3 of these old X10 motion sensors for $20.
Wed Oct 28, 2020 9:25 am
Turns out there's an example plugin in the SDK that shows how to do this, sort of. Here's the relevant code:
   def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
      super(Plugin, self).__init__(pluginId, pluginDisplayName, pluginVersion, pluginPrefs)
      self.debug = True
   def startup(self):
      self.debugLog(u"startup called -- subscribing to all X10 and INSTEON commands")
      indigo.insteon.subscribeToIncoming()
      indigo.insteon.subscribeToOutgoing()
      indigo.x10.subscribeToIncoming()
      indigo.x10.subscribeToOutgoing()
   def shutdown(self):
      self.debugLog(u"shutdown called")
   def insteonCommandReceived(self, cmd):
      self.debugLog(u"insteonCommandReceived: \n" + str(cmd))
   def insteonCommandSent(self, cmd):
      self.debugLog(u"insteonCommandSent: \n" + str(cmd))
      self.debugLog(u"x10CommandReceived: \n" + str(cmd))
      if cmd.cmdType == "sec":   # or "x10" for power line commands
         if cmd.secCodeId == 6:
               indigo.server.log(u"SENSOR OPEN")
               indigo.server.log(u"SENSOR CLOSED")
      self.debugLog(u"x10CommandSent: \n" + str(cmd))
I don't know if the
call can be made in an external (always running) script, or if it has to be a plugin.
Wed Oct 28, 2020 9:34 am
macpro offline
Thanks. Will give that a go.
Wed Oct 28, 2020 9:50 am
FlyingDiver wrote:
I don't know if the
It has to be a plugin.
The Switchboard is available on Benjamin's github repo. I think it still works but I've never personally used it.
Wed Oct 28, 2020 1:07 pm
macpro offline
I've found the Switchboard plugin (thanks to Jay) and it seems to do the trick.
Still figuring out how to configure everything, but it looks like a can use it to replace the old Security script.
