Trying to convert...
Wed Jul 15, 2020 2:28 am
Umtauscher offline
Hi Guys,
I am sorry but my inability to come to terms with Indigo-Python leaves me with an unconverted Applescript again.
If anyone is able to convert this, I would very much appreciate any help.
# Indigo no longer supports execution of embedded AppleScripts. For help
# translating AppleScripts to python see: http://indigodomo.com/applescript
# The original AppleScript was:
# -- Set the value of a variable.
# -- If the variable doesn't exist, create it.
# tell application "IndigoServer"
#    if not (variable "AlarmScharf" exists) then
#       make new variable with properties {name:"AlarmScharf", value:false}
#    end if
#    do shell script "afplay /Users/wilhelm/Music/STARWAVE/c827.WAV"
#    if on state of device "Alarmsensoren ausgelöst" is true then
#       say "Alarmsensoren sind aktiv, der Alarm kann nicht scharfgeschaltet werden"
#    else
#       set value of variable "AlarmScharf" to true
#       say "Alarm ist scharf"
#    end if
# end tell
Thanks in advance
Wilhelm
Wed Jul 15, 2020 7:11 am
neilk offline
Re: Trying to convert...
Something like this (untested) and likely to have errors but to get you started.....
import os
    var = indigo.variables["AlarmScharf"]
except:
   indigo.variable.create("AlarmScharf", "false")
os.system("afplay /Users/wilhelm/Music/STARWAVE/c827.WAV")
if indigo.devices[u"Alarmsensoren ausgelöst"].onState == True:
   os.system('say "Alarmsensoren sind aktiv, der Alarm kann nicht scharfgeschaltet werden"')
   indigo.variable.updateValue(AlarmScharf, "true")
   os.system('say "Alarm ist scharf"')
Better if you use the device/variable ID's, not sure of the logic over the variable creation but if once created it stays then you can use the variable ID's instead
Wed Jul 15, 2020 8:55 am
Umtauscher offline
Thanks a lot Neil, and it looks so simple.... ;-)
I'd rather stay with variable names like in any other programming language.
Thanks again
Wilhelm
Wed Jul 15, 2020 9:36 am
That would be a non sequitur. We're not talking about variables in the sense of a programming language, but rather Variables as an Indigo object type which you reference by ID or name. Referencing an object by an immutable attribute like it's id is much safer than referencing an object by a mutable attribute like a name.
This applies to all other object oriented programming languages as well.
Thu Jul 16, 2020 10:37 am
neilk offline
Thanks again
Wilhelm
Not a problem, I should probably have added some comments, and I corrected an error I spotted editing the original post ( adding the 'u' due to the accented characters in your device name to declare it as unicode). In my defence I am English and we expect everyone else to speak our language, even if our America cousins get a little confused with the spelling :wink: Let me know if you need any help as any errors should be easy to flush out.
# the standard python 'os' module gives access to operating system capability, in this case I will use 'os.system' to execute the commands from your AppleScript
# this is really just fire and forget and assumes they run successfully, look into subprocess if you want greater control and feedback from the execution
# the import makes the 'os' module available to this script (probably an overly simplistic explanation, but it will do)
import os
# the python try/except block allows you to test some code for errors, and handle them if an error occurs, the indentation following the try and identifies the code either to be tried, or on error
   # in this case I am trying to set the variable 'var' to the value of the indigo variable "AlarmScharf", if the variable does not exist it will cause an error
except:
   # which is then caught in the except block on error, and the line below creates the indigo variable and sets the value to false, indigo variables  are strings
# os.system simply executes the command
# the if statement is pretty clear (and uses the same principle of indentation that was used in the try/except block)
# in the if statement you don't actually need the "== True", you can omit it as the device state is a boolean but it reads a little more clearly when new to python
# the 'u' is to identify the literal that follows is unicode, as your device name has accented characters
I am still a Python novice and get some of the basics wrong (like forgetting unicode), but I did follow Jay's advice and did one of the online tutorials (the free one from Microsoft https://www.youtube.com/watch?v=jFCNu1-Xdsw) and conversations I previously didn't follow now make sense, and I even managed to knock out a plugin or two with the help of the Indigo hive (especially Jay, Joe and Dave)
Neil
Fri Jul 17, 2020 3:17 am
Umtauscher offline
Just another short question:
How would I set "virtual On/Off device state" via python?
I cannot seem to find any special documentation for virtual devices.
Cheers
Wilhelm
Fri Jul 17, 2020 2:25 pm
If you're talking about the Virtual On/Off Device type in the Virtual Devices Interface, it depends on how you have it configured. If it's using a variable value for status, then you just set the Indigo variable value like you do any other Indigo variable. If you don't have it configured that way, you can execute an action group that has a Set Virtual On/Off Device State action in it.
Fri Jul 17, 2020 2:56 pm
Umtauscher offline
Hi Jay,
the backgroud of my question is the following:
I am using an action group to test some paramters and conditionally change a variable to switch the virtual device.
So starting this action group would change the state of the virtual device on certain conditions.
This works, when only using the device in Indigo.
But:
When I use the Homekit bridge, this is not working well, because the state in homekit is always changed - whether the virtual device changes or not. I found homekit only realizes the the switch doesn‘t occur, when I flip the state of the virtual device on and off again. Since the script decides the actual action, I have to do that inside the script. But I didn‘t find anything to set the virtual device state using python.
The virtual device has 2 action groups and a state variable.
Fri Jul 17, 2020 4:54 pm
Yeah, so it's easy, just update the variable value and the device state will follow.
Sat Jul 18, 2020 1:13 am
Umtauscher offline
So you are basically saying, changing the virtual device state from a pyton script is not possible.
I cannot set the variable because there are triggers on that which I don't want to fire just to flip the device state for a split second...
Anyways, thanks, I probably have to redesign that constuction.
Cheers
Wilhelm
Sun Jul 19, 2020 6:54 pm
No, that's not what I said:
I said it's the easy way, not the only way. You can execute an action group which has a Set Virtual On/Off Device State action to turn it on and then another one that turns it off after a 1 second delay. Note that it could then get out of sync with the variable value (if the variable is already set to "on" then it won't be in sync after the action).
