How do I calculate elapsed time?
Sat Jul 04, 2020 10:10 pm
gmusser offline
My old AppleScripts stored time as an integer representing the number of seconds elapsed since 1970, which made time calculations trivial. I'm having trouble porting these to Python. I looked at the delta-time calculation in the Indigo scripting tutorial, but I’m not grasping the data structure used to store time and how it should be manipulated. For instance, consider this code fragment:
I presume that "lamp" is what in C would be a struct, but then what is "timeDelta"? It looks like a struct, too, but (a) how can you subtract two numbers and get a struct? and (b) ".seconds" looks like a call to a conversion function rather than accessing one element of a structure. Python sure does use a lot of periods. (Clearly it would help if I sat down and learned the language properly!)
Anyway, here is my attempt at Pythonizing my AppleScript. The first script, triggered when my boiler turns on, logs the time. The second, triggered when the boiler turns off, logs the time, calculates the run time, and resets the relevant Indigo variable. I tried substituting the datetime.now() function for indigo.server.getTime(), but the result was the same.
Thanks for your help!
import os
# set up log file name
data_path = os.path.expanduser('~') + "/Documents/BoilerData-TEST.txt"
    # open log file
    with open(data_path, 'a+') as outfile:
        # set Indigo variable to current time
        now = indigo.server.getTime()
        indigo.variable.updateValue(79472523, value=unicode(now))
        # write the boiler startup time to the log file
        decimal = (now.hour * 3600.0 + now.minute * 60.0 + now.second) / (3600.0*24.0)
        outfile.write((u"{0:%m/%d/%Y}\t{1}\ton\r".format(now, decimal)))
except Exception as err:
    indigo.server.log("boiler monitor error: {0}".format(err))
import os
    # open log file
        # write the boiler shutdown time to the log file
        outfile.write((u"{0:%m/%d/%Y}\t{1}\toff".format(now, decimal)))
        # if we can calculate an elapsed time, do so
        startup = indigo.variables[79472523].getValue(int)
        if startup > 0:
                elapsed = now - startup
                # write elapsed time (in seconds) to the log file
                outfile.write((u"\t{0}\r".format(elapsed)))
                # reset variable to indicate the boiler is now off
                indigo.variable.updateValue(79472523, value=unicode(0))
                outfile.write((u"\r"))
Sun Jul 05, 2020 4:41 am
Re: How do I calculate elapsed time?
I don't know what a struct is, but in Python pretty much everything is an object. Dates and times (in Python: datetime) are datetime objects which have a lot of properties. If you print out a datetime object, the print function formats it into a standard POSIX time value:
import datetime
now = datetime.datetime.now()
print(u"{0}".format(now))
>>> 2020-07-05 05:28:50.901691
Taking the difference between two time values results in a timedelta object.
import datetime
from time import sleep
sleep(5)
then = datetime.datetime.now()
print(u"{0}".format(then))
diff = then - now
print(u"{0}".format(diff.seconds))
>>> 2020-07-05 05:31:02.896778
>>> 2020-07-05 05:31:07.903543
>>> 5
The timedelta object is still a datetime object, and has properties too.
In your example, 'lamp' is an Indigo device object (and has properties like 'onState'). For your second question, you're not subtracting two numbers and getting a struct, you're performing math on two objects and getting a new object. IMO, converting time to decimals is an unnecessary step.
If you want to work with POSIX dates that are stored as strings, Python has a way to handle that. Take a look at 'datetime.strptime' and 'datetime.strftime'. Oh, and the seconds since epoch (1/1/70) is also something that Python can handle easily.
https://docs.python.org/2.7/library/time.html
Sun Jul 05, 2020 4:42 am
p.s. datetime.now and indigo.server.getTime are the same thing. Indigo is providing a convenience method so you can just get the time from the server instead of importing datetime.
Sun Jul 05, 2020 10:11 am
gmusser offline
Thanks for clarifying. On the looking at the documentation, I see that the Unix timestamp (seconds elapsed since 1970) is available as the element ".timestamp". That avoids the need to use strptime and strftime to convert to and from strings. The site https://www.programiz.com/python-progra ... p-datetime provides this code fragment:
from datetime import datetime
now = datetime.now()
timestamp = datetime.timestamp(now)
But when I use that code in my script, Indigo returns the error "type object 'datetime.datetime' has no attribute 'timestamp'". This, even though I just copied and pasted the above code. Here is the full script as it now stands:
import os
    # open log file
        indigo.variable.updateValue(79472523, value=unicode(timestamp))
        # write the boiler startup time to the log file as mm/dd/yyyy with time as fraction of a day
Sun Jul 05, 2020 12:14 pm
datetime.timestamp() was introduced in Python 3--it's not available in Python 2.7. Be careful when Googling answers to Python questions because this will sting you every time. In my opinion, you don't need the timestamp at all. You can store the start time as a POSIX time just as easily and you'll still be able to do the math you need to do.
import datetime as dt
start_time = dt.datetime.now()
indigo.variable.updateValue(1612110734, dt.datetime.strftime(start_time, '%Y-%m-%d %H:%M:%S.%f'))
sleep(5)
stored_time = indigo.variables[1612110734].value
old_time = dt.datetime.strptime(stored_time, '%Y-%m-%d %H:%M:%S.%f')
now = dt.datetime.now()
diff = now - old_time
indigo.server.log(u"{0}".format(diff))
>>> 0:00:05.007182
Sun Jul 05, 2020 3:49 pm
ELWOOD offline
Have you looked at the "Timed Devices" plugin. One of the timer devices "Running Timer" will track on time of any device. I use it to keep track of my HVAC system, The plugin gives total on time for the heating and air-conditioning and I use a short script to calculate total cost per day, week, month and a total for the year.
Elwood
Sun Jul 05, 2020 6:56 pm
gmusser offline
@DaveL17 - thanks so much. With a bit more tweaking, I got the script to work.
@Elwood - I hadn't seen that; will take a look.
Sun Jul 05, 2020 7:01 pm
Glad you found something that works for you.
