Applescript to Python for IRED
Thu Dec 12, 2019 6:03 pm
lrego offline
Fellows, used the applescript below to send IR command thru IRED from ALEXA virtual device, as Applescript is not supported anymore in 7.4, is it possible to convert easily to Python?
Thank you in advance
Luis
# The original AppleScript was:
# log "Turn on Living TV"
# tell application "iRed2"
# perform uuid "45D04E80-B0CA-44B5-BE2A-54832BEFDEB4"
# end tell
Thu Dec 12, 2019 6:23 pm
Re: Applescript to Python for IRED
The easiest solution is to remove the log line then just move the rest of the script into an external script since it doesn't target Indigo.
