Replacing AppleScript with Restful URLs
Fri Nov 15, 2019 12:22 pm
Mark offline
I often control my devices from a computer using Keyboard Maestro. I find it very handy, and much faster, to have keyboard shortcuts to control various things (printers, lights, monitors, etc, all plugged into Insteon devices). I used to use AppleScript for this, but prepping for 7.4 I've replaced all my outside-Indigo AppleScripts with Restful URLs. So far so good, but I can't seem to find an example of of a Restful URL to turn on and off scenes.
I found a python example:
 indigo.insteon.sendSceneOff(54, sendCleanUps=True)
Is there a Restful URL for same?
Fri Nov 15, 2019 2:09 pm
Re: Replacing AppleScript with Restful URLs
There isn't currently a direct way to do that via a RESTful URL, but you could create Action Groups for the scenes you want to send and execute those.
Alternatively and what I would recommend, you could execute the python snipped you found using Indigo's Plugin Host command line, which I think you could call from a script inside Keyboard Maestro. If you need the full path then the indigo-host command can be found here:
/usr/local/bin/indigo-host
Fri Nov 15, 2019 5:23 pm
Mark offline
Thanks for the quick reply Matt. Interesting about the command line. I may fool with that. But I've got KM executing lots of Action Groups, so I'll likely stick with that MO, since I already know how to do that. I like to eliminate "subway stops" when I can, [keys -> executing KM macros ->executing Restful URLs -> executing Action Groups -> executing scenes] is a lot of stops! It's not that it doesn't work, but I have to be mindful of being able to remember how all that strings together in a month or a year (heck, in five minutes!) should something go wrong. Less is more, in this case. I was just looking to eliminate what stops I could.
Please put a request for firing scenes with Restful URLs on the wish list.
I'm now down to just one AppleScript that I can't seem to figure out how to replace. I'll create a new post with that issue...
I'll miss AppleScript support, but to be honest, I did manage to strip it all out with less trouble than I had anticipated. I didn't really want to learn a new language, but I have to admit Python is very clean, usually much simpler/shorter than AppleScript (and, of course, less buggy). I completely overhauled my entire system (new devices, new house, new modem, new functionalities, but simpler overall) and as I was rebuilding I just didn't transfer over anything that used AppleScript. I've got the house running like I want, and did so with a lot less junk (code) than I had before...
I've complained a lot here in the past about Insteon devices and their reliability, both lifespan and sending/receiving commands, but since I eliminated all the non-RF devices (at no small expense!) I finally have a house that works as I had envisioned. I went from about 70% reliable to very close to 100%. Too soon to tell about the longevity issue... fingers crossed...
Tue Jan 14, 2020 8:49 pm
Nidocamen offline
Hey Matt, is the indigo-host piece relatively new? (I'm guessing no but thought I'd ask lol)
On my system, indigo-host doesn't exist at /usr/local/bin
I'm on Indigo 6.1.9 on macOS Sierra (I know, I know, gotta upgrade lol)
Thx :)
Wed Jan 15, 2020 10:46 am
It was installed starting with Indigo 7.4.
Thu Jan 16, 2020 7:10 am
Nidocamen offline
Ok. The Restful stuff was implemented somewhat in Indigo 6, right? I can't recall where the docs were on the syntax / URL structure.
I just need to be able to exec some action groups and update variables and need to do it from outside of Indigo but not necessarily via AppleScript.
Thu Jan 16, 2020 10:06 am
Here's the REST API docs. Should work with Indigo 6 as well.
Fri Jan 17, 2020 9:16 pm
Nidocamen offline
Awesome, thanks! :)
