Convert script to Set Time Date and Season to Python
Sat Aug 24, 2019 9:34 am
wideglidejrp offline
The following is the last Apple Script in my system. It was cobbled together from various sources but, surprisingly, it has worked well for years. Any suggestions to simplify this into Python greatly appreciated.
set value of variable "pennwood_date" to (items 1 thru -7 of (date string of (current date)) as text) as string
# The text on the next line came from Niel
# (items 1 thru -7 of (date string of (current date)) as text) as string
# at https://discussions.apple.com/message/31262688?ac_cid=op123456#31262688
set value of variable "pennwood_day" to (weekday of (current date)) as text
set value of variable "pennwood_month" to (month of (current date)) as text
# The following lines were obtained from an Apple discussion group
# https://discussions.apple.com/message/31262688?ac_cid=op123456#31262688
set theDate to (current date)
set isoDate to theDate as «class isot» as string -- get current iso date/time
log isoDate
set value of variable "pennwood_time" to isoTimeTo12Hour(isoDate)
on isoTimeTo12Hour(isoDateString) -- convert 24-hour time to AM/PM
   set meridiem to " AM"
   set theHour to text 12 thru 13 of isoDateString as number
   if theHour = 12 then set meridiem to " PM"
   if theHour = 0 then set theHour to 12
   if theHour > 12 then set {theHour, meridiem} to {theHour - 12, " PM"}
   return "" & theHour & text 14 thru 16 of isoDateString & meridiem
end isoTimeTo12Hour
# end of script from Apple discussion group
set spring to {April, May}
set summer to {June, July, August}
set fall to {September, October, November}
set winter to {December, January, February, March}
if month of (current date) is in spring then
   set value of variable "pennwood_season" to "Spring"
else if month of (current date) is in summer then
   set value of variable "pennwood_season" to "Summer"
else if month of (current date) is in fall then
   set value of variable "pennwood_season" to "Fall"
else if month of (current date) is in winter then
   set value of variable "pennwood_season" to "Winter"
end if
John R Patrick
Author of
Home Attitude
Sun Aug 25, 2019 4:01 pm
Re: Convert script to Set Time Date and Season to Python
That script will take some effort to grok. Can you just tell us what you want the end result of the script to be (I can see some of it, but I don't really want to try and figure out what all the ISO stuff is about). My suspicion is that all it'll take is using the Python date/time formatters rather than parsing strings (dates are much easier to deal with in Python).
Sun Aug 25, 2019 6:49 pm
I think you are exactly right. The solution I currently have is much more complex than needed. The purpose of the script is to produce variables which I use for setting thermostats and providing input to Polly "good morning and good evening" announcements. The specific goal of the script is to produce the needed variables as show in the following screenshot. The format of the variables needs to be as shown.
Screenshot 2019-08-25 18.37.22.png (23.75 KiB) Viewed 4764 times
John R Patrick
Author of
Home Attitude
Sun Aug 25, 2019 7:30 pm
from datetime import datetime
now = datetime.now()
pennwood_date  = now.strftime("%A, %B %-d")
print pennwood_date
pennwood_day   = now.strftime("%A")
print pennwood_day
pennwood_month = now.strftime("%B")
print pennwood_month
pennwood_time  = now.strftime("%-I:%M %p")
print pennwood_time
seasons = {
    "January": "Winter",
    "February": "Winter",
    "March": "Winter",
    "April": "Spring",
    "May": "Spring",
    "June": "Summer",
    "July": "Summer",
    "August": "Summer",
    "September": "Fall",
    "October": "Fall",
    "November": "Fall",
    "December": "Winter"
pennwood_season = seasons[pennwood_month]
print pennwood_season
Replace the print statements with lines to set the appropriate Indigo variable. You have that from previous scripts. I used print to check the output.
See https://docs.python.org/2/library/datet ... e.datetime for the definitions of the formatters.
Mon Aug 26, 2019 8:03 am
Thanks very much. The Python script makes mince meat out of the Apple Script. It works perfectly. I looked through the reference link for Basic date and time types. Now I see the superiority of Python vs. Apple Script. AS is very simple but Python is incredibly comprehensive. I think I am AS free now but I will look through my action groups. There may be one or two lurking in there. Thanks again for the assistance.
John R Patrick
Author of
Home Attitude
Tue Jul 14, 2020 10:46 am
I have a converted Apple script for handling my thermostats. It works fine, but I want to streamline it with the addition of defined function. I am getting an indentation error on line six. I don't see what is wrong. It is the same as how I learned in tutorial. Any comments appreciated...
# Set thermostats to Heat if dining room temperature is less than 60 else set them to Cool
def finish_up():
    current_temp = float(indigo.variables[1451762256].value)
    indigo.server.log("Current temperature outdoors: " + str(current_temp))
    if current_temp < 60:
        indigo.thermostat.setHvacMode(1383655983, value=indigo.kHvacMode.Heat)
        indigo.thermostat.setHvacMode(1229008572, value=indigo.kHvacMode.Heat)
        indigo.thermostat.setHvacMode(1125058629, value=indigo.kHvacMode.Heat)
        indigo.thermostat.setHvacMode(1383655983, value=indigo.kHvacMode.Cool)
        indigo.thermostat.setHvacMode(1229008572, value=indigo.kHvacMode.Cool)
        indigo.thermostat.setHvacMode(1125058629, value=indigo.kHvacMode.Cool)
John R Patrick
Author of
Home Attitude
Tue Jul 14, 2020 2:43 pm
I don't see any syntax error - of course I can't execute it exactly as yours. Also, that script by itself does nothing - you actually have to call the function. Questions:
  1. Where is this function defined?
  2. Where are you calling it from?
  3. When do you get told that there's a syntax error?
Wed Jul 15, 2020 6:44 pm
This is a test of a function. It will be part of a much larger script. I can't get past this error about an indentation problem. I tried the script on my tutorial workspace and got the same error. I cannot find anything wrong with it, but Indigo and tutorial space flag the error.
def finish_up():
    current_temp = 60
    print(current_temp)
        mode = "Heat"
        mode = "Cool"
finish_up
print(mode)
print("The function has completed its job")
John R Patrick
Author of
Home Attitude
Wed Jul 15, 2020 7:56 pm
By making a few subtle changes to get it to run, this script runs without error for me.
def finish_up():
    current_temp = 60
    indigo.server.log(str(current_temp))
        mode = "Heat"
        mode = "Cool"
mode = finish_up()
indigo.server.log(mode)
indigo.server.log("The function has completed its job")
Hope this helps.
Thu Jul 16, 2020 8:03 am
Dave, your script doesn't return anything, so mode will always be None... ;)
Thu Jul 16, 2020 8:27 am
You're right Jay - I was just trying to replicate the OP's error (which I couldn't). This returns from the method.
def finish_up():
    current_temp = 60
        mode = "Heat"
        mode = "Cool"
    return mode
mode = finish_up()
   Script                          60
   Script                          Cool
   Script                          The function has completed its job
EDIT: Fixes typo.
Thu Jul 16, 2020 8:45 am
You sure you don't want:
def finish_up():
    current_temp = 60
        mode = "Heat"
        mode = "Cool"
    return mode
mode = finish_up()
Thu Jul 16, 2020 9:08 am
Yep, Joe's fixes my edit snafu. My post should be corrected now, too.
Thu Jul 16, 2020 2:16 pm
Thanks for that. With your changes, the script runs without error, but it does not print the mode. I made a few changes as shown here and it runs fine with no errors. My question, why did it work? The variables mode and current_temp are inside the function. I thought they had to be either global or returned in order to use them outside of the function. What am I missing?
def finish_up():
    current_temp = 50
        mode = "Heat"
        mode = "Cool"
finish_up()
John R Patrick
Author of
Home Attitude
Thu Jul 16, 2020 3:00 pm
If you're not using the last version that Joe posted, you're not getting everything as it should be.
Typically, variables defined in a method are exclusive to that method, so you need to "return" everything you need.
[*] as I understand Python--that is to say, incompletely--it is possible to create global variables within a method, but I think convention would say it's discouraged.
