Incrementing a variable and parsing string
Sun Mar 22, 2020 11:23 am
hamw offline
Re: Incrementing a variable and parsing string
Jay,
Thanks very much for your help with this parser. It's taken me some time... but now that I'm on COVID-19 lockdown I'm giving the Python another go. I've set the variables in and tried running it.
# Get the entire response string
vaux_response_string = indigo.variables[1925362107].value #VauxResponse variable
# I'm assuming that the list will always split into 5 items. This avoids setting
# each variable individually. If not, it can be done much like you do it in
# AppleScript by splitting into a list then just grabbing each item.
first_value, second_value, vaux_zone_number, vaux_bass_setting, vaux_treble_setting = vaux_response_string.split(",")
if "!s" in first_value.lower():
    # Get the boolean value of the logging variable and log if it's true
    if indigo.variables[767117833].getValue(bool): #vauxLogging_Enabled
        indigo.server.log(vaux_response_string)
if second_value == "40":
    # Log the zone and it's settings
    indigo.server.log("{}  {}  {}".format(vaux_zone_number, vaux_bass_setting, vaux_treble_setting))
    # This is a more Pythonic way of doing your zone number map
    zone_map = {
        "0": "Off",
        "1": "Kitchen",
        "2": "FamRm",
        "3": "Study",
        "4": "LivDnRm",
        "5": "GameRm",
        "6": "Patio",
        "7": "Pool",
        "8": "MBR",
    # Save off the current zone name for use later in case it doesn't change for some reason
    vaux_zone_variable = indigo.variables[519871620] #VauxZoneName
    temp_zone_name = vaux_zone_variable.value
    # If the zone number from the list is in the map's keys, save off the new name and set the Indigo variable
    if vaux_zone_number in zone_map.keys():
        temp_zone_name = zone_map[vaux_zone_number]
        indigo.variable.updateValue(vaux_zone_variable, value=temp_zone_name)
    # Create the string that's going to be set in the variable and logged
    new_string_value = "{}  Bass {}  Treble {}".format(temp_zone_name, vaux_bass_setting, vaux_treble_setting)
    # Set the Indigo variable
    indigo.variable.updateValue(1963098885, value=new_string_value)
    # Log the string
    indigo.server.log(new_string_value)
Currently returning this error:
Mar 22, 2020 at 1:12:56 PM
Simple Serial Plugin Response from serial device (text): !S,1,5,1,2,27,27,6,8
, of length 22 characters
Script Error Vaux Parser Python.py: too many values to unpack
Vaux Parser Python.py, line 6, at top level
ValueError: too many values to unpack
Error seems to be on this line:
Would appreciate your thoughts.
Sun Mar 22, 2020 11:32 am
Can you share the value of the variable that's accessed with:
Take for example, this code which runs without error:
x = "1,2,3,4,5,6"
a, b, c, d, e, f = x.split(',')
But this code results in the error you're seeing:
x = "1,2,3,4,5,6,"
Note the extra comma on the end of x.
Sun Mar 22, 2020 12:14 pm
hamw offline
Hi Dave,
Thanks for the look. Actually, this is the bass/treble parser, and I had hit the volume control, resulting in the error. When changing bass/treble it works fine. Yaay!
I am going to try to adapt Jay's script to the rest of the parser, and will report back.
Stay healthy!
Ham
Sun Mar 22, 2020 12:28 pm
Glad to hear that it's working for you.
Stay safe!
Sun Mar 22, 2020 8:15 pm
hamw offline
OK, I added a "parser selector" at the top to pick out the identifying number for whether the second variable represents an audio source/volume selection (1 or 2) or a bass/treble selection (4). In this way I was hoping to have an integrated script fire one or the other as listed below. However, while the second part (zone/volume, 1 or 2) seems to work, the first part will not fire. It does not throw an error. I tried inserting a log step to see if it was running at all but no. Any thoughts?
indigo.variable.updateValue(1524463060, str(vaux_response_string[3:4]))  #update parser selector
#first_value, second_value, vaux_zone_number, fourth_value, vaux_source_name = vaux_response_string.split(",") #vaux_volume_number1, vaux_volume_number2, vaux_bass_setting, vaux_treble_setting = vaux_response_string.split(",")
#if "!s" in first_value.lower():
#if indigo.variables[767117833].getValue(bool): #vauxLogging_Enabled
    #indigo.server.log(vaux_response_string)
#if second_value == "40": Parser_selector below picks first number of value, 4, and should execute this script if true.
if indigo.variables[1524463060] == "4":
       zone_map = {
           "0": "Off",
           "1": "Kitchen",
           "2": "FamRm",
           "3": "Study",
           "4": "LivDnRm",
           "5": "GameRm",
           "6": "Patio",
           "7": "Pool",
           "8": "MBR",
       new_string_value = "{}  Bass {}  Treble {}".format(vaux_zone_variable, vaux_bass_setting, vaux_treble_setting)
    # Log the string
#if second_value == "1":
if indigo.variables[1524463060].value ==  ("1" or "2"):
   first_value, second_value, vaux_zone_number, fourth_value, vaux_source_setting, vaux_volume_number1, vaux_volume_number2, vaux_bass_setting, vaux_treble_setting = vaux_response_string.split(",")
    # Log the zone and its' settings
       indigo.server.log("{}  {}  {}".format(vaux_zone_number, vaux_source_setting, vaux_volume_number1))
       zone_map = {
           "0": "Off",
           "1": "Kitchen",
             "2": "FamRm",
           "3": "Study",
           "4": "LivDnRm",
           "5": "GameRm",
           "6": "Patio",
           "7": "Pool",
           "8": "MBR",
       source_map = {
           "0": "Off",
           "1": "Tuner",
           "2": "iTunes",
           "3": "AirPlay",
           "4": "Cable",
       vaux_source_variable = indigo.variables[1890620001] #VauxSourceName
       temp_source_name = vaux_source_variable.value
       if vaux_source_setting in source_map.keys():
           temp_source_name = source_map[vaux_source_setting]
           indigo.variable.updateValue(vaux_source_variable, value=temp_source_name)
        vaux_volume_variable = vaux_volume_number1   #vauxZoneVolume
        indigo.variable.updateValue(1699344874, vaux_volume_number1)
        vaux_source_setting = indigo.variables[1890620001]
       new_string_value = "{}  {}  {} ".format(temp_zone_name, temp_source_name, vaux_volume_number1)
       indigo.variable.updateValue(1932988370, value=new_string_value) #vauxResponseOutputShort
    # Log the string
Mon Mar 23, 2020 5:00 am
I'm having a bit of trouble following your script.
You've got some stuff in there multiple times, for example I think you do this at least three times:
Moreover, I think the reason that the first bit isn't working as you expect is because you may have messed up your index reference. The index of [3:4] gives you the fourth element (by your note, that would be 'fourth_value'), when I think you want 'faux_zone_number' which would be index [2] not index [3].
Consider this:
a = [0,1,2,3,4,5]
print(a[3:4])
>>>[3]
Mon Mar 23, 2020 7:13 am
Consider this:
a = [0,1,2,3,4,5]
print(a[3:4])
>>>[3]
Actually '[3:4]' returns a list with one element, the fourth value in the original array. If you just want the value, and not a list containing that value, then you need to do just '[3]'.
To the OP -
Also, there's some logic errors in the code. For instance, you have:
I don't think this does what you think it does. It's doing a logical OR on two string variables (which always returns TRUE), then comparing that to a string value. Which will also always return TRUE (I think). What you probably wanted to write was:
if indigo.variables[1524463060].value in ["1", "2"]:
Which only evaluates as TRUE if the variable's value is "1" or "2".
Mon Mar 23, 2020 7:09 pm
hamw offline
Thanks very much. Yes, it would be much clearer if you had the strings!
The bass/treble string is: !S,40,2,5,4
where !S is always there to identify the string
40 = specifies bass/treble string. <--- this is what is picked out with the parser selector, "if indigo.variables[1524463060].value in ["1", "2"]:"
2 = zone
5 = bass level
4= treble level
The zone/source/volume string is : !S,1,3,1,3,27,27,2,8
!S = string identifier
1 = specifies zone/source/volume string <--- this is what is picked out with the parser selector, "if indigo.variables[1524463060].value in ["1", "2"]:"
3 = zone
1 = who knows
3 = Source
27 = volume
27 = volume (if stereo pair)
2 = bass for that zone
8 = treble setting for that zone
Note that the selector picks the first value, "4" or "1", which I figured was easiest. So the idea is to use the parser selector to pick the correct type of string and allow each section of the script to run, if true. I might just be able to split the trigger in to two separate ones.
Much appreciated!
Wed Mar 25, 2020 4:38 pm
hamw offline
Mis-labeled the second string above. Pls see that position 5 = source.
Also I was not clear that the reason the parsing blocks need to be separated is that when a string is returned it is of different lengths depending on if it is bass/treble control or source/volume control. As seen above, bass/treble is a 5 value string whereas source/volume is 9 values.
That's why this string for source/volume:
Response from serial device (text): !S,1,8,1,1,26,26,4,4
throws this error in the bass/treble section of the script:
Script Error embedded script: too many values to unpack
embedded script, line 15, at top level
Hence my trying to separate the blocks. I had it all set in AppleScript, and appreciate the help so far. I do have it working as two separate triggers with the blocks, both firing when the string changes. I tried to put the parser_selector lines into a conditional but no joy. So while it works and looks good on the phone, it throws an error from one of the triggers o the other every time.
Wed Mar 25, 2020 6:45 pm
It doesn't look like the error you posted matches up with the script above. Can you please post your latest version and the error message you get? It will help nail down the problem.
Thu Mar 26, 2020 8:31 am
Here is a general pattern you can use to process any messages that have the rough form you specified above:
# This is the format of the treble/bass string: "!S,40,2,5,4"
# This is the format of the zone/source/volume string: "!S,1,3,1,3,27,27,2,8"
# This will split off the first two items - the '!S' which
# is not used (junk) and the second element (command) which is what
# you'll use to decipher the rest of the string (details)
junk, command, details = vaux_response_string.split(',', 2)
# details now has the string after the second comma in it, for instance "2,5,4"
# Determine what to do next
if command == "40":
   # It's the treble/bass string, so we know that there will be
   # 3 items in the details
   zone, bass, treble = details
   # Do whatever you need to do with those values here
elif command == "1":
    # It's the zone/source/volume string, so we know there will
    # be 7 items in the details
    zone, unknown, source, volume, volume2, bass, treble = details.split(',')
The written description: take the first two elements off the string because we know that the first item is exactly the same and can be safely ignored. The second element will determine how we process the rest of the string. Once we know what the command format is, then we can split the rest of the string into it's component parts.
This relies on the messages being formatted EXACTLY as you have specified them. If that's always the case, then this framework should work correctly. You can add more by adding extra elif clauses for each additional command message that you receive and care to parse. If you get an error that mentions value unpacking, it means that the message wasn't constructed as you specified. So either it had fewer than 3 elements when doing the first split, or the details didn't have the correct number of elements that you're examples specified.
Sat Mar 28, 2020 9:11 am
hamw offline
Jay, Dave and Joe, thank you all for your interest in helping me through this. So far, the two scripts work correctly independently of one another when put in separate triggers. However since both triggers fire with the string variable change, while one will work correctly for the zone/volume and the other will work correctly with bass/treble, the other trigger will log an error.
I combined the two adapted scripts in the hopes that the selector text that Jay put in would allow the script to run the appropriate code:
if command == "1":
   vaux_zone_number, fourth_value, vaux_source_setting, vaux_volume_number1, vaux_volume_number2, vaux_bass_setting, vaux_treble_setting = details.split(",")
zone_map = {
    "0": "Off",
    "1": "Kitchen",
    "2": "FamRm",
    "3": "Study",
    "4": "LivDnRm",
    "5": "GameRm",
    "6": "Patio",
    "7": "Pool",
    "8": "MBR",
source_map = {
    "0": "Off",
    "1": "Tuner",
    "2": "iTunes",
    "3": "AirPlay",
    "4": "Cable",
    # Log the string
if command == "40":
   #indigo.server.log("{}  {}  {}".format(vaux_zone_number, vaux_bass_setting, vaux_treble_setting))
   vaux_zone_number,vaux_bass_setting, vaux_treble_setting = details.split(",")
   zone_map = {
    "0": "Off",
    "1": "Kitchen",
    "2": "FamRm",
    "3": "Study",
    "4": "LivDnRm",
    "5": "GameRm",
    "6": "Patio",
    "7": "Pool",
    "8": "MBR",
# Log the string
Here are the responses when setting source in the Game Room zone. The script runs correctly and both the zone/source/volume and bass/treble scripts run.
However, when trying to change the bass/treble, the script hangs on the zone/source/volume sections. So it looks like it is not passing over the zone/source/volume to execute only the bass/treble.
Mar 28, 2020 at 10:56:59 AM
>>>>>>>>>>>>>>>>Turn off Game Room
   Simple Serial Plugin            Response from serial device (text): !S,1,5,0,0,0,0,6,8
, of length 20 characters
   Script                          5  0  0
   Script                          GameRm  Off  0
   Script                          GameRm  Bass 6  Treble 8
   Simple Serial Plugin            Response from serial device (text): , of length 0 characters
>>>>>>>>>>>>>>>>>>>> Change Bass/Treble
   Simple Serial Plugin            Response from serial device (text): !S,40,5,6,7. <<<<<<<<<< 40 = bass/treble string, 5 = zone Game Room, 6 = bass setting, 7 = treble setting
, of length 13 characters
   Script Error                    Vaux Python Parser 200328.py: local variable 'vaux_zone_number' referenced before assignment
     Vaux Python Parser 200328.py, line 40, at top level
UnboundLocalError: local variable 'vaux_zone_number' referenced before assignment
>>>>>>>>>>>>>>>>> Again
   Simple Serial Plugin            Response from serial device (text): !S,40,5,6,6  <<<<<<<<<<< new string with change showing treble lowered to 6
>>>>>>>>>>>>>>>>> Again
   Simple Serial Plugin            Response from serial device (text): !S,40,5,6,5
>>>>>>>>>>>>change the volume once again. Now the script works correctly to process the zone/source/volume as well as bass/treble.
Mar 28, 2020 at 10:58:01 AM
   Simple Serial Plugin            Response from serial device (text): !S,1,5,1,1,29,29,6,5
   Script                          5  1  29.  <<<<<<<Zone Source Volume
   Script                          GameRm  Tuner  29 <<<<<<<<<<<<< Correct
   Script                          GameRm  Bass 6  Treble 5  <<<<<<<<  Correct
Overall the simplest thing to do is to ignore the problem, because I rarely change the bass/treble, but I'd like to get it to work if possible. Maybe the easiest thing is to just put these two separate scripts into different triggers with a conditional based the selector, but I could not figure out how to get to resolve to "true" to let the trigger execute.
Sat Mar 28, 2020 9:32 am
Fix this:
To this:
vaux_zone_name = vaux_zone_variable.value
Sat Mar 28, 2020 10:32 am
hamw offline
Thanks very much! However, after modifying the script, when changing the bass/treble it is still throwing the same error in the zone/source/volume section at line 40 up top, suggesting that it is not passing over that section despite the selector text being false.
if command == "1":
zone_map = {
    "0": "Off",
    "1": "Kitchen",
    "2": "FamRm",
    "3": "Study",
    "4": "LivDnRm",
    "5": "GameRm",
    "6": "Patio",
    "7": "Pool",
    "8": "MBR",
source_map = {
    "0": "Off",
    "1": "Tuner",
    "2": "iTunes",
    "3": "AirPlay",
    "4": "Cable",
    vaux_zone_name = zone_map[vaux_zone_number]
    # Log the string
if command == "40":
   zone_map = {
    "0": "Off",
    "1": "Kitchen",
    "2": "FamRm",
    "3": "Study",
    "4": "LivDnRm",
    "5": "GameRm",
    "6": "Patio",
    "7": "Pool",
    "8": "MBR",
# Log the string
Shouldn't this:
if command == "1":
cause it to skip to the next section if "if command ==1" is false? Does not appear to be working that way.
maybe a simpler thing would be to have two separate triggers. Is it possible to write that section as a trigger conditional, so if it resolves to true then the trigger executes? That way it would work with separate triggers. I tried inserting
if command == "40":
   pass
into a separate trigger conditional, but it throws this error: "
  Error                           failed to evaluate embedded script conditonal
   Error                           script did not return a valid boolean value
Sat Mar 28, 2020 10:52 am
Your indentation was totally inconsistent. It's the indentation that marks the limits of the "if" block. I cleaned that up, plus a bunch of other simplification:
zone_map = {
    "0": "Off",
    "1": "Kitchen",
    "2": "FamRm",
    "3": "Study",
    "4": "LivDnRm",
    "5": "GameRm",
    "6": "Patio",
    "7": "Pool",
    "8": "MBR",
source_map = {
    "0": "Off",
    "1": "Tuner",
    "2": "iTunes",
    "3": "AirPlay",
    "4": "Cable",
junk, command, vaux_zone_number, details = vaux_response_string.split(',', 3)
# details now has the string after the third comma in it, for instance "5,4"
if command == "1":
   indigo.server.log("{}  {}  {}".format(vaux_source_setting, vaux_volume_number1))
    indigo.variable.updateValue(1932988370, value="{}  {}  {} ".format(temp_zone_name, temp_source_name, vaux_volume_number1))
if command == "40":
    indigo.variable.updateValue(1963098885, value="{}  Bass {}  Treble {}".format(temp_zone_name, vaux_bass_setting, vaux_treble_setting))
