About this forum
Fri Sep 29, 2017 3:06 pm
About this forum
We've decided to create this forum for those that are starting down the road of converting AppleScript scripts to Python. If you have an issue, post a script snippit, explain the context in which the script is running, and we'll try to help you convert it. Note that rather than converting, we may identify a plugin that may help with part of the solution and may mean no coding at all. This is why it's important to not just post AppleScript code, but also explain how it's used and the context.
Reitering some details discussed elsewhere on the forums and in the blog post
It may also help to describe what the overall solution is that the AppleScript is solving is, so if you can describe the scenario that would be helpful as well.
In order to continue to help everyone understand what's going to work and what's not, we'll summarize here as well. AppleScripts that target the Indigo Server are the ones that will need attention. So if your script has a tell application "IndigoServer" in it will no longer work. Likewise, if you have an embedded script that targets any Indigo objects (embedded scripts don't strictly need to have a tell block in them) or execute commands, it will no longer work.
Here are some examples of things that won't work (not an exhaustive list):
turn on device "My Device Here"
set value of variable "My Variable" to "some value here"
make new variable with properties {name: "My New Variable", value: "the new value here"}
calculate sunrise
send email to "someaddress" with subject "My Subject" with body "My email body"
Just a few examples - anything in the Indigo Server's AppleScript dictionary will no longer work.
However, any script that talks to other applications will work. For instance:
tell application "iTunes
    # Any iTunes command
    play
end tell
will work fine when run from an external AppleScript file because it only targets iTunes. Likewise, if you have scripts that send curl commands, which is an easy way to integrate control of web-based services, those will continue to work as long as they don't attempt to talk to the Indigo Server:
do shell script " curl 'http://192.168.0.2/api/v1/runactivity' -d '{ \"activity_uuid\" : \"someidgoeshere\", \"toggle_state\" : \"on\" }' "
While that particular command can easily be done in Python as well, it will continue to work since it doesn't target the Indigo Server.
A Note about Embedded AppleScripts
While we have yet to make the final decision (we'll update this post when we do), we expect that you won't be able to embed AppleScripts any more, so the only way to execute them will be via an external script file. That's not likely to be a big deal to many of you since we've long warned everyone that external scripts are better because they don't have to run directly in the Indigo Server, but we just wanted to give you a heads up.
Wed Apr 04, 2018 7:36 am
McJohn offline
Re: About this forum
Question Jay;
We read in the latest news letter that the support of AppleScript in Indigo 7.2 is ending.
The question is: is this also for the external AppleScript file support or only for the embedded AppleScripts?
Thanks and kind regards,
John
Wed Apr 04, 2018 8:18 am
Colorado4Wheeler offline
I'm not Jay, but anything that targets the Indigo server will no longer be supported. There's a handful of posts about this, but here is a link to a reply Jay made regarding this.
Wed Apr 04, 2018 10:43 am
I've updated the OP to reiterate some of the details that we talk about in other places.
Wed Apr 04, 2018 12:55 pm
McJohn offline
Thank you both for your time and the clear explanation! :D
Tue Apr 24, 2018 2:56 pm
Jann offline
One Q: If I understand this correctly, Indigo WILL NOT listen for AppleScript anymore (ie: another external script saying “tell IndigoServer” but it will *still* run embedded AppleScript via osascript If ALL I'm doing is communicating w/other apps on that Mac?
ie: This would work: (it simply stores current Mac volume, sets it to 80, plays a sound that indicates house alarm is deactivated, and resets the volume to what it was PRIOR to playing the sound)
set original_volume to output volume of (get volume settings)
set volume output volume 80
do shell script "afplay '/Users/jgobble/Music/beeps/alarm_deactivate.aif'"
set volume output volume original_volume
Or is this not gonna work as an "embedded AppleScript" either?
I ask because I searched the XML of the indigo server database for "indigoserver" and found no locations in that file that have that string. I *only* use embedded AppleScript so this should've found it if i needed to worry about it, right?
side Q: Is there no easier way to play a sound?
Tue Apr 24, 2018 3:09 pm
Why not hedge your bets and just put that into an AppleScript file and then you can execute it from Indigo using my plugin or the AppleScript python library or an oascript shell call? All the indications I'm getting is "ditch AppleScript with Indigo" be that external references or embedded, I've decided to take this at its word and move all AS functions out of Indigo entirely and use the plugin I wrote to run them as needed or even embed it into python for a quick-and-easy method.
That being said, you do not target Indigo so if that script is external then it will work. If you put quotes around it and send it the python AppleScript library it will work, but having the AppleScript natively executed in Indigo likely will not.
Tue Apr 24, 2018 3:34 pm
Jann offline
I'd love to ditch them all, but that will have to be over time (a month or so) ...
What is the name of your plugin for running the script in a separate file? I know I can use osascript but it tends to hang... a lot!
Tue Apr 24, 2018 3:36 pm
Jann offline
also is it just "run shell" with "/usr/bin/osascript /path/to/my/applescript" if i decide to use osascript?
Tue Apr 24, 2018 3:57 pm
Embedded scripts won't run as they are now because those are run in the IndigoServer process. We haven't yet decided if we'll leave the edit box in there and just run the scripts via osascript or if we'll just require scripts to be external (which are already run via osascript - no reason to do it yourself).
You will run an external AppleScript the same way you always have - use the Execute Script action, point the action to an AppleScript. Nothing to change about that.
