Where how do I create the dummy device?
Tue Mar 05, 2019 12:34 pm
Sjack offline
I installed the plugin it is green under Plugins menu item.
The Installation notes, state that a "dummy" device type called Z-Wave Watcher will be create.
You should create a dummy device. If I create a new device the options do not show the ZWave Watcher device type.
So I'm stuck for now.
I'm trying to use the plugin to debug a Ecolink flood sensor.
Thank and regards,
Jacob
Tue Mar 05, 2019 12:43 pm
Re: Where how do I create the dummy device?
Hi Jacob
It should just be an option under New Device > ZWave Watcher > ZWave Watcher from memory.
There’s nothing fancy about it.
Tue Mar 05, 2019 5:03 pm
Screenshot
Tue Mar 05, 2019 8:05 pm
Sjack offline
Hi
That doesn't show up on my install see screenshots
I'm running Indigo 7.2 with the plugin v1.0.5 on MacOS Mojave 10.14.3.
I disabled other plugins I use Cynical Security Spy, iTunes.
Do I need to install enable something else?
Thanks and regards,
Jacob
No option to choose Z-Wave Watcher under Create New Device
Screenshot 2019-03-05 at 19.51.53.png (467.31 KiB) Viewed 3684 times
Wed Mar 06, 2019 1:17 am
In that case the plugin isn’t installed (correctly).
Sat Mar 09, 2019 9:38 am
Sjack offline
So where do I go from here? :?
I used this sequence:
I disabled the plugin, removed it from the system, downloaded the plugin from the plugin store.
Started the server, double clicked the plugin. got attached screenshot "Install....".
Clicked Install and Enable. Got confirmation that plugin was installed in the event log:
Mar 9, 2019 at 09:10:02
Installing and enabling plugin Z-Wave Watcher v1.0.5
Loading plugin "Z-Wave Watcher 1.0.5"
Starting plugin "Z-Wave Watcher 1.0.5" (pid 49607)
Started plugin "Z-Wave Watcher 1.0.5"
Z-Wave Watcher Debug startup called
As stated before the plugin shows green in the PlugIn menu item, see screenshot: " Z-wave...".
The example Z-wave Listener seems to work as I got some output from that in the event log:
Mar 9, 2019 at 09:36:18
Enabling plugin "Example Z-Wave Listener 1.0.0"
Starting plugin "Example Z-Wave Listener 1.0.0" (pid 49788)
Started plugin "Example Z-Wave Listener 1.0.0"
Example Z-Wave Listener Debug startup called -- subscribing to all incoming and outgoing Z-Wave commands
Mar 9, 2019 at 09:36:54
Example Z-Wave Listener Debug received: 01 14 00 04 00 06 0E 32 02 21 44 00 00 00 C2 01 2D 00 00 00 C2 9E (node 006)
Example Z-Wave Listener Debug received: 01 14 00 04 00 04 0E 32 02 21 44 00 00 00 C2 01 2D 00 00 00 C2 9C (node 004)
Example Z-Wave Listener Debug received: 01 14 00 04 00 06 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 8E (node 006)
Example Z-Wave Listener Debug received: 01 14 00 04 00 04 0E 32 02 21 54 00 00 00 00 01 2D 00 00 00 00 8C (node 004)
Example Z-Wave Listener Debug received: 01 10 00 04 00 06 0A 32 02 A1 42 2F C1 01 2D 2F C8 11 (node 006)
Example Z-Wave Listener Debug received: 01 10 00 04 00 04 0A 32 02 A1 42 2F F0 01 2D 2F FC 16 (node 004)
Example Z-Wave Listener Debug received: 01 10 00 04 00 06 0A 32 02 A1 4A 00 00 01 2D 00 00 10 (node 006)
Example Z-Wave Listener Debug received: 01 10 00 04 00 04 0A 32 02 A1 4A 00 00 01 2D 00 00 12 (node 004)
Thanks and regards,
Jacob
Z-wave watcher plugin green
Screenshot 2019-03-09 at 09.12.15.png (451.25 KiB) Viewed 3603 times
Install plugin "Z-wave Watcher"
Screenshot 2019-03-09 at 09.09.47.png (346.69 KiB) Viewed 3603 times
Sat Mar 09, 2019 6:08 pm
Can you right click the zwavewatcher.indugoplugin file in Finder, and ‘Show package contents’?
In /Contents/Server Plugin/ there should be devices.xml
Is that present?
Sun Mar 10, 2019 5:47 pm
Sjack offline
Thank you for your support.
Yes there is a devices.xml file and this is it's content.
<?xml version="1.0"?>
<Devices>
   <!-- This custom device illustrates how a plugin can update custom device
   states which can be used in Device State Changed triggers, conditionals,
   and inspected on Control Pages. The python runConcurrentThread() method
   will update the states every second.
   <Device type="custom" id="zwatch">
      <Name>ZWave Watcher</Name>
      <ConfigUI>
         <Field id="deviceId" type="menu">
            <Label>ZWave Device:</Label>
            <List class="indigo.devices" filter="indigo.zwave"/>
         </Field>
      </ConfigUI>
   </Device>
</Devices>
The content under Contents is:
File: Info.plist
Folder: Resources
       File: icon.png
Folder: Server Plugin
       File:  plugin.py
       File: devices.xml
The downloaded plugin also had a Thumbs.db file under resources, which I removed after the first install didn't work. I didn't expect removing the windows catch file would have an impact, but it seemed cleaner to me.
Thanks.
Sun Mar 17, 2019 1:57 pm
In that case we need Matt/Jay's help.
Your Indigo isn't working properly.
Peter
Sun Mar 17, 2019 4:05 pm
I'm not sure what could be going wrong here.
Quit and relaunch the Indigo client (Indigo 7->Quit menu). Does it then work?
If not, then stop and restart the Indigo Server (Indigo 7->Stop Server menu item). Does it then work?
Sun Mar 17, 2019 4:08 pm
Actually, I just remembered what this one is. Rename the file:
Server Plugin/devices.xml
to have a capital D:
Server Plugin/Devices.xml
and it will work. You have your HD formatted to be case sensitive. I generally recommend against that as it can cause subtle bugs like this to surface (not just in Indigo).
(Peter: can you update that file name in the project?)
Sun Mar 17, 2019 4:28 pm
Done.
v1.0.7 on the pluginstore.
