I am a user of Indigo since 2006
After install of the new 6.0.0 b5 demo the cynic securitySpy won't work at all.
OSX 10.7.5
SecuritySpy.indigoPlugin v. 1.1.0b4
SecuritySpy 2.2.4
This is the log:
- Code: Select all
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/cyin/asynplugin.py", line 40, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/cyin/plug.py", line 93, in __init__
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/cyin/plug.py", line 146, in check_compatibility
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/distutils/version.py", line 138, in __cmp__
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/distutils/version.py", line 40, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/distutils/version.py", line 107, in parse
<type 'exceptions.ValueError'>: invalid version number '6.0.0 b5'
This instead happens to the plugin SmartphoneRadar
- Code: Select all
File "plugin.py", line 86, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 428, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/Smartphone Radar.indigoPlugin/Contents/Server Plugin/iPresence.py", line 107, in indigoVersionIsAtLeast
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: '0 b5'
Smartphone Radar Error plugin runConcurrentThread function returned or failed (will attempt again in 10 second
Appears to be caused for both of us to an error in version control...
In addition SmartphoneRadar search a plugin in a folder of version 5. I also removed the plugin from folder, but i did not noticed any change in the error.
Thanks in advance
Piero
