Interesting. So it's persistent. (I assume you restarted the plugin already.)
Tell me what's in the Indigo log before the crash you show. And tell me what version of OS X you're using, and what version of Indigo.
Cheers
-- perry
Dewster35 wrote:There is nothing consistent that is happening BEFORE the trigger in the event log.
I believe it IS working... it's just puking out this error into the event log each time.
Dewster35 wrote:I did not have debugging turned on, but I did and I saw that I had some other triggers from when I was talking with you about "meeting" and being able to pull it out of context wherever it appears. I had a trigger in as *meeting*. I deleted that trigger and now all of the error messages are gone. I guess I was getting thrown because I didn't really think that for every ical event starting/stopping etc, it would go through each trigger. So the trigger I had was fine, but this other one was throwing a wrench into the works. Is there a way to identify which event/trigger there is an issue with for this type of error? That would help dial in to the root cause much quicker I guess.
Users browsing this forum: No registered users and 19 guests
