Perry,
I have an AVR-4810 and an AVR-4310. If you need help testing the plugin I'm willing to help!
Cheers, Bruno
Cynical Denon Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 51, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 49, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 95, in run
self._dispatch()
File ".../Server Plugin/asyn/controller.py", line 227, in _dispatch
top.callout(Ctx('TIMER', sched=top, control=self, when=top.when, now=now))
File ".../Server Plugin/asyn/core.py", line 140, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/denon/avr.py", line 440, in _cmdxmit
self.xmit_idle()
File ".../Server Plugin/denon/avr.py", line 412, in xmit_idle
self._next_discovery()
File ".../Server Plugin/denon/avr.py", line 391, in _next_discovery
self._schedule_discovery()
File ".../Server Plugin/denon/avr.py", line 372, in _schedule_discovery
self.callout('discover', 'done')
File "plugin.py", line 141, in _event
self.discovery(*args)
File "plugin.py", line 170, in discovery
self.proceed("on" if self.avr.main_power else "standby", recovered=True)
File ".../Server Plugin/cyin/devstate.py", line 155, in proceed
self.callout('change', self)
File ".../Server Plugin/cyin/devstate.py", line 118, in _base_change
self.start()
File ".../Server Plugin/cyin/devstate.py", line 398, in start
self.set_display_address("%s %s %s" % (self.hostdev.name, self.PARTNAME, self.subaddress))
File ".../Server Plugin/cyin/iom.py", line 453, in set_display_address
self.io.replacePluginPropsOnServer(props)
ValueError: ElementNotFoundError -- could not find device with element ID 10805398
wideglidejrp wrote:Having a problem getting control of my Denon AVR-3806. I am using a Startec RS232_1 to make the connection to my router. I did the same thing with my Russound receiver and it works great. For some reason I cannot get the port to be active on the second Startech. I have attached screen shot of the settings. They are the same as I use with the Russound, except for the IP address. The port shows as inactive. Any suggestions?
wideglidejrp wrote:I see your point about inactive unless something connects. The plugin connects but the result is that Denon is in Standby. I wonder if that is why I can't get it to do something. My test case is to set the volume to -100. It doesn't do anything. Maybe because the unit is in standby mode to the plugin. I don't know how to get it out of standby.
