SecuritySpy Plugin Crashes After Upgrading to Ventura
Mon Jan 09, 2023 5:51 pm
GRWilde offline
I just upgraded to Ventura and Indigo and all of my other plugins work fine - but the SecuritySpy plugin crashes. The SecuritySpy App itself works fine. I am getting the following error messages:
Cynical SecuritySpy Error Error in plugin execution InitializeMain:
File "plugin.py", line 26, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/spy/__init__.py", line 18, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/spy/core.py", line 26, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/asyn/http.py", line 40, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/asyn/ssl.py", line 27, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/asyn/vendor/OpenSSL/__init__.py", line 8, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/Cynical SecuritySpy.indigoPlugin/Contents/Server Plugin/asyn/vendor/OpenSSL/crypto.py", line 3268, in <module>
type: module 'lib' has no attribute 'OpenSSL_add_all_algorithms'
Anyone have any suggestions?
George Wilde
Sat Jan 14, 2023 4:57 pm
GRWilde offline
Re: SecuritySpy Plugin Crashes After Upgrading to Ventura
I found that the same terminal commands from bosy's post regarding the Cynical Weather v3.5.1 Crash also fixed the crash I experienced in Cynical SecuritySpy.
sudo pip3 install pyOpenSSL --upgrade
sudo pip3 install cryptography --upgrade
George Wilde
Sat Jan 14, 2023 6:53 pm
norcoscia offline
Strange since I run security spy w/o any issues (and have always run it) but I do have the Cynical Weather v3.5.1 issue after installing Cynical Weather.
_______
Norm
