SecuritySpy Plugin help needed
Fri Mar 23, 2018 8:08 pm
Villager offline
I would like to use a Fibaro Motion Sensor to control a PTZ camera with the Cynical SecuritySpy Plugin, but do not understand how to create a server device to represent my SecuritySpy installation in Indigo 7.1.1. I am using SecuritySpy 4.2.3 and it is working fine. I have read the SecuritySpy Plugin Overview but am unsure how to proceed with setup. Can you point me toward some very basic, step-by-step instructions to get me started with using the plugin?
Thanks for your help!
Ron
Fri Mar 23, 2018 9:05 pm
Re: SecuritySpy Plugin help needed
There's an Indigo device for the Security Spy server you need to create. The config is the same as for the web interface for SS. Provide the server IP, port number, username, and password.
Once the server device is working, you create a device for each camera you want to access/control. The device creation dialog will give you a popup list of cameras.
Sat Mar 24, 2018 2:59 am
Villager offline
Got it! Thank you for your help FlyingDiver.
