Leak Watch new issue
Sun Aug 06, 2017 7:50 am
george99 offline
Recently the leak watch start giving me false alarms. Once or twice a day, even though the leak sensors were not triggered.
Any ideas what could cause this?
Sun Aug 06, 2017 9:59 am
Re: Leak Watch new issue
How damp is the area where the sensor is? I had a leak sensor with the tip located in my sump well. The idea was that it would trip before the ground water reached the foundation. Over time, the continuous presence of moisture caused the sensor tip to fail.
Sun Aug 13, 2017 3:57 pm
george99 offline
Very dry. I have 11 sensors. It's a different one showing in the log that is triggering it each time.
Sun Aug 13, 2017 3:59 pm
george99 offline
Also, just to double check, I enabled individual triggers that don't use your plugin to cross check. So if one is triggered, I should get 2 alerts. One direct, and one thru your plugin.
I will update this post the next time I get an alert.
