Error Continues
Wed May 17, 2017 5:58 pm
Sharek326 offline
Error Continues
Currently using Cache Plugin Version 1.8.0 and I still get this error everyday until I reload the plugin and it stops until tomorrow. I have two WIFI Itachs and it happens with both of them. Any idea how I can get this to stop?
May 17, 2017, 7:52:52 PM
WebServer request to execute "V12MediaControl" control #8 from 192.168.1.10
Action Group Power
Cynical Caché Error in sendIR: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/irdev.py", line 123, in sendIR
self.gcdev.emit(symbol, action.count)
File ".../Server Plugin/ir/gcache/gcdev.py", line 122, in emit
task.transmit() # start transmission
File ".../Server Plugin/ir/gcache/gcdev.py", line 50, in transmit
self.seq = self.dev._transmit(self.ir, self.repeat)
File ".../Server Plugin/ir/gcache/gcdev.py", line 149, in _transmit
"%d,%d,%d,%d,%s" % (seq, ir.carrier, count, offset, ','.join(map(xlate, pulses))))
File ".../Server Plugin/ir/gcache/gcdev.py", line 82, in command
self.hostdev.command(','.join([cmd, self.address] + map(str, args)))
File ".../Server Plugin/ir/gcache/gcnet.py", line 131, in command
self.hostdev.write(cmd + '\r')
AttributeError: 'NoneType' object has no attribute 'write'
Z-Wave received "Media Room - Motion Sensor" status update is on
Action Group Power
Z-Wave received "Meter Total" power load to 1309.751 W
Z-Wave received "Meter Total" energy total to 25.836 kWh
Z-Wave received "Meter Clamp 1" power load to 571.785 W
Z-Wave received "Meter Clamp 2" power load to 737.966 W
Z-Wave received "Meter Clamp 1" energy total to 13.077 kWh
Z-Wave received "Meter Clamp 2" energy total to 12.759 kWh
Indigo Cocoa client authenticated (192.168.1.10)
May 17, 2017, 7:53:30 PM
Z-Wave received "Media Room - Motion Sensor" status update is off
Reloading plugin "Cynical Caché 1.8.0"
Stopping plugin "Cynical Caché 1.8.0" (pid 18120)
Stopped plugin "Cynical Caché 1.8.0"
Starting plugin "Cynical Caché 1.8.0" (pid 58662)
Cynical Caché API version 2.0
Cynical Caché Python version 2.7.10.final.0
Started plugin "Cynical Caché 1.8.0"
May 17, 2017, 7:53:59 PM
Action Group Power
Schedule Total Energy (Kwh) Today
