Audio Only trigger?
Tue May 16, 2017 6:18 am
mikejandreau offline
Audio Only trigger?
It doesn't look like I can trigger an event based on Audio detected from a camera, right?
Anyone have any workaround? I'm looking to set something up as a baby monitor, specifically for sound and was hoping to flash some lights or send a Push Notification (which SecuritySpy obviously can't do on its own).
Tue May 16, 2017 8:46 am
Gusten offline
Audio Only trigger?
I dont know what cameras you are using, but I know for example with Axis cameras with microphone you can make an event in the camera when sound is higher than set limit. This event can then send a tcp alarm to indigo using cynical plugin on the receiving end and use this as a trigger for indigo. If you use Axis cameras it will work if not maybe your cameras have something similar function
