Itach Error Daily
Thu Apr 06, 2017 6:00 pm
Sharek326 offline
Itach Error Daily
Every day for the past week I have to reset the Itach Plugin or I get this error. How can I correct this?
Cynical Caché Error in sendIR: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 58, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 68, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/irdev.py", line 123, in sendIR
self.gcdev.emit(symbol, action.count)
File ".../Server Plugin/ir/gcache/gcdev.py", line 122, in emit
task.transmit() # start transmission
File ".../Server Plugin/ir/gcache/gcdev.py", line 50, in transmit
self.seq = self.dev._transmit(self.ir, self.repeat)
File ".../Server Plugin/ir/gcache/gcdev.py", line 149, in _transmit
"%d,%d,%d,%d,%s" % (seq, ir.carrier, count, offset, ','.join(map(xlate, pulses))))
File ".../Server Plugin/ir/gcache/gcdev.py", line 82, in command
self.hostdev.command(','.join([cmd, self.address] + map(str, args)))
File ".../Server Plugin/ir/gcache/gcnet.py", line 131, in command
self.hostdev.write(cmd + '\r')
AttributeError: 'NoneType' object has no attribute 'write'
Tue Apr 18, 2017 6:51 pm
Sharek326 offline
Re: Itach Error Daily
This is still happening and requires me to have to reload the Plugin everyday. Has anyone else had this issue or know how I can solve it?
