Hello!
I need some help with the Cynical Network plugin.
I have soldered in a wifi to serial bridge in my Neato robot vacuum, it works very well.
I can now start the vacuum by sending "Clean" in the webconsole.
The websocket server is listening on port 81. Everything that you send via the websocket connection is directly sent to the serial interface and the results from the serial interface are returned via the websocket connection.
Tried to create a device in Indigo that connects to the websocket server, but nothing happends when i connect and try to send "clean" from Indigo.
Anyone who had tried this before?
Regards
Thomas Jakobsen
Norway
