Cynical Behavior reporting multiple errors on startup
Sun Dec 18, 2016 7:23 pm
maslett offline
Perry,
any idea why I am getting all the errors at startup as show below.
Thanks in advance, Mark
___________________________
Dec 18, 2016, 8:11:57 PM
Starting Indigo Server version 7.0.2 (Mac OS X 10.12.2)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7/Databases/76WildwoodSt.indiDb"
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 436)
Loading interface "INSTEON Commands 2.0.10"
Starting interface "INSTEON Commands 2.0.10" (pid 437)
Loading interface "Z-Wave 2.0.34"
Starting interface "Z-Wave 2.0.34" (pid 438)
Loading plugin "AD2USB Alarm Interface 1.5.3"
Starting plugin "AD2USB Alarm Interface 1.5.3" (pid 439)
Loading plugin "Alexa-Hue Bridge 2.0.2"
Starting plugin "Alexa-Hue Bridge 2.0.2" (pid 440)
Loading plugin "Cynical Behaviors 1.0.5"
Starting plugin "Cynical Behaviors 1.0.5" (pid 441)
Loading plugin "Dimmer Extender 1.1.1"
Starting plugin "Dimmer Extender 1.1.1" (pid 442)
Loading plugin "Harmony Hub 7.0.1"
Starting plugin "Harmony Hub 7.0.1" (pid 443)
Loading plugin "Meta Device 0.9.9"
Starting plugin "Meta Device 0.9.9" (pid 444)
Loading plugin "NEST Home 2 2.0.41"
Starting plugin "NEST Home 2 2.0.41" (pid 445)
Loading plugin "NEST Home 3 2.0.41"
Starting plugin "NEST Home 3 2.0.41" (pid 446)
Loading plugin "NEST Home 2.0.40"
Starting plugin "NEST Home 2.0.40" (pid 447)
Loading plugin "NOAA Weather Plus 1.1.17"
Starting plugin "NOAA Weather Plus 1.1.17" (pid 448)
Loading plugin "Pushover 1.1.3"
Starting plugin "Pushover 1.1.3" (pid 449)
Loading plugin "Randomized Lighting 0.0.5"
Starting plugin "Randomized Lighting 0.0.5" (pid 450)
Loading plugin "Survey Plugin 2.21"
Starting plugin "Survey Plugin 2.21" (pid 451)
Loading interface "Virtual Devices 2.0.2"
Starting interface "Virtual Devices 2.0.2" (pid 452)
Found disabled plugin "Airfoil Pro 1.0.6"
Found disabled plugin "DIRECTV DVR Control 1.1.1"
Found disabled plugin "EasyDAQ Relay Card 2.0.2"
Found disabled plugin "EPS - Scene Toggle 1.0.0"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Growl 2.0.1"
Found disabled plugin "Hue Lights 1.4.7"
Found disabled plugin "iCal Alarm Processor 2.0"
Found disabled plugin "iTunes 2.0.3"
Found disabled plugin "LIFX Bridge 7.0.0"
Found disabled plugin "Lutron RRA2/Caséta 7.0.0"
Found disabled plugin "NOAA Weather 2.0.0"
Found disabled plugin "SQL Logger 2.0.4"
Found disabled plugin "Timers and Pesters 2.0.1"
Found disabled plugin "Vera Bridge 1.0.10"
Found disabled plugin "WeatherSnoop 2.1.1"
Bonjour registered "Indigo - 76WildwoodSt"
Indigo Cocoa client connected
Harmony Hub Error Error in plugin execution InitializeMain:
File "plugin.py", line 10, in <module>
ImportError: No module named sleekxmpp
Stopping plugin "Harmony Hub 7.0.1" (pid 443)
Started interface "INSTEON Commands 2.0.10"
Started plugin "Action Collection 2.0.4"
Meta Device Log level preferences are set to "Normal".
Started interface "Virtual Devices 2.0.2"
Started plugin "Meta Device 0.9.9"
Started plugin "Pushover 1.1.3"
Pushover Debug startup called
Started plugin "Randomized Lighting 0.0.5"
Alexa-Hue Bridge Alexa-Hue Bridge initilizing . . .
Alexa-Hue Bridge No debugging requested
Cynical Behaviors API version 2.0
Cynical Behaviors Python version 2.7.10.final.0
Started plugin "NOAA Weather Plus 1.1.17"
Started plugin "Alexa-Hue Bridge 2.0.2"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Started plugin "Cynical Behaviors 1.0.5"
Started plugin "Dimmer Extender 1.1.1"
Started plugin "NEST Home 2 2.0.41"
NEST Home 2 ** Data Tracking Online **
Started plugin "NEST Home 3 2.0.41"
NEST Home 3 ** Data Tracking Online **
Cynical Behaviors Error error:
File ".../Server Plugin/cyin/plug.py", line 249, in deviceStartComm
iom.start_object(io, io.deviceTypeId)
File ".../Server Plugin/cyin/iom.py", line 171, in start_object
iom.start()
File "plugin.py", line 63, in start
self.setLed()
File "plugin.py", line 86, in setLed
if self.device.canSetLed(self.button):
File ".../Server Plugin/cyin/stddevice.py", line 79, in canSetLed
return ledno <= len(self.ledConfig) and self.ledConfig[ledno-1]
File ".../Server Plugin/cyin/stddevice.py", line 129, in ledConfig
config = self.buttonConfiguration()
File ".../Server Plugin/cyin/stddevice.py", line 119, in buttonConfiguration
reply = self.sendRaw([0x1F, 0x00], waitUntilAck=True)
File ".../Server Plugin/cyin/stddevice.py", line 58, in sendRaw
suppressLogging=suppressLogging and not cyin.DEBUG)
InterfaceError: interface INSTEON is not connected or enabled
Started plugin "NEST Home 2.0.40"
NEST Home ** Data Tracking Online **
AD2USB Alarm Interface Log level preferences are set to "Normal".
iom.start()
self.setLed()
Stopped plugin "Harmony Hub 7.0.1"
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
iom.start()
self.setLed()
Started plugin "AD2USB Alarm Interface 1.5.3"
AD2USB Alarm Interface Plugin setup completed. Ready to open link to the ad2usb in Basic mode.
iom.start()
self.setLed()
Meta Device Your plugin version, v0.9.9, is current.
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
Started plugin "Survey Plugin 2.21"
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
Started interface "Z-Wave 2.0.34"
iom.start()
self.setLed()
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem1411 (firmware 1.00)
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
AD2USB Alarm Interface ad2usb opened for communication at socket://127.0.0.1:15103
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
iom.start()
self.setLed()
Sun Dec 18, 2016 7:58 pm
Re: Cynical Behavior reporting multiple errors on startup
Is your INSTEON interface connected and working (can you control INSTEON modules from Indigo)? That seems to be what the plugin is complaining about.
Sun Dec 18, 2016 8:55 pm
maslett offline
Yes it's working fine. I only get this error messages when I start up. The plugin starts before the interfaces is initialized. Once the interface is up an running its works ok. Its like there needs to be a delay before the plugins are loaded
Mon Dec 19, 2016 9:56 am
norcoscia offline
I have the same issue - it happens until Indigo gets fully connected to the INSTEON interface - for some reason, it just takes a bit to long - I have been meaning to ask if there is an easy way to delay the loading of this plug-in to give Indigo a little more time to declare the INSTEON interface up?
_______
Norm
Tue Dec 20, 2016 6:05 am
maslett offline
It seemed to start when I upgraded to Indigo 7.
Tue Dec 20, 2016 7:10 am
norcoscia offline
Mine has been doing it for several months - well before my Indigo 7 update.
_______
Norm
Thu Dec 22, 2016 4:32 pm
Perry The Cynic offline
Cynical Behaviors hits up the INSTEON relay very early when it starts up (to read the state of all those blinkylights), and it turns out that Indigo doesn't wait until INSTEON is operational before it begins starting up plugins. I'll fix that once I figure out a good way to do that; meanwhile you can just ignore the errors (or reload the plugin if you're impatient) and it should be fine.
Sorry for the mess. My life's kinda interesting right now, so nonfatal issues like this go into a queue for a while. (It doesn't help that I usually don't actually restart the server ever unless I do release testing...)
Cheers
-- perry
Fri Dec 23, 2016 5:17 am
norcoscia offline
Thanks for the info Perry and no worries on the startup error - the only reason I mentioned it was I noticed another post about it - I hope all is well on your end and my best wishes for you and your loved ones this holiday season.
_______
Norm
