Cynical Denon and Indigo 7.0
Fri Dec 09, 2016 7:42 pm
brianlloyd offline
Looks like there might be some problems with Cynical Denon and the new version. The error, from the log is:
Cynical Denon Error in <lambda>: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
TypeError: <lambda>() takes exactly 1 argument (3 given)
Hoping to get my AV stuff back up and running under 7.0.
Fri Dec 09, 2016 10:41 pm
GlennNZ offline
Re: Cynical Denon and Indigo 7.0
Had the same issue with Cynical Cache
There was a new version which fixed it.
Check here:
http://www.cynic.org/indigo/plugins/
Download again - and try to update (the cache one did not have a clearly documented version)
Glenn
Sat Dec 10, 2016 11:49 am
brianlloyd offline
Yay! All working again. Thank you!
The "update" did not appear to take, at least in the case of Cynical Caché. Stopping and restarting the server fixed it. Since I had three of your plugins to update, I did that instead of stopping and restarting each one separately. So it appears that there may be an issue with "install and update".
