Did Indigo 7 Kill Cynic Plugin?
Fri Dec 02, 2016 5:45 pm
captcurrent offline
Since upgrading iam unable to control my Security Spy Devices When i try to move a camera I get
Cynical SecuritySpy Error in ptz_motion: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
TypeError: ptz_motion() takes exactly 2 arguments (4 given)
I tried the solution given in
viewtopic.php?f=25&t=17337
when I disable and restart the plugin in debug mode i get the following error on start up on the log
Cynical SecuritySpy Error [ERR] /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Cynical SecuritySpy-1.indigoPlugin/Contents/Server Plugin/spy/core.py:242: FutureWarning: The behavior of this method will change in future versions. Use specific 'len(elem)' or 'elem is not None' test instead.
Cynical SecuritySpy Error [ERR] if elem.find('address'):
huh?
anythoughts?
Fri Dec 02, 2016 8:29 pm
Swancoat offline
Re: Did Indigo 7 Kill Cynic Plugin?
I'm running Cynical Security Spy with Indigo 7 without issue.
http://nerdhome.jimdo.com
Fri Dec 02, 2016 8:40 pm
captcurrent offline
you are lucky going to strat writing scripts to recover lost capabilities
Fri Dec 09, 2016 7:08 pm
GlennNZ offline
HI
I had exactly the same issue with Cynic Cache - which had been previously working very well ( just discovered today)
Discovered - that was update (used normal download link - but had a lovely new version) which fixed the issue.
Perry - does mention elsewhere that he has updated all now - so perhaps a new version waiting for you to?
Glenn
Mon Dec 12, 2016 1:50 pm
captcurrent offline
Great. Glenn the reload did me good. Of course inread this after building a number of replacement scriptd. But still. Thanks fir the solution
