Will the Global Cache plug-in work with the Simple Control (aka Roomie Remote) versions of the iTach Flex?
Also, with the iTach IP2IR (or the Flex) can the plug-in be used for learning codes via the built-in IR receiver? I don't see a way to configure that.
(I have some iTach IP2IR units and also a few Simple Control/Roomie "Blasters" (re-labelled iTach Flex).
