iRule to Indigo
Sat Jan 02, 2016 10:23 pm
bbbullock offline
iRule to Indigo
I've read the on-line user guide for the Cynic Cache' plugin product and cannot figure out how to successfully get Insteon codes out of iRule and into Indigo. I have an iTach IP2IR device with one port configured as a "Sensor In" port. I'd like to send from iRule to that port directly and have it heard by Indigo. Do I have the correct iTach product to do this? If so, is there a simplified setup description that I can check on the iRule and Indigo side of the equation?
Sun Jan 10, 2016 3:08 am
Perry The Cynic offline
Re: iRule to Indigo
If you're trying to send IR symbols from Indigo, then the IP2IR is the right device, and you want to plug into that either a "bug" stuck on a particular device, or a "blaster" to fill a room with IR.
I'm afraid the "sensor in" feature is for reading dry contact digital signals; it is not for reading IR signals. (The IP2IR has an IR "learning" feature, but that can't really be used to "listen" to a room for IR symbols.)
If you're trying to recognize IR symbols sent by some other device (iRule or any other), then you need a GC-IRL (or GC-IRE) device plugged into a serial port, and the IP2IR won't do you any good. GC-IRL isn't an iTach product, though it could be plugged into an IP2SL if you're out of serial ports.
Cheers
-- perry
