rlust wrote:I have a new Insteon Wifi Camera 75790 that works with browser control. How do I configure it to work with Security Spy?
Thanks for any help!
I had the same issue and asked Ben the below worked for me.
The Insteon brand isn't officially supported (presently) on the Compatible Camera List available on the website here:
http://www.bensoftware.com/securityspy/ ... alist.html #header
However, some Insteon camera are rebrands of OEM Foscam models;
So you can try the Foscam JPEG and Foscam H.264 (selecting H.264 under its "Format" menu) in the 30 day demo of the latest version of SecuritySpy v3(.4.
demo available here:
http://www.bensoftware.com/securityspy/SecuritySpy.dmgIf you've already tried these, you may simply need to enter the cameras HTTP and RTSP Port No's (as could be different from Foscams) in the above Foscam Device type's.
These should be available directly on the camera (firmwares) web interface.
Finally, you could try the ONVIF Device type, clicking its "Get Profile LIst" button to auto-configure it for the camera (camera/firmware is ONVIF compliant).
