Am using b10 and plugin 1.4.1.
- Code: Select all
3 Jul 2013 07:54:43
Trigger Alarm Set
Cynical SecuritySpy Error in runConcurrentThread: Traceback (most recent call last):
File ".../Server Plugin/cyin/debugging.py", line 46, in diagnostic_log
yield
File ".../Server Plugin/cyin/debugging.py", line 56, in diagnose_call
return method(*args, **kwargs)
File ".../Server Plugin/cyin/asynplugin.py", line 51, in runConcurrentThread
self.run()
File ".../Server Plugin/asyn/inject.py", line 49, in run
asyn.Controller.run(self)
File ".../Server Plugin/asyn/controller.py", line 91, in run
item._can_read()
File ".../Server Plugin/asyn/selectable.py", line 208, in _can_read
self._scan(input)
File ".../Server Plugin/asyn/scan.py", line 51, in _scan
self.callout(RAW, self._rbuf)
File ".../Server Plugin/asyn/core.py", line 140, in callout
results = [cb(ctx, *args) for cb in list(self._callbacks)] # latch callback list
File ".../Server Plugin/asyn/http.py", line 284, in incoming
super(Request, self).incoming(ctx, *args)
File ".../Server Plugin/asyn/selectable.py", line 364, in incoming
self._scan(data)
File ".../Server Plugin/asyn/scan.py", line 54, in _scan
result = self.scan.scan(self._rbuf, self.callout)
File ".../Server Plugin/asyn/scan.py", line 105, in scan
callout(ctx, *m.groups())
File ".../Server Plugin/spy/core.py", line 201, in reply
self.cameras[cnum]._event_tap(ctx, *args[3:])
File ".../Server Plugin/spy/core.py", line 314, in _event_tap
self.callout(ctx, *args)
File "plugin.py", line 161, in _event
self.setup() # pick up any changes
File "plugin.py", line 139, in setup
self.spy_camera.add_callout(self._event)
File ".../Server Plugin/asyn/core.py", line 91, in add_callout
self._callbacks.append(callee)
MemoryError
Cynical SecuritySpy Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
The alarm unset trigger (turning camera passive) logs very similar events.
Any suggestions? Thanks.
