Live feed
Thu Oct 27, 2022 4:43 pm
haakon offline
Live feed
Thank you for a great plugin!
I am using it to fetch data from Tibber, a Scandinavian power company. Their API can provide historical as well as live data. I can get the former to work with GhostXML, not the latter. It it possible to get live data using GhostXML? (I'm a newbie when it comes to coding, so please excuse me if the question is poorly worded.)
By using a raw curl string I am able to get this to work:
curl \
-H "Authorization: Bearer 96a14971-525a-4420-aae9-e5aedaa129ff" \
-H "Content-Type: application/json" \
-X POST \
-d  '{ "query": "{  viewer {    homes {      consumption(resolution: HOURLY, last: 12) {        nodes {          from          to          cost          unitPrice           consumption        }      }          }  }}" }'
When I try to replace the query with the following (that works well in Tibbers API explorer), I get a syntax error from GhostXML. (I keep the line breaks for readability:)
subscription{
  liveMeasurement(homeId:"96a14971-525a-4420-aae9-e5aedaa129ff"){
    timestamp
    power
    accumulatedConsumption
    accumulatedCost
    currency
    minPower
    averagePower
    maxPower
So is it possible to get a subscription query like this to work? If that is the case, how should it be input?
Thu Oct 27, 2022 5:21 pm
Re: Live feed
Glad you're finding the plugin useful. Are you using the raw curl method? That should work with the API call. There's an example to follow in the plugin documentation.
Screen Shot 2022-10-27 at 6.15.53 PM-2.png (211.31 KiB) Viewed 2635 times
