Hopefully plugin related?
Posted: Fri Feb 25, 2022 8:11 pm
I'm trying to access a page that every script I've written either does nothing or I get an SSL certificate error.
I am playing an Alexa Routine Trigger URL.
https://www.amazon.com/Virtual-Smart-Ho ... 104&sr=1-2
Once I create a fake "doorbell", I can trigger it in alexa by loading a webpage. Each fake "doorbell" device gives me 3 web address to use
Tonight I tried setting it up as a GhostXML Device (Real Type). Feed JSON, Manual Refresh. Past that point, I've not sure. bearer has gotten me the closest to success "GUI turns green" but no data is parsed (which I don't care about), and the alexa device on the other end doesn't respond (which I do care about).
I'm not sure if your plugin is the solution to my problem or if I have to figure out a scripting solution. I'm drawing a blank across the board.
- Code: Select all
HTML Response: https://www.virtualsmarthome.xyz/url_routine_trigger/activate.php?trigger=1234_substiute_for_my_trigger&token=4321_substitute_for_my_token&response=html
XML Response: https://www.virtualsmarthome.xyz/url_routine_trigger/activate.php?trigger=1234_substiute_for_my_trigger&token=4321_substitute_for_my_token&response=xml
JSON Response: https://www.virtualsmarthome.xyz/url_routine_trigger/activate.php?trigger=1234_substiute_for_my_trigger&token=4321_substitute_for_my_token&response=json
