Help: Bearer Authentication
Fri Nov 06, 2020 4:33 pm
roquej offline
I am trying to get GhostXML working with Bearer Authentication, but a bit lost. Please, know I am not a programmer, just a tinkerer.
To test the issue, I wrote this piece of code, which kind of works
import simplejson as json
import urllib2
from base64 import b64encode
import datetime
#import value from indigo variable
token =  indigo.variables["AWAir_token"].value
AWAir_Family_deviceID =  indigo.variables["AWAir_Family_deviceID"].value
url = "https://developer-apis.awair.is/v1/users/self/devices/awair/" + AWAir_Family_deviceID + "/air-data/latest?fahrenheit=true"
#get DEVICE Data in json from api url
request = urllib2.Request(url)
request.add_header('Authorization', 'Bearer ' + token)
#get TOKEN in json from api url
   urlReturned = urllib2.urlopen(request)
except:
   indigo.variable.updateValue("awair_family_status", value="Could not retreive Family data")
   indigo.server.log ("awair_family_status = " + "Could not retrive Family")
   exit(0)
#format api returned data
data_getStatus = urlReturned.read()
#interpret json
   dict = json.loads(data_getStatus)
except:
   indigo.variable.updateValue("awair_family_status", value="error json.loads(data_getStatus)")
   indigo.server.log ("awair data_getStatus = " + "error json.loads(data_getStatus)")
   exit(0)
#temperature
   awair_family_0_temp=dict[u'data'][0][u'sensors'][0][u'value']
except:
   indigo.variable.updateValue("awair_family_status", value="error parcing TEMPERATURE")
   indigo.server.log ("awair_family_0_temp = " + "error parcing TEMPERATURE")
   exit(0)
awair_family_0_temp=str(round(awair_family_0_temp,1))
GhostXML using "Token" is asking for "token URL" and "token password", for which I am not sure what to use.
Thank you in advance.
JP
Fri Nov 06, 2020 7:33 pm
Re: Help: Bearer Authentication
I don't think that the token auth option will work for you. A quick Google shows that Bearer authentication requires a different token payload than we're using. That said, adding it into the plugin shouldn't be a huge lift.
I don't have a good way to test the changes so I will need some help with testing any new features.
Fri Nov 06, 2020 8:01 pm
roquej offline
Anything to help. Just point the way!
Sat Nov 07, 2020 9:20 am
This may not be exactly right, but it should be close. This is the first part of your script rewritten to follow the format of the plugin structure. Please run the script and post (or DM) the results.
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import subprocess
import json
glob_off = ''
curl_arg = 'curl -vskX' + glob_off + ' GET ' + url + ' -H "accept: application/json" -H "Authorization: Bearer "' + token
proc = subprocess.Popen(curl_arg, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
reply_in = proc.communicate()
reply    = json.loads(reply_in[0])
indigo.server.log(u"{0}".format(reply))
Sat Nov 07, 2020 9:27 am
roquej offline
Here you go:
Nov 7, 2020 at 10:26:38 AM
Script {u'data': [{u'indices': [{u'comp': u'dust', u'value': 4.0}, {u'comp': u'humid', u'value': 1.0}, {u'comp': u'co2', u'value': 0.0}, {u'comp': u'temp', u'value': 0.0}, {u'comp': u'voc', u'value': 1.0}], u'timestamp': u'2020-11-07T15:26:34.000Z', u'sensors': [{u'comp': u'humid', u'value': 53.310001373291016}, {u'comp': u'temp', u'value': 78.0980010986328}, {u'comp': u'voc', u'value': 397.0}, {u'comp': u'dust', u'value': 75.30000305175781}, {u'comp': u'co2', u'value': 661.0}], u'score': 70.0}]}
Sat Nov 07, 2020 9:38 am
That's awesome. I think we're going to be able to make it work. I'll be in touch. :D
Sat Nov 07, 2020 9:59 am
roquej offline
Sat Nov 07, 2020 10:01 am
Super easy if you're using the requests lib:
headers = {"Authorization": "Bearer {}".format(token), "accept": "application/json"}
reply = requests.get(url, headers=headers)
Sat Nov 07, 2020 1:22 pm
Thanks Jay. We're using curl for all the calls. I don't remember why we chose curl over requests, but I know we had a super solid reason. :D
Sat Nov 07, 2020 2:10 pm
This Pre-Release of the GhostXML plugin (v0.5.0.03) includes the first crack at bearer authentication. To use it, create a new device and select 'Bearer' as the authentication method and enter the token value in the appropriate field.
For your specific construction (getting a device id out of an Indigo variable), select 'Use Substitutions' and enter the variable ID in the appropriate field. With substitutions, your source URL would be something in the neighborhood of:
https://developer-apis.awair.is/v1/users/self/devices/awair/[1]/air-data/latest?fahrenheit=true
The revisions are tested against an authentication response service but obviously not for your specific service.
Sat Nov 07, 2020 7:08 pm
roquej offline
Dave,
First, you are awesome!! Second, can’t get it to work:
Using “https://developer-apis.awair.is/v1/users/self/devices/awair/4832/air-data/latest?fahrenheit=true” - the correct info for the URL, which the same in the code but config dialog has an error.
Any suggestions?
JP
Sat Nov 07, 2020 7:21 pm
roquej wrote:
Dave,
Any suggestions?
JP
What is the config dialog error? I entered your info in a device and didn't get an error.
Things to try: ensure that you don't have any extra spaces in the field and check to see if you may have accidentally entered the url in more than once into the field (happens to me all the time).
Sat Nov 07, 2020 7:42 pm
roquej offline
Never mind, I was using my iPad to connect to the mac-min and the iPad seem to have caused issues with the copy and paste. Switch to the Macbook Pro and all good now.
AND it works great. Thank you!
You rock!
Sat Nov 07, 2020 8:10 pm
roquej offline
Ok - another quick question. Out of the values provided, by the JSON, they move...is this normal? What I man is that index 0, sometimes is temp, but later is co2, and later is dust. Is that normal behavior?
If it is, what would be the best way to always find temperature, even if it changes index position?
JP
Sat Nov 07, 2020 8:34 pm
Yes, that's normal behavior and one of the things that the plugin is meant to handle. Without getting super technical, the incoming json includes data structures that can change (mutable) and depending on the source -- varying. That's part of the reason for the Ghost part. :D
What do the custom states for the device look like?
Screen Shot 2020-11-07 at 8.32.43 PM.png (90.24 KiB) Viewed 3412 times
