Meteobridge Weather XML
Thu Oct 03, 2019 11:14 am
Re: Meteobridge Weather XML
forestfield wrote:
How about 1 line...
Assuming wind direction is in a python variable called dir, then
wind_direction = ['N','NE','E','SE','S','SW','W','NW'][int(((dir+22.5)%360)/45)]
should be about right, assuming you want 8 compass points
Elegant! Mind if I steal that?
Thu Oct 03, 2019 11:34 am
norcoscia offline
So I created a variable named dir, then push the value into it and then when I try to put that line into a script and I get this error - do I need to convert the direction value to a float or is something else wrong?
Also, do I need to create a variable named wind_direction or will the script do that by itself?
Help...
_______
Norm
Thu Oct 03, 2019 11:41 am
Help...
You need to create the Python variable 'dir' based on an Indigo variable, and then you need to store the Python variable wind_direction into the appropriate Indigo variable.
Thu Oct 03, 2019 11:45 am
norcoscia offline
I created the dir variable in the first part of the trigger (below)
I don't understand how to store the python variable into an indigo variable or how that will fix the error in the script?
_______
Norm
Thu Oct 03, 2019 11:56 am
Python variables are not Indigo variables. You stored a state into an Indigo variable. That does not create a variable in the Python script.
Read the Variables section of https://wiki.indigodomo.com/doku.php?id ... g_tutorial
In this case, you don't even need the Indigo 'dir' variable. Change the device number to match your meteobridge device.
dir = int(indigo.devices[623595257].states["WIND_dir"])
newVar = indigo.variable.create("wind_direction", "-")
indigo.variable.updateValue(newVar, "wind_direction")
Thu Oct 03, 2019 12:08 pm
norcoscia offline
Thanks Joe - I will read it (and try to understand it) - appreciate the help!!!!
_______
Norm
Thu Oct 03, 2019 2:41 pm
forestfield offline
Feel free to steal... It's something I did ages ago when I was working on a libellium weather station.
Everyone else - I didn't know where the original wind direction was coming from - and I did n't want to overcomplicate, so thanks for the extra input.
Thu Oct 03, 2019 3:32 pm
Thank you! Stolen.
