New Plugin: GhostXML
Fri Jan 05, 2018 7:01 am
Re: New Plugin: GhostXML
Thanks Deuan. I'm virtually certain that's what's causing the error you're seeing. I think the schedule is calling for the device to be updated before the last request has finished. As a test, please try upping the refresh time by 1 second and try again. Continue to add 1 second to the schedule until the error no longer appears and let me know what that time is. The way the plugin is written, it adds refresh calls to a queue and processes them in turn. So if a condition exists where each refresh cycle takes longer than the requested refresh, the plugin will never be able to catch up.
That said, it should do better at handling this condition--I'll do some more digging and see what I can do for a more graceful solution.
Dave
Fri Jan 05, 2018 7:09 am
Scratch that. Please stand by. I'm able to reproduce the error and need to do some more digging.
Looks like there's a bug.
Fri Jan 05, 2018 7:22 am
Yep, there is a bug in the call to manually refresh an individual device. I think I've got it ironed out and will post a fix soon.
Sorry for the troubles and thanks for calling the error to my attention. Cheers!
Fri Jan 05, 2018 9:28 pm
I've just uploaded a fix for this bug. Manual refresh should be working now. Please let me know if that's not the case.
There's a few other things included in the update.
Fri Jan 05, 2018 11:12 pm
deuan offline
Great, So far so good.
Back to refreshing every 5 seconds and no errors. Great Work!
Deuan
Sat Jan 06, 2018 5:14 am
Good deal. Thanks for letting me know.
Sun Mar 18, 2018 9:08 am
hamw offline
I currently control my Digital Loggers IP power switch with a quick applescript as below, using a variable substitution trigger to execute the commands. However, since it's one way so I don't know actual status. And, since it is an applescript.... :cry:
using terms from application "IndigoServer"
set actionOrdered to the value of variable "Digital_Loggers_Switch"
set actionListAll to {"1=ON", "1=OFF", "1=CCL", "2=ON", "2=OFF", "2=CCL", "3=ON", "3=OFF", "3=CCL", "4=ON", "4=OFF", "4=CCL", "5=ON", "5=OFF", "5=CCL", "6=ON", "6=OFF", "6=CCL", "7=ON", "7=OFF", "7=CCL", "8=ON", "8=OFF", "8=CCL"}
if actionListAll contains actionOrdered is true then
log actionOrdered & " the list works"
set theIP to "http://usesr:pwd@10.0.1.XX:XXXX/outlet?" --change your ip and command string here
set theURL to theIP & actionOrdered
--log theURL --comment this out once it is working
set curlURL to "curl -k" & " " & theURL
set shellscript to curlURL
--log shellscript -- commment this out once it is working
do shell script shellscript
set value of variable "Digital_Loggers_Switch" to "x"
end if
end tell
end using terms from
I'd like to use the GhostXML plugin to generate device states so it is more controllable and I can then also get feedback. I looked at the documentation and found these links. I've tried setting up a GhostXML device, and while it does establish a link, as I can't seem to find the correct http xml URL it's generating a parse error. Any suggestions would be appreciated. If it is not possible, could I ask for a little help in converting this to a python script...
https://www.digital-loggers.com/http.html
https://www.digital-loggers.com/restapi.pdf
Sun Mar 18, 2018 11:49 am
I reckon the following should get the socket names and states for all sockets:
http://192.168.0.100/restapi/relay/outlets/all/state/=name,physical_state/
Add a GhostXML device, set it to JSON, tick the "Would you like to use Digest Auth in this URL?" then enter your username and password in the boxes which appear (scroll the dialog box - they aren't visible to start with).
Peter
Sun Mar 18, 2018 1:49 pm
Thanks Peter, for responding and hamw, please let us knowhow you get on.
Sun Mar 25, 2018 9:22 am
hamw offline
Thanks for the suggestions. I did enter the string but while it will hook up to the device, it now generates a "no data to return." Any thoughts?
Sun Mar 25, 2018 11:54 am
Can you please turn on debugging and post the log data? Be sure to delete any usernames, passwords or API keys.
Sun Mar 25, 2018 9:11 pm
hamw offline
Here you go:
   GhostXML Debug                  Time since update (17) is greater than configured frequency (15)
   GhostXML Debug                  Queue task 409167487 sent to thread 409167487 - Digital Loggers Switch
   GhostXML Debug                  refreshDataForDev() method called.
   GhostXML Debug                  Found configured device: Digital Loggers Switch
   GhostXML Debug                  Refreshing device: Digital Loggers Switch
   GhostXML Debug                  getTheData() method called.
   GhostXML Debug                  *   Trying 10.0.1.xx...
* TCP_NODELAY set
* Connected to 10.0.1.xx (10.0.1.xx) port xxxx (#0)
* Server auth using Digest with user 'xxxxx'
> GET /restapi/relay/outlets/all/state/=name,physical_state/ HTTP/1.1
> Host: 10.0.1.xx:xxxx
> User-Agent: curl/7.51.0
> Accept: */*
* HTTP 1.0, assume close after body
< HTTP/1.0 200 OK
< Connection: close
< Content-Type: text/html
< Cache-Control: No-cache, no-store, must-revalidate, max-age=0
< Expires: Mon, 01 Jan 1990 00:00:01 GMT
< Pragma: no-cache
< Set-Cookie: DLILPC=""; Version=1; Max-Age=0; Path=/
{ [90 bytes data]
* Curl_http_done: called premature == 0
* Closing connection 0
   GhostXML Debug                  Source file type: XML
   GhostXML Debug                  stripNamespace() method called.
   GhostXML Debug                  <HTML><HEAD>
<META HTTP-EQUIV="refresh" content="0; URL=/">
</HEAD><BODY></BODY>
</HTML>
   GhostXML                        There was an parse error. Check XML source.
   GhostXML Debug                  Device needs updating set to: True
   GhostXML Debug                  getDeviceStateList() method called.
   GhostXML Debug                  Pulling down existing state list.
   GhostXML Debug                    Writing dynamic states to device.
   GhostXML Debug                  No new states found.
   GhostXML Debug                  Device needs updating set to: False
   GhostXML Debug                  parseStateValues() method called.
   GhostXML Debug                  Writing device states:
   GhostXML Debug                     Response = Parse error. Check XML source.
   GhostXML Debug                  Digital Loggers Switch updated.
Mar 25, 2018, 11:04:31 PM
* TCP_NODELAY set
> Accept: */*
< HTTP/1.0 200 OK
< Connection: close
< Pragma: no-cache
{ [90 bytes data]
Would appreciate any advice on this.
Mon Mar 26, 2018 5:48 am
Hmmm. This line from your AppleScript makes me think that you should set the authentication method to 'Basic':
Please try Basic Auth and see if that doesn't work for you.
Mon Mar 26, 2018 5:05 pm
hamw offline
This is basic, but in the log it says it is using "digest"?
   GhostXML Debug                  User prefs saved.
   GhostXML                        Debugging on (Level: 3)
   GhostXML Debug                  valuesDict: UiValuesDict : (dict)
     configMenuServerTimeout : 15 (string)
     infoLabel0 :  (string)
     sep2 :  (string)
     sep3 :  (string)
     sep4 :  (string)
     showDebugInfo : true (bool)
     showDebugLevel : 3 (integer)
     space0 :  (string)
     space10 :  (string)
     space11 :  (string)
     space4 :  (string)
     space5 :  (string)
     space6 :  (string)
     space7 :  (string)
     space8 :  (string)
     space9 :  (string)
     updaterEmail : XXX@comcast.net (string)
     updaterEmailsEnabled : false (bool)
     updaterLastCheck : 1522066432 (real)
   GhostXML Debug                  *   Trying 10.0.1.XX...
* TCP_NODELAY set
* Connected to 10.0.1.XX (10.0.1.XX) port XXX (#0)
* Server auth using Digest with user 'xxx'                                                         <<<<<<<<<<<<<<<<<<< Digest??
> Host: 10.0.1.XX:XXX
> Accept: */*
< HTTP/1.0 200 OK
< Connection: close
< Pragma: no-cache
{ [90 bytes data]
</HTML>
   GhostXML Debug                  validatePrefsConfigUi() method called.
   GhostXML Debug                  closedPrefsConfigUi() method called.
This is set to "Digest."
     sep2 :  (string)
     sep3 :  (string)
     sep4 :  (string)
     space0 :  (string)
     space10 :  (string)
     space11 :  (string)
     space4 :  (string)
     space5 :  (string)
     space6 :  (string)
     space7 :  (string)
     space8 :  (string)
     space9 :  (string)
     updaterEmail : xxxx@comcast.net (string)
* TCP_NODELAY set
* Connected to 10.0.1.XX (10.0.1.XX) port XXXX (#0)
* Server auth using Digest with user 'admin'
> Host: 10.0.1.XX:XXX
> Accept: */*
< HTTP/1.0 200 OK
< Connection: close
< Pragma: no-cache
{ [90 bytes data]
</HTML>
Is basic working as intended? I stopped the plugin and reloaded to see if that would enable basic, but there was no change in the log.
Mon Mar 26, 2018 6:22 pm
Okay, that's strange. Here's mine:
   GhostXML Debug                  deviceStartComm() method called.
   GhostXML Debug                  Starting GhostXML device: Test (HTTP Bin Basic)
   GhostXML Debug                  Device has been updated. Blow state list up to Trigger and Control Page labels.
   GhostXML Debug                  Time since update (44321) is greater than configured frequency (15)
   GhostXML Debug                  Queue task 586752937 sent to thread 586752937 - Test (HTTP Bin Basic)
   GhostXML Debug                  Found configured device: Test (HTTP Bin Basic)
   GhostXML Debug                  Refreshing device: Test (HTTP Bin Basic)
   GhostXML Debug                  *   Trying 50.17.198.171...
* TCP_NODELAY set
* Connected to httpbin.org (50.17.198.171) port 80 (#0)
* Server auth using Basic with user 'dave'
> GET /basic-auth/dave/test123 HTTP/1.1
> Host: httpbin.org
> Authorization: Basic ZGF2ZTp0ZXN0MTIz
> User-Agent: curl/7.54.0
> Accept: */*
< HTTP/1.1 200 OK
< Connection: keep-alive
< Server: meinheld/0.6.1
< Date: Tue, 27 Mar 2018 00:07:16 GMT
< Content-Type: application/json
< Access-Control-Allow-Origin: *
< Access-Control-Allow-Credentials: true
< X-Powered-By: Flask
< X-Processed-Time: 0
< Content-Length: 47
< Via: 1.1 vegur
{ [47 bytes data]
* Connection #0 to host httpbin.org left intact
   GhostXML Debug                  Source file type: JSON
   GhostXML Debug                  parseTheJSON() method called.
   GhostXML Debug                  Prior to FlatDict Running JSON
   GhostXML Debug                  {u'authenticated': True, u'user': u'dave'}
   GhostXML Debug                  After List Check, Before FlatDict Running JSON
   GhostXML Debug                  cleanTheKeys() method called.
   GhostXML Debug                  cleanTheKeys result:
   GhostXML Debug                     authenticated = True
   GhostXML Debug                     user = dave
   GhostXML Debug                  Test (HTTP Bin Basic) updated.
   GhostXML Debug                  deviceStopComm() method called.
   GhostXML Debug                  Stopping GhostXML device: Test (HTTP Bin Basic)
And with Digest:
   GhostXML Debug                  Starting GhostXML device: Test (HTTP Bin Digest)
   GhostXML Debug                  Time since update (6852422) is greater than configured frequency (15)
   GhostXML Debug                  Queue task 1499219718 sent to thread 586752937 - Test (HTTP Bin Basic)
   GhostXML Debug                  Found configured device: Test (HTTP Bin Digest)
   GhostXML Debug                  Refreshing device: Test (HTTP Bin Digest)
   GhostXML Debug                  *   Trying 174.129.203.239...
* TCP_NODELAY set
* Connected to httpbin.org (174.129.203.239) port 80 (#0)
* Server auth using Digest with user 'dave'
> GET /digest-auth/auth/dave/test123/MD5/never HTTP/1.1
> Host: httpbin.org
> Accept: */*
< HTTP/1.1 401 UNAUTHORIZED
< Date: Tue, 27 Mar 2018 00:09:14 GMT
< Content-Type: text/html; charset=utf-8
< Content-Length: 0
< Www-Authenticate: Digest realm="me@kennethreitz.com", algorithm=MD5, qop="auth", opaque="bd235384a66d8dba06405f6ee058669a", nonce="eeffa67a420df0a77aac7596af097ab6", stale=FALSE
< Set-Cookie: stale_after=never; Path=/
< Set-Cookie: fake=fake_value; Path=/
< Via: 1.1 vegur
* Issue another request to this URL: 'http://httpbin.org/digest-auth/auth/dave/test123/MD5/never'
* Found bundle for host httpbin.org: 0x7fc8b2501060 [can pipeline]
* Re-using existing connection! (#0) with host httpbin.org
> Host: httpbin.org
> Authorization: Digest username="dave", realm="me@kennethreitz.com", nonce="eeffa67a420df0a77aac7596af097ab6", uri="/digest-auth/auth/dave/test123/MD5/never", cnonce="MmIzZDdlNzBjNDY4YjYyZjg0MGIxMTZlYzMzYjg0ODQ=", nc=00000001, qop=auth, response="16d96d90a25968d3d58240e614d46820", opaque="bd235384a66d8dba06405f6ee058669a", algorithm="MD5"
> Accept: */*
< HTTP/1.1 200 OK
< Via: 1.1 vegur
{ [47 bytes data]
   GhostXML Debug                  Test (HTTP Bin Digest) updated.
   GhostXML Debug                  Stopping GhostXML device: Test (HTTP Bin Digest)
Please do me a favor and create a new device with Basic auth from the start. There could be a bug that doesn't show up until a user tries to change auth types.
Page 14 of 20 1 ... 11, 12, 13, 14, 15, 16, 17 ... 20
