Meteobridge Weather XML
Fri Sep 13, 2019 10:46 am
norcoscia offline
Re: Meteobridge Weather XML
That one is a version 3 (at least that is what one of the Amazon buyers received according to the amazon posts) - I did my best googling the heck out of the list but no luck finding one that would flash via web interface.
Seems like buying one that has already been flashed from ambient weather is an option but that starts to add up when you figure in the station cost - wish I could find a 25 dollar router - I will keep looking with my fingers crossed.
_______
Norm
Sat Sep 14, 2019 8:00 am
norcoscia offline
So I located a <23 dollar (new) V1 TP-LINK and it is on its way - I have done more reading and have a question about the GhostXML plugin.
Once I get everything running I'm assuming the plug-in will return values like the ones in the photo below.
My question is how do I map those values into indigo devices (and how are the devices created). Or do I need to create a variables for each value and (if so) - how does the info get into the variable. Is that all handled by the plug-in or will I need a python script (please say no).
Anyway thanks for all the help so far and I think this will eventually be a big upgrade for my weather station :-)
_______
Norm
Sat Sep 14, 2019 9:57 am
With the GhostXML plugin, you create a device that represents the data source you want to gather data from--in this case the Meteobridge device. The device will have states that contain all the data provided. The instructions for how to use the plugin are found here.
Note that the plugin imports all data as strings. Therefore, to use the data for math-based operations, you'll need to convert it yourself. For displaying on a control page, no adjustments are needed (unless you want to make the data prettier).
Sat Sep 14, 2019 10:02 am
norcoscia offline
Perfect, thanks!
_______
Norm
Sat Sep 14, 2019 10:04 am
Sure thing. Note that there is a post above that explains the settings that we've used to connect to the Meteobridge API.
Thu Sep 19, 2019 6:18 am
norcoscia offline
Thanks so much for helping Korey - set it up and it is working great - so much better than my last setup.
Dave, as usual your plug-in is working great - fantastic job!!!!!!!
_______
Norm
Thu Sep 19, 2019 6:26 am
Glad to hear that it's working for you. I noted it above, but all the data are imported as strings. To do math, you're going to have to convert them yourself.
Thu Sep 19, 2019 6:49 am
norcoscia offline
OK, got it - not sure if I need to do any math with the info but I guess I'll figure that out as I go!
Thanks again!
_______
Norm
Thu Sep 19, 2019 9:08 am
Korey offline
Thanks again!
Great news!
I use the adaptors plugin to convert wind speed & temp to imperial values.
Screen Shot 2019-09-19 at 8.06.25 AM.png (464.58 KiB) Viewed 5096 times
Korey
Thu Sep 19, 2019 9:14 am
norcoscia offline
Thanks Korey - I'm sure that will come in handy :-)
_______
Norm
Mon Sep 30, 2019 6:41 am
norcoscia offline
Did you figure out how to change the wind direction from degrees to something that looks like SE or SW or NNW - (like it is displayed on the weather flow page)? Can adapters plug-in do that?
_______
Norm
Thu Oct 03, 2019 10:10 am
Korey offline
I have not.
I'm sure there is a way to Convert º to N W S E using python, we just need the smart python guys to chime in!
Korey
Thu Oct 03, 2019 10:29 am
norcoscia offline
I could do it but it would take a million lines of code - someone smart could do it in just a few lines :-)
_______
Norm
Thu Oct 03, 2019 10:54 am
forestfield offline
How about 1 line...
Assuming wind direction is in a python variable called dir, then
wind_direction = ['N','NE','E','SE','S','SW','W','NW'][int(((dir+22.5)%360)/45)]
should be about right, assuming you want 8 compass points
Thu Oct 03, 2019 11:05 am
norcoscia offline
Wow, thanks - how about the next lottery number :-)
_______
Norm
