New install issue
Fri Nov 06, 2020 5:35 pm
shapa offline
New install issue
Enabling plugin "Announcements 1.0.17"
Starting plugin "Announcements 1.0.17" (pid 20952)
Announcements
Announcements =================================================== Initializing New Plugin Session ===================================================
Announcements Plugin name: Announcements
Announcements Plugin version: 1.0.17
Announcements Plugin ID: com.fogbert.indigoplugin.announcements
Announcements Indigo version: 7.4.1
Announcements Python version: 2.7.16 (default, Jun 5 2020, 22:59:21) [GCC 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.29.20) (-macos10.15-objc-
Announcements Mac OS Version: 10.15.7
Announcements Process ID: 20952
Announcements =======================================================================================================================================
Started plugin "Announcements 1.0.17"
Announcements Error Error in plugin execution startup:
File "plugin.py", line 235, in startup
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ast.py", line 49, in literal_eval
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ast.py", line 37, in parse
SyntaxError: ('unexpected EOF while parsing', ('<unknown>', 0, 0, ''))
Announcements Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 210, in runConcurrentThread
File "plugin.py", line 702, in announcement_update_states
SyntaxError: unexpected EOF while parsing (<unknown>, line 0)
Announcements Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Z-Wave received "Kitchen Motion Sensor Temperature" sensor update to 25.8 °C
Z-Wave received "Kitchen Motion Sensor Humidity" sensor update to 33%
Z-Wave received "Kitchen Motion Sensor Luminance" sensor update to 3 lux
Z-Wave received "Kitchen Motion Sensor Ultraviolet" sensor update to 0
Fri Nov 06, 2020 6:14 pm
Re: New install issue
Sorry you're having trouble (and thanks for reporting the error). By new install, does that mean that this is the first time you've ever installed this plugin?
Sat Nov 07, 2020 11:45 am
shapa offline
Yes, second home, clean Indigo install and first time installed the plugin.
Sat Nov 07, 2020 1:16 pm
Thanks, that will help me troubleshoot. The plugin is supposed to establish a default on first install, but clearly that's not happening properly.
Sun Nov 08, 2020 5:48 am
I have posted an update to the plugin that should fix this issue. Please try v1.0.18 which is available in the plugin store. NOTE: before enabling the new version of the plugin, please delete the files below if they exist (adjust the path to refer to your version of Indigo as needed).
Download Announcements Plugin v1.0.18
Delete these files if they exist:
/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.fogbert.indigoplugin.announcements.txt
/Library/Application Support/Perceptive Automation/Indigo 7.4/Preferences/Plugins/com.fogbert.indigoplugin.announcements.indiPref
Sun Nov 08, 2020 11:12 am
shapa offline
Hooray! Works now.
Starting plugin "Announcements 1.0.18" (pid 22879)
Announcements
Announcements Plugin version: 1.0.18
Announcements Process ID: 22879
Started plugin "Announcements 1.0.18"
Sun Nov 08, 2020 11:16 am
shapa offline
OK, another issue. Could not edit the announcement. The text is not editable.
"8 Nov 2020 at 17:14:26
Announcements Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 1089, in generatorStateOrValue
KeyError: key devVarMenu not found in dict
Not able to enter any text here:
Screenshot 2020-11-08 at 17.15.48.png (292.47 KiB) Viewed 3324 times
Sun Nov 08, 2020 12:14 pm
Sorry about that. That bug didn't show up for me when I was testing changes, but I can reproduce it. I'll get to work on a fix, but in the meantime, it seems that you can select Save for that dialog and then reopen it and you'll be able to go forward.
Sorry in advance if you come across any more bugs! :D
Sun Nov 08, 2020 12:36 pm
shapa offline
Save / re-open is not working :)
No worries, I will wait.
Sun Nov 08, 2020 12:42 pm
I've uploaded a new build that should fix the issue you found. I also stumbled upon another bug that is also fixed. This revised version (v1.0.19) has not yet been uploaded to the plugin store.
https://github.com/DaveL17/Announcements/archive/master.zip
