tazswe wrote:Hi Dave,
It should be nice if it would be possible to adjust the words per minute rate. I think that it’s to fast at the moment and would like to have the possibility to slow it down when you have longer and more complex announcements.
Skickat från min iPad med Tapatalk
say "[[rate 150]]This is a sentence with seven words."
from os import system
import datetime as dt
for r in range(1000, 0, -100):
now = dt.datetime.now()
system('say one [[slnc {}]] two'.format(r))
print(dt.datetime.now() - now)
anyone wrote:I would like to request a feature that allows the announcement string spoken by the built-in speech synthesizer to be exposed for use by other plugins.
Currently, when the "Speak Announcement" button is clicked on the "Configure Announcement Device" screen, only the built-in speech synthesizer is used. I would like the ability to route the announcement string through another tool so that it can be spoken by a different speech synthesizer plugin. This would help in the integration of alternative speech synthesizers, as it would allow users, as they construct Announcements, to hear their complex announcements strings thru their preferred tool.
killerdan56 wrote:Can you make a version that plays a sound before or after the spoken announcement using this app https://www.macupdate.com/app/mac/63375/play-sounds
Would appreciate it
